Tractor Trumps - So...
Tractor Trumps - South Glos Rules 😉
202 Users
319 Reactions
12.4 K Views
Old Tractor Pron.
Posted : 07/12/2010 4:59 pm
The "Mini Mutant"
Posted : 07/12/2010 5:01 pm
Not a tractor in the strictest sense... but interesting.
[url= http://static.zooomr.com/images/9666017_ef30f0d184_o.jp g" target="_blank">http://static.zooomr.com/images/9666017_ef30f0d184_o.jp g"/> [/img][/url]
Posted : 07/12/2010 5:26 pm
From yesterdays ride..
[url= http://static.zooomr.com/images/9673089_4cead7c2ee.jp g" target="_blank">http://static.zooomr.com/images/9673089_4cead7c2ee.jp g"/> [/img][/url]
[url= http://static.zooomr.com/images/9673086_7f97b7c00d.jp g" target="_blank">http://static.zooomr.com/images/9673086_7f97b7c00d.jp g"/> [/img][/url]
[url= http://static.zooomr.com/images/9673083_b3373d31bb.jp g" target="_blank">http://static.zooomr.com/images/9673083_b3373d31bb.jp g"/> [/img][/url]
[url= http://static.zooomr.com/images/9673084_e816b5f076.jp g" target="_blank">http://static.zooomr.com/images/9673084_e816b5f076.jp g"/> [/img][/url]
Posted : 12/12/2010 12:17 pm
 mc
smiffy - Member
"mc - Member
Is that a 3 cyl Perkins 35?
It's a TE20 with a P3 conversion.
The other option was the infamous gold seal diesel engine (basically the Standard petrol engine converted to diesel, which is what mcmoonter probably has), which was renowned for it's poor starting.
The P3 conversion kit was supplied by Perkins, and was that succesful, it resulted in MF using Perkins engines as standard."
My 35x is a Perkins 3; it starts after a night indoors with a Shogun jumpstart!
The 35 didn't use a P3 😉
The P3 refers to the first of the perkins diesels, which also came in 4 and 6 cylinder versions, suprisingly named the P4 and P6.
The P-series of engines used inline injection pumps, and also the design feature whereby the con-rod big-end was larger than the cylinder bore, so you had to push the piston out the top, remove the gudgeon pin, then drop the con-rod out the bottom (they make for a lot of strong language when trying to get the things back together!)
The 35, used the newer 3.152 series of engine, complete with rotary fuel pumps, with the original 35s using the indirect injected version, before introducing the 35X signifying the move to the A3.152 direct injected version.
Which was then replaced by the AD3.152 with the introduction of the 135.
Massey continued to use the 3.152 in various versions up until they stopped production of the smaller 200 series tractors in the late 90s.
And yes, I know I sound far too geeky, but I've rebuilt numerous perkins 3-cylinders, and know them pretty well, including the variances between the different versions.
Posted : 12/12/2010 2:33 pm
 mc
Oh, and any direct injected 3.152 engine that takes more than a few seconds of cranking in above freezing temperatures, has issues.
Posted : 12/12/2010 2:56 pm
fettling - that's a little forwarder for shifting timber out of the woods. Those little Rottnes are tough like terriers, never seen one that straight with that much paint on it though.
Posted : 12/12/2010 3:22 pm
...the 35X signifying the move to the A3.152 direct injected version.
That's the one we have.
Posted : 13/12/2010 9:28 am
I am informed by the owner it is a home bodged thing - will print off this and check what he has under the bonnet...
Posted : 13/12/2010 9:10 pm
Came across this badboy this morning when I took a diversion on the ride into work...
Posted : 14/12/2010 5:40 pm
Yesterday.. Possibly an old David Brown
[url= http://static.zooomr.com/images/9684204_5e03d95ffc_o.jp g" target="_blank">http://static.zooomr.com/images/9684204_5e03d95ffc_o.jp g"/> [/img][/url]
Posted : 19/12/2010 6:18 pm
 mc
Anything with a P3 is home bodged, as it was only available as a conversion kit from perkins, but I'm sure there have been numerous other engines fitted by others. It's just that the P3 conversion was one of the more popular options.
