I have just had a £500+ monthly energy bill!!!!!
Yes, I have alerted my provider and asked how the hell 2 people in a 3 bed use more power than Luxembourg but while I await their response I thought I would check here.
How can I find out where the power is going?
I could turn off the main fuse board and then turn on one circuit at a time and record the daily consumption but that is a mite inconvenient.
Any better suggestions?
How big is your fridge?
It'll be something like that?
I have an energy monitoring plug which sits between the main socket and a single device and tells me how much juice that device is using.
£15 or so from Amazon and then plug each suspect device into it (fridge, washing machine, dryer etc).
That said - £500 does seem extraordinarily high for nearly all domestic settings I can think of so a couple of things to rule out; 1/ A recent meter change? The end reading of the old meter or even the start reading of the new meter could be wrong (they do not always come starting at zero so if they have assumed 0 but it was actually 00200 for eg then you will have been billed for 200kW you have not used), 2/ a few estimated readings being a bit low and now an actual meter reading correcting the last few months usage, 3/ the most recent reading being incorrect, 4/ a faulty meter (does happen occasionally), 5/ someone tapping into your meter and running a cannabis farm next door.
Just for reference we are a 3 person household - 2 adults, 1 child. We have the large TV on lots, my work station on lots, a PS5 on lots, Mrs D drying her hair each day for a length of time I cannot even fathom, washing machine on at least once and sometimes twice a day, dishwasher on once a day, very large American style fridge/freeze and a plethora of snake tanks with heating and lighting. Our leccy usage is £120ish p/m in winter and a bit less in summer.
First off are you 100% sure that the meter readings, start and finish, are accurate? That would be my first thought. After that your pretty much need a smart meter and switch off. Items for me by one.
You haven’t accidentally switched on an electric immersion heater for the hot water tank have you?
Have you just bought a Tesla?
Have you actually used £500, or is it a direct debit increase based on an estimate?
Just checked the little Octopus Energy display screen and it reckons we have used £1,500 so far this year.
I haven't got one so I could be wrong, but isn't that what Smart Meters are for?
Are you on Octopus Go? If so the smart meter isnt that smart if you are charging an electric car overnight as it doesnt record it at the lower rate. You can see the lower rate if you check the bills but sometimes wake up with £7 usage from an overnight charge when it is in fact about £2
Your display should tell you what you are using instantaneously and also historically.
That's basically it's raison de'etre
I'd invest in a couple of decent smart plugs and take a peek at suspect devices (washing /drying, topup heating). I've an eve device in my office to trigger/monitor the oil filled rad. If you use the dedicated eve app it'll show usage trands for the device and even provide projected costings based on past usage.
Just a thought: you've not accidentally switched on an immersion heater in a cupboard?
Neighbours tapping your power for their skunk farm?
Surely you can work out what's plugged in.
I reckon only using electricity for heating could use so much - how do you heat the house?
Left the immersion on?
@dannybgoode - without wanting to derail the thread too much, but how on earth does a family of 3 need to run the 'washing machine on at least once and sometimes twice a day' ?
Not a dig/attack, i am just always curious as to how others live.
In clean clothes daily
With a clean dry fresh towel daily
Bedding washed weekly
Sports kits most days
I’m not in charge of such things so only have a scant knowledge of such things however I do know a) a 9yo generates more dirty clothes than could possibly ever be imagined, b) Mrs D is a nurse and has to wash her uniforms as soon as she gets in from a shift, c) I’m pretty sure someone else sneaks their washing in with ours as well as I think the washing machine is on too much as well 😀
I pedict 10 pages of this next week when the fisry full month of new prices hits.
People are going to be stunned, as is wca, by the actual cost of fuel amd food.
Its only going to get worse as well, as long as the war in Ukraine continues.
Tjats why we should be throwing the kitchen sink aand everything else in that direction.
As for high wattage items. Washing machine, tumble dryer, dishwashers are up there. Then tv and computers, lower but on long time.