Posted : 19/12/2010 6:32 pm
Late David Brown in the Case takeover phase, best of the cheap tractors
Posted : 22/12/2010 10:45 am
our 35X is factory spec with P3, just like every other 35X I've ever seen? (and sadly I've looked over a few).
Posted : 22/12/2010 11:24 am
Does this count? Taken today.
Posted : 12/01/2011 8:57 pm
[url= http://static.zooomr.com/images/9736715_3541a23078_o.jp g" target="_blank">http://static.zooomr.com/images/9736715_3541a23078_o.jp g"/> [/img][/url]
Posted : 18/01/2011 11:22 pm
 mc
I'm guessing you missed my post further up the page about perkins engines, what they were referred to as, and what they were fitted in 😉
Posted : 31/01/2011 11:41 am
[url= http://static.zooomr.com/images/9808000_87a57fa1ff_o.jp g" target="_blank">http://static.zooomr.com/images/9808000_87a57fa1ff_o.jp g"/> [/img][/url]
c.1942 HUBER 8ton 4cylinder diesel ROLLER
Serial No. 3400
Fitted with CAT D4 engine with petrol donkey start, rear scarifier and canopy. Originally imported into the UK by the US Army for airbase construction during WWII. Post war sold to West County building firm and used for road construction then later used as company display. Signed on canopy Downing Rudman & Bent.
Posted : 25/02/2011 8:12 pm
On the ride into work this morning...
Posted : 28/02/2011 4:13 pm
Going to need the big hammer to fix that one!
Posted : 28/02/2011 4:25 pm
Dingtastic 😉
Posted : 28/02/2011 5:02 pm
[url= http://farm6.static.flickr.com/5135/5547604005_86dd6e7cf7.jp g" target="_blank">http://farm6.static.flickr.com/5135/5547604005_86dd6e7cf7.jp g"/> [/img][/url]
A hetic weekend to bring it all together but a brace of Newhollands and a bell 205
Posted : 21/03/2011 10:46 pm
oldagepredator - prefer the next pic with the 'mog, not much of a NH fan (bit fragile in my hands).
Just had a heli-lift at work too moving 100 ton of stone onto the Beacons and a 1000 bags of moor cuttings for peat bog restoration on Abergwesyn.
Posted : 27/03/2011 10:42 pm
[img] ?w=640&h=400[/img]
Posted : 27/04/2011 6:10 pm
[url= http://farm7.static.flickr.com/6089/6053375110_40ed7d309d_o.jp g" target="_blank">http://farm7.static.flickr.com/6089/6053375110_40ed7d309d_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/65359900@N08/6053375110/ ]The New Fleet :-)[/url] by [url= http://www.flickr.com/people/65359900@N08/ ]MTB Arena[/url], on Flickr
Posted : 17/08/2011 4:22 pm
Here are a few from Kansas.
Posted : 05/10/2011 8:35 am
Good God is this thread really two years old.!!! 😯
Posted : 05/10/2011 8:36 am
And it keeps on giving.
Posted : 05/10/2011 10:25 am
Even I forgot about it 😉 😯
Great pix McMoonter BTW.
Posted : 05/10/2011 10:28 am
[url= http://farm7.static.flickr.com/6050/6214063910_de5f06a582_o.jp g" target="_blank">http://farm7.static.flickr.com/6050/6214063910_de5f06a582_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/6214063910/ ]IMG_2284[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 05/10/2011 11:09 am
After that recent post about deleting history etc. and threads closing after 12 months.
I thought I'd keep the baby alive 😉
Heres some recent stuff, as seen out on rides.
[url= http://farm9.staticflickr.com/8020/7456420564_5f2c5e0e2d_b.jp g" target="_blank">http://farm9.staticflickr.com/8020/7456420564_5f2c5e0e2d_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456420564/ ]IMG_3766[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8010/7456440160_054b966a77_b.jp g" target="_blank">http://farm9.staticflickr.com/8010/7456440160_054b966a77_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456440160/ ]Little Orange Tractor[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm8.staticflickr.com/7250/7456448898_6e2ea32cba_b.jp g" target="_blank">http://farm8.staticflickr.com/7250/7456448898_6e2ea32cba_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456448898/ ]John Deere Tractor[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm8.staticflickr.com/7129/7456458226_061eb3d27c_b.jp g" target="_blank">http://farm8.staticflickr.com/7129/7456458226_061eb3d27c_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456458226/ ]Powwwwer[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 27/06/2012 7:53 pm
South Gloucestershire County Councils own tractor.
[url= http://farm8.staticflickr.com/7106/7456473054_d45396220c_b.jp g" target="_blank">http://farm8.staticflickr.com/7106/7456473054_d45396220c_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456473054/ ]IMG_2093[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 27/06/2012 8:02 pm
Final two, for a while.
[url= http://farm9.staticflickr.com/8014/7456473240_cd8e21dc1c_b.jp g" target="_blank">http://farm9.staticflickr.com/8014/7456473240_cd8e21dc1c_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456473240/ ]IMG_2129[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm8.staticflickr.com/7252/7456473440_81db49162e_b.jp g" target="_blank">http://farm8.staticflickr.com/7252/7456473440_81db49162e_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456473440/ ]IMG_2145[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 27/06/2012 8:03 pm
and another..
[url= http://farm8.staticflickr.com/7250/7456487650_04e839f898_b.jp g" target="_blank">http://farm8.staticflickr.com/7250/7456487650_04e839f898_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456487650/ ]Dreamy :-)[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 27/06/2012 8:04 pm
 Kuco
Posted : 27/06/2012 8:07 pm
and another.. spy shot 😉
[url= http://farm9.staticflickr.com/8012/7456502824_b81afce596_b.jp g" target="_blank">http://farm9.staticflickr.com/8012/7456502824_b81afce596_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456502824/ ]Spy Shot John Deere[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8014/7456498542_d96e429610_b.jp g" target="_blank">http://farm9.staticflickr.com/8014/7456498542_d96e429610_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456498542/ ]John Deere[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 27/06/2012 8:10 pm
@kuco
What is it ?
Keep em' coming.
Posted : 27/06/2012 8:11 pm
for fun..
[url= http://farm8.staticflickr.com/7112/7456536042_dca5571cfd_b.jp g" target="_blank">http://farm8.staticflickr.com/7112/7456536042_dca5571cfd_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456536042/ ]IMG_8201[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 27/06/2012 8:13 pm
 Kuco
Can't remember exact model other than it's an old Mercedes with one of our works Case 9007 excavators.
Searching Google think it's an MB Trac [url= http://en.wikipedia.org/wiki/MB_Trac ]Wiki[/url]
Posted : 27/06/2012 8:14 pm
Final few...
[url= http://farm8.staticflickr.com/7276/7456516748_788d5f8fc8_b.jp g" target="_blank">http://farm8.staticflickr.com/7276/7456516748_788d5f8fc8_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456516748/ ]IMG_9522[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8163/7456518624_d7420c1d6e_b.jp g" target="_blank">http://farm9.staticflickr.com/8163/7456518624_d7420c1d6e_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456518624/ ]IMG_9419[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8162/7456546432_279d06414d_b.jp g" target="_blank">http://farm9.staticflickr.com/8162/7456546432_279d06414d_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456546432/ ]IMG_7123[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm8.staticflickr.com/7132/7456550802_573d596164_b.jp g" target="_blank">http://farm8.staticflickr.com/7132/7456550802_573d596164_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456550802/ ]IMG_7142[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8152/7456551024_5dde64b939_b.jp g" target="_blank">http://farm9.staticflickr.com/8152/7456551024_5dde64b939_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456551024/ ]IMG_7284[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8008/7456551190_0433e8dcde_b.jp g" target="_blank">http://farm9.staticflickr.com/8008/7456551190_0433e8dcde_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456551190/ ]IMG_7288[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Right back to the beginning of the year 🙂
Posted : 27/06/2012 8:21 pm
Final.