I did a 2 week meter read and octopus sent me a bill. £14 gas and £40 elec. I live alone. So £110pcm. That's being frugal too. Instantly changed my dd payment to £100 to pre empt the outcry and subsequently high demands from Octopus.
Not got a hot tub or oil filled radiator on ? Used the oven a lot or long showers (assuming elec shower).
I've been monitoring energy use and the hot tub is a killer - we now just leave the pump on and water at the lowest setting of 20c, only switch on when needed once a week. Saving over £100 a month. Also ditched using the dryer - clothing on airer in conservatory with a dehumidifier.
I've been doing weekly readings and chucking it into a spreadsheet. We've really cut down on Kwh. Worked out that using the hot tub one night a week costs about £4 to heat to 39c !
We got hammered last winter with both of us WFH, heating on, oil filled radiators on in conservatory and shed office. I moved into the conservatory this winter and had the heating on low (and put a jumper on). I'm about to move back out to the shed as the conservatory is too bright in the afternoons, but there will be no heating being used in the shed !!
Our variable electric is now just short of 27p per Kwh, up from 19p
We're a family of 5. If the washing machine wasn't a peak-STW-miele I reckon it would have walked out of the house in protest by now. I daredn't plug it in to a smart plug.
Indeed wca has a hot tub. Time for a solar array to heat that bad boy up.
I suspect my energy supplier will want to come out to check the meter as we've cut back so much ! 🙂
Hot tub was recently refilled and heated from 14 degrees to 38. Total energy consumption for the house during that period was £14 which was largely the tub I should imagine. I am using it 3 - 4 times a week so cheaper to keep it up to temp than reheating 1000 litres of water.
Sauna is about £2 for the time I am in there which even at 5 times a week would only be about £500 e year so well worth it for the pain relief it gives.
Electric car is on overnight timer so charges from midnight but the battery is so degraded that it only takes about 1 hour to fully charge.
I am aware we probably use more power than normal due in part to the above high consumptions but still not 4 times the average.
Will get a plug meter reader to check the fridges, washing machine, tumble dryer etc.
Worn =/ dirty. You can wear most stuff stuff more than once before it needs washing.
Really? A new towel every day? I don't even do that in a hotel.
Nor do I, because its not necessary.
However there are many people who do actually only use a towel once then wash it.
Ditto clothes
That is why some people do 10 loads of washing a week
I’m sorry I’m having no sympathy for someone running a hot tub, sauna and electric car then complaining about their fuel bill, whilst other people are deciding how to afford to eat.
I do understand you want to check you’re being charged with honesty, but that’s a massive out of proportion first world problem IMO.
I’ve been monitoring energy use and the hot tub is a killer
Surely you must've known this when you bought it?
Ours is about £140/month with an electric car (although low ish mileage), two desktop PCs on a lot in the evening (kids). We re-use towels, re-wear trousers a lot, means we do about 3 loads of laundry a week (for four of us). I have enough sports kit to wash it all together once a week.
Overnight quiescent drain is about 120W, in the evenings it's 300W or so.
To the OP - are you using power tools a lot? If you are using a lot of tools, a vacuum or even a welder that would really push up your bill. I once ran a small fan heater for a day or so to dry out our caravan, made a significant impact on the bill and that was years ago before the current price shocks.
I have never actually complained about being charged for what I use. I know and appreciate that I am in a lucky* position to live my life.
I just asked for help on tracing what I think is over metering of energy use.
*Not sure if you are aware that my user name has led to me being registered disabled - or might be the other way around. The 'hot tub' is a hydrotherapy tub to allow me to exercise my leg in a controlled temperature with the extra support that the water provides. The sauna is run at a low temperature of around 50 degrees but I am in there for a longer period so that the heat of my body core is raised and all muscles are properly heated through to promote relaxation and reduce the pain in muscles and joints exacerbated by the poor posture when walking caused by the ankle. The electric car is a 2011 Nissan Leaf with approximately 35 mile range that was bought for about £3,000 if memory serves for all of the short journeys to the shops, train station etc that I would have previously walked or ridden. I am not looking for your sympathy but just pointing out that sometimes there is something more that joy behind the purchase of such 'toys'
I need to look into this a bit to (also Hot tub owner/user). Last time I did the calc is was costing about a £1 a day on average. This was pre recent prices rises so a fresh calc is due.