[url= http://farm9.staticflickr.com/8163/7456602916_250f5b57f8_b.jp g" target="_blank">http://farm9.staticflickr.com/8163/7456602916_250f5b57f8_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7456602916/ ]Claas[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 27/06/2012 8:26 pm
Here's my own little tractor!
Its a 1950's Nuffield DM4, runs sweet and goes well!
Posted : 27/06/2012 8:35 pm
Not mine, and a loooong way away. [url= http://farm9.staticflickr.com/8144/7456873124_ca0a18257e_b.jp g" target="_blank">http://farm9.staticflickr.com/8144/7456873124_ca0a18257e_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/96661824@N00/7456873124/ ]Coromandel Tractor[/url] by [url= http://www.flickr.com/people/96661824@N00/ ]rob_j_hopkins[/url], on Flickr
Posted : 27/06/2012 9:24 pm
[url= http://farm8.staticflickr.com/7246/7466324714_3b4d1f9207_b.jp g" target="_blank">http://farm8.staticflickr.com/7246/7466324714_3b4d1f9207_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7466324714/ ]Tractor of the Day :-)[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 29/06/2012 12:36 pm
 mos
[url= http://farm8.staticflickr.com/7119/7466369534_2f30ba1f6f.jp g" target="_blank">http://farm8.staticflickr.com/7119/7466369534_2f30ba1f6f.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/65116677@N02/7466369534/ ]Claas at Driffield[/url] by [url= http://www.flickr.com/people/65116677@N02/ ]marcusandcath[/url], on Flickr
Spotted by my daughter at Driffield Show
Posted : 29/06/2012 12:48 pm
@mos
Just Claas 🙂
Start them young 🙂
Posted : 29/06/2012 1:12 pm
[img][url= http://farm4.staticflickr.com/3154/2438578691_b7b3421074.jp g" target="_blank">http://farm4.staticflickr.com/3154/2438578691_b7b3421074.jp g"/> [/img][/url]
[/img]
Posted : 29/06/2012 1:30 pm
[url= http://farm9.staticflickr.com/8011/7473207360_470c796178_b.jp g" target="_blank">http://farm9.staticflickr.com/8011/7473207360_470c796178_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7473207360/ ]Tractor of the Day :-)[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm8.staticflickr.com/7133/7473207162_4e98d19ef6_b.jp g" target="_blank">http://farm8.staticflickr.com/7133/7473207162_4e98d19ef6_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7473207162/ ]Tractor of the Day :-)[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 30/06/2012 4:56 pm
Must try and get a pic of the Suffolk Constabulary's New Holland.
Posted : 30/06/2012 5:09 pm
We don't want to hear your excuses 😉 Just get on with it, and get that pic 🙂
Your bike in shot for extra points.
Posted : 30/06/2012 5:12 pm
Posted : 30/06/2012 5:50 pm
I did this a couple years ago. In the JD here. Pushed wide by a car racing the corner and as soon as it went to 2 wheels it was all over, lucky not to topple the JD too.
Posted : 30/06/2012 6:16 pm
I don't think I've posted this yet, apologies if I have:
[url= http://farm7.staticflickr.com/6080/6111173433_bbac96294d.jp g" target="_blank">http://farm7.staticflickr.com/6080/6111173433_bbac96294d.jp g"/> [/img][/url]
Posted : 30/06/2012 8:21 pm
@beamers
I like that 🙂
No restrictions here... post as many as you like.
Posted : 01/07/2012 5:12 pm
If you want rusty..........
[url= http://farm5.staticflickr.com/4049/4414225634_8d6ebffaa2.jp g" target="_blank">http://farm5.staticflickr.com/4049/4414225634_8d6ebffaa2.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/salsaboy/4414225634/ ]Caterpillar[/url] by [url= http://www.flickr.com/people/salsaboy/ ]andy_carter[/url], on Flickr[/img]
Posted : 03/07/2012 1:40 pm
mos - Going to driffield this year? I shall be there in the fencing competition 🙂
Posted : 03/07/2012 2:57 pm
Bloody hells bells was this thread really started 3 years ago... 😯
Posted : 03/07/2012 3:01 pm
 mos
Shorty, gonna try, depends on work. Whats your company name?