Any recommendations on the energy monitoring plugs? Is there an option which can export usage to a file? (e.g. csv)
I don't have hot tub, sauna, electric car or any electric heating.
We're 'average' family of 4 in average 4 bed semi with all A+ rated appliances and 4 year old boiler, who do resort to tumble drier on too many occasions.
I'm now on a £220 a month to stave off the price rise, and expect by Christmas to be on £250-300 a month if predictions are correct.
It's the hot tub at 38c using the power. They are really expensive to run, add in the sauna too.
A hot tub is like having a 1kw kettle on 24/7. So 30p per hour, or £7.20 per day maximum (£223 a month). Assume heater is only on 50% of the time you are looking at £100 easy. We've just slashed the costs by about £3-£4 a day (checked with regular meter readings). Electric was at about £9 per day when hot tub was 'ticking over', it's now under £6 per day with the heat down at just 20c, then upped once a week.
<John Peel>Later we've got a session from Overnight Quiescent Drain</John Peel>
Ditto clothes
Ah, gotcha, fair enough.
I am using it 3 – 4 times a week so cheaper to keep it up to temp than reheating 1000 litres of water.
Think about that for a minute - by my reckoning there is no way this can be correct. Sure reheating it will use a lot of power (and be a pain as it's not ready to use when you want it) but keeping it up to temp will use more.
Every minute that the water is above ambient temperature it is losing energy to the environment, and the bigger the difference between ambient temperature and the water temperature the more energy it is losing.
but how on earth does a family of 3 need to run the ‘washing machine on at least once and sometimes twice a day’ ?
Household of one here and washing machine does around 10 loads per week. I do have daily sweats and chills though. Towels used to be changed twice weekly but now eeking that out a bit. Sheets changed twice weekly in warmer months.
Washer is on daily here - my cycling kit on quick washes. Washers are relatively cheap if on cool washes. It's the dryers that cost. SIL had her daughter and kids staying for a while a few years back, and they were use towel once, in washer, then in dryer. Electric bill for SIL was huge.
I appreciate OP needs the hot tub, but I'd suggest dropping the temp when not used, then put the heat on in the morning, for use that evening. Ours will heat at about 1.5c per hour. We've even got kingspan on the top of ours to keep the heat in. I recon even with use 3 x a week he'll save about half the energy bill.
How much juice does your thicknesser use?!
All joking aside, are you using power tools more often? Doing any welding? It may not be a big single thing (but those are easy to check), it could be accumulation of other activities.
Wow, that is a lot.
Family of 4 here and our machine does about 5-6 loads per week. Never use the tumble dryer, but we do live somewhere with very dry air and have central heating that keeps the house warm.
People washing towels daily/after every use are wasting money and killing the planet. There is just no need. Surely you use them to dry your clean skin rather than rub the dirt off?
Can you take the cover off and put on a piece of glass when the sun's out? Might help 🙂
From the Artic Spa website - How much does a hot tub cost to run? The average running cost of a 2 pump Hot Tub will vary according to insulation, usage and again construction. We average out at around £0.41 per day and that is with 40 minutes use every day. Even allowing for that being an advert and increased costs, from looking at the Octopus meter it appears to be about £1 per day for the hot tub at 38 degrees.
We chose the Artic Spa partly because of the low running costs. The shell that forms the tub is fully insulated. It sits in a wooden frame/shell that is also fully insulated so when the water leaves the tub, the pipes are still in an insulated area. The insulated lid that fits on the top is about 8 inches thick and has enough weight to be a snug fit. It is also inside the cabin I built which also has some insulating properties.
Yes, it is a large electric draw but less than £50 per month from what we have seen on the meter. The money saved in turning it up and down is not worth the ease of being able to just hop in at a moments notice such as when I get back from pushing a trolley around a supermarket or finish a ride.
[i]All joking aside, are you using power tools more often? Doing any welding? It may not be a big single thing (but those are easy to check), it could be accumulation of other activities.[/i]
Just moved most of the tool feeds to remote control sockets so nothing is left on standby.
We are having that 'energy awareness' moment and looking where we can save but I still think £6,500 is more that 'a little high' even for an earth rapist with first world issues like me.
WCA - sounds like the sauna & hot tub are big contributors even if you do have a valid reason for them. Can you improve the insulation around the hot-tub?
I seem to remember you posting ages ago that your other half tends to have the heating on with most of the windows open? Or did I imagine that?
EDIT - cross posts - perhaps improving insulation would only be marginal gains....?
We do have a cheapy 'clip in line' readout of energy use. When we first got it I spent a (Frustrating for the family) couple of hours turning things on and off with it in my hand. We can set it to the exact standing charge and PpU we are paying - and so see when someone fires up the kettle or tumble drier.
IMO, each of the kids computers + monitors that seem to be on 12 hours a day use as much as a tumble drier load per day.
IIRC, I also worked out we had an old Sony DVD player that on standby *ate* energy....
This could easily explain a one-off high bill.
Can you take the cover off and put on a piece of glass when the sun’s out?
Probably a very good way of getting a hot tub full of green gunk...
[cougar mode]I can think of more exciting ways to fill the tub with gunk[/cougar mode]
Eurgh.
Are these plug-in energy monitoring things much or a muchness, or is there any particular one or system that's better than others? e.g. for analysis of usage etc.
Hot Tub?
So I was correct that the only way you could be using so much electricity was because you were using it for "heating".
Only because we're at £100pcm for a electricity - we both work from home plus pay no real attention to power usage, but my Mum who has electricity-based heating (in our non-connected annex) and can easy use £100pw.
clip in line’ readout of energy use - can you recommend one?
I'd be interested in how much power our various units are using.
Or washing machine is old and only costs about 38p per wash
Are these plug-in energy monitoring things much or a muchness, or is there any particular one or system that’s better than others? e.g. for analysis of usage etc.
Mine is black and white, records hourly use and just keeps a 24hr memory. It then gives me average daily, weekly and monthly use. It is not clever in any way or fancy pants. £5 second hand.
But, after a couple of hours of turning devices on and off and noting their energy use, I have an idea of what is 'bad' in our house. For example: the boiler uses a *lot* of electricity, tumble drier (obvs), oven and the slow, insidious and all day use of gaming PC or PlayStations. I also replaced our (very old) fridge and halved the annual bill.
Does anyone unplug their router at night?
No because I can't be arsed to go through the boot up and reconnection each morning. That said out of interest I will put the energy monitor on it and see how much it uses. I am guessing, in the scheme of things, not much at all...
My BT Smarthub 2 has a rating of 0.04 W when not in use. I certainly don't switch it off. Nest Hubs use about 3 W (set up as photoframes) and I've two of those.
This is the new version of mine:
https://efergy.com/elite-classic/
Mine looks much older:
It was from local FB group second hand - TBF, once you have used it once it is all you need.
Nope, i went through this whole energy consumption testing thing a few years ago, the total consumption of the entire mesh network set up (3 routers, wired backhaul) would be about a 2 quid a month now.
I've also got smart WiFi switches on some of the really heavy users (TV, Amp, Playstation, Stereo and most of the house holdlights (indoors and out) so leaving the WiFi on means i can switch everything else on and off. Especially important with kids in the house.
That can be a bad thing for your router speed. Some ADSL feeds work on the basis that they speed up until the router can't handle the speed without too many errors, then slow to a bit below that. If you unplug it, the ISP thinks it can't cope, and slows the transmission rate down.
No, the disruption would be significant in our house. The router and modem use about 20W which is not trivial but it's not a lot.