Posted : 03/07/2012 3:31 pm
My grey Fergie delivering the funky new stove.
Posted : 03/07/2012 3:39 pm
mos - Jaggers fencing 🙂
Posted : 03/07/2012 4:17 pm
It could be the oldest open thread on here ?
Posted : 04/07/2012 9:31 am
@salsaboy.
Great pix from that graveyard.
Like
http://www.flickr.com/photos/salsaboy/4413601377/in/photostream/
Posted : 04/07/2012 9:38 am
[rub thighs]Mmmm...[.rub thighs]
[url= http://farm9.staticflickr.com/8008/7500112190_29ff2f955f_o.jp g" target="_blank">http://farm9.staticflickr.com/8008/7500112190_29ff2f955f_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7500112190/ ]Aliss Chalmers in Action - not South Gloucestershire :-([/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 04/07/2012 9:47 am
Le Tour collection 🙂
[url= http://farm9.staticflickr.com/8160/7508979378_788062b4be_o.jp g" target="_blank">http://farm9.staticflickr.com/8160/7508979378_788062b4be_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7508979378/ ]Tour De France - Tractortastic[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 05/07/2012 5:07 pm
Yesterday and today's....
[url= http://farm9.staticflickr.com/8026/7650990764_11041d53b7_o.jp g" target="_blank">http://farm9.staticflickr.com/8026/7650990764_11041d53b7_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7650990764/ ]Tractor & Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8292/7650990360_f6c0475d3f_o.jp g" target="_blank">http://farm9.staticflickr.com/8292/7650990360_f6c0475d3f_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7650990360/ ]Tractor & Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8008/7650989506_15582af73d_o.jp g" target="_blank">http://farm9.staticflickr.com/8008/7650989506_15582af73d_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7650989506/ ]Tractor & Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm8.staticflickr.com/7113/7650989298_a133445a68_o.jp g" target="_blank">http://farm8.staticflickr.com/7113/7650989298_a133445a68_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7650989298/ ]Tractor & Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm8.staticflickr.com/7277/7650990142_d262564dbf_o.jp g" target="_blank">http://farm8.staticflickr.com/7277/7650990142_d262564dbf_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7650990142/ ]Tractor & Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 26/07/2012 5:55 pm
[url= http://farm9.staticflickr.com/8432/7650991514_5e80d13014_o.jp g" target="_blank">http://farm9.staticflickr.com/8432/7650991514_5e80d13014_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7650991514/ ]Tractor & Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 26/07/2012 5:56 pm
Coulpe more... including Bradley Wiggins spotting 😉
[url= http://farm8.staticflickr.com/7107/7651401894_31cd4cf3e8_o.jp g" target="_blank">http://farm8.staticflickr.com/7107/7651401894_31cd4cf3e8_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7651401894/ ]IMG_5928[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8154/7651402124_2dd978b661_o.jp g" target="_blank">http://farm9.staticflickr.com/8154/7651402124_2dd978b661_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7651402124/ ]IMG_5997[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 26/07/2012 5:58 pm
[url= http://farm9.staticflickr.com/8003/7678008612_146d51dba2_o.jp g" target="_blank">http://farm9.staticflickr.com/8003/7678008612_146d51dba2_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7678008612/ ]2012 Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 30/07/2012 5:34 pm
Show me your 2012 combine pix 🙂
[url= http://farm8.staticflickr.com/7110/7678005728_666c91cfcc_o.jp g" target="_blank">http://farm8.staticflickr.com/7110/7678005728_666c91cfcc_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7678005728/ ]2012 Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8423/7678007220_2c25a9f878_o.jp g" target="_blank">http://farm9.staticflickr.com/8423/7678007220_2c25a9f878_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7678007220/ ]2012 Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm9.staticflickr.com/8003/7678008126_051e266003_o.jp g" target="_blank">http://farm9.staticflickr.com/8003/7678008126_051e266003_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7678008126/ ]2012 Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
[url= http://farm8.staticflickr.com/7125/7678005542_1db6c1ee68_o.jp g" target="_blank">http://farm8.staticflickr.com/7125/7678005542_1db6c1ee68_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7678005542/ ]2012 Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 30/07/2012 5:36 pm
Combines and Forage harvesters can't be called tractors 🙄
Posted : 30/07/2012 5:46 pm
@pigface
But a rule breech is OK at this time of year :-).
I'm not starting a specific Self-Propelled Forage Harvester thread.. that's just sad 😉
Here is a combine from the other day... there must be loads around the country at the moment, get snapping 🙂
[url= http://farm9.staticflickr.com/8424/7650990584_f57a36ef7d_o.jp g" target="_blank">http://farm9.staticflickr.com/8424/7650990584_f57a36ef7d_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7650990584/ ]Tractor & Combine[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 30/07/2012 6:09 pm
Posted : 30/07/2012 6:22 pm
 Muke
8)[img] [/img]
Posted : 30/07/2012 8:42 pm
Great thread! 😀
Seriously, can't believe the size of these contraptions in real life. 😯
Posted : 30/07/2012 8:59 pm
[url= http://farm8.staticflickr.com/7119/7685207854_ce9fe48f7b_o.jp g" target="_blank">http://farm8.staticflickr.com/7119/7685207854_ce9fe48f7b_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/58162507@N07/7685207854/ ]IMG_9634[/url] by [url= http://www.flickr.com/people/58162507@N07/ ]SGMTB[/url], on Flickr
Posted : 31/07/2012 4:53 pm
[url= http://farm9.staticflickr.com/8434/7741304986_8d894ee788.jp g" target="_blank">http://farm9.staticflickr.com/8434/7741304986_8d894ee788.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/matt_outandabout/7741304986/ ]Ian's Massey Ferguson 35[/url] by [url= http://www.flickr.com/people/matt_outandabout/ ]matt_outandabout[/url], on Flickr
[url= http://farm9.staticflickr.com/8448/7741315404_d8fa511a66.jp g" target="_blank">http://farm9.staticflickr.com/8448/7741315404_d8fa511a66.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/matt_outandabout/7741315404/ ]Massey Ferguson 35[/url] by [url= http://www.flickr.com/people/matt_outandabout/ ]matt_outandabout[/url], on Flickr
[url= http://farm8.staticflickr.com/7132/7741338836_6222452fac.jp g" target="_blank">http://farm8.staticflickr.com/7132/7741338836_6222452fac.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/matt_outandabout/7741338836/ ]Massey Ferguson 35[/url] by [url= http://www.flickr.com/people/matt_outandabout/ ]matt_outandabout[/url], on Flickr
[url= http://farm9.staticflickr.com/8292/7741355636_8a72b46790.jp g" target="_blank">http://farm9.staticflickr.com/8292/7741355636_8a72b46790.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/matt_outandabout/7741355636/ ]Ian's Tractor[/url] by [url= http://www.flickr.com/people/matt_outandabout/ ]matt_outandabout[/url], on Flickr
Posted : 08/08/2012 6:10 pm
Im in North Norfolk at the minute so be prepared to be trumped the lot of you 😆
Posted : 08/08/2012 6:12 pm
How can you trump a type 35 with double wheels and a home-made, propelled, log lifting and winching trailer? 😉
Posted : 08/08/2012 6:15 pm
i used to work on army tractors (not my picture) best i can do for a london lad (all though i do now work on a farm)
Posted : 08/08/2012 6:36 pm
Can I ask a question? I would love to take pics of tractors but am rather concerned that I could be mistaken for a stalker. 😳
Are you all using powerful lenses or do you hide in a hedge or what do you do?
Thanks. 🙂
Posted : 08/08/2012 6:42 pm
Page 4 / 15