Hot tub, sauna and Tesla while moaning about energy bills. Is this another bot threat designed to rule the forum 😂😂😂
Next we have Rishi S sign up to ask how to cut costs on heating his outdoor pool during winter.
Thanks folks for answering my q.
Is not something that should even be said in jest at the moment really, but everyone to their own. We all (including me) have good reasons for our particular excesses
I know people who do because they feel more comfortable without the radiation. I'm not a believer but it makes them sleep better so why not. Just put the thing on a timer so it has time to reboot before you get up and all is good. You might even find it works better as a lot of these things do a sort of optimisation sequence at startup such as work out how to compensate for your telephone line and the quietest frequency bands to use.
Another data point here. With a 2 adult household in a 3 bed semi our Octopus electricity for January was 366Kwh costing £65. Probably more like £100 post the April rise.
To get £500 a month is big usage. I would tend to take the maker's low usage claims for the hot tub/sauna with a large pinch of salt. Even if you want to avoid having to warm them up powering off overnight and having them on a timer to warm up at some point during the day would save money.
I agree about the advert possible overstating the efficiency but when it was unplugged for a weekend it only lost a couple of degrees of heat. Unfortunately it is hardwired into a high capacity circuit with just an on/off twist switch so cannot fit a timer to it. It does have an 'eco' mode which lets the temperature drop for certain periods and re-heats for the time you know you want it. I only found this out today so will see what I can do with that but a 10 minute hot tub in the morning before work is really nice and then a longer soak in the evening before the sauna makes it hard to decide when to drop the temp. I guess we don't do as much midnight skinny dipping now so I could drop the temp between 9pm and 6am and se if that helps.
Amazing how much stuff I never noticed was plugged in and just sat there. Todays wander around the estate has been an eye opener.
I wasn’t WCA, hence I humbly apologise for my comments.
Blimey, We are dirty people reading this! Bedding gets washed once a week and towels every 2 or 3 weeks as they dry properly and only ever get used on clean bodies!
[i]I wasn’t WCA, hence I humbly apologise for my comments.[/i]
No worries Kryton 🙂
I spend so much time on here bragging about how wonderful my life is and asking how to make and do things I forget to mention the shit bits. No reason for you to know of them.
<em class="bbcode-em">Doing any welding? It may not be a big single thing (but those are easy to check), it could be accumulation of other activities.
A welder can use a metric shit ton of electric in a few minutes. If you've got a surprise spike in you costs (and its not down to some anomaly with meter readings) then that might well be your culprit My workshop is at a friends place on its own meter but its on their account and they bill the costs on to me as required. Typically - doing generally woodworking for a quarter the usage is so low its not even worth her billing me - but any time I've been using the welder or the plasma cutter, even if it seems like I've not used them a lot, its about £400 - £500.
I would suggest you read WCAs explanation as to the reasons for the hot tub etc and another forumite's subsequent apology for a similar comment to yours before posting bollocks like this.
FWIW, the place my ex moved into had a hot tub, and just chugging along keeping it at 10-15 degrees so everything worked properly, like the pumps, filters and various potions that had to be added (she's not a hot tub person) was costing her about 40 quid a month (and our leccy is a shit load cheaper than yours, even now).
The mate who she sold it to spends about £180-200 a month keeping it warm enough to use with ninety minutes notice. Gets used (almost) every day, as his inlaws live at the bottom of the hill, and his wife's uncle lives in the next farm...
Same here. Bedding and towels get done every couple of weeks-ish, and all at the same time as the white towels and white bottom sheet from the bed go in together on a 60deg wash. Every other wash we do is 30deg (and we do about two loads a week, depending on how much dirty sport kit has been generated)
For those that work at home and have a dryer - ours broke in January and while I was looking for a new one we put the washing on an airer next to the rad which is always on when the heating is on. I thought I’d give it a try as we had to have the heating on anyway while at home.
It’s been 3 months now and we haven’t had any need for the dryer again. As soon as the weather was good enough we put it out on the washing line which is nicer for the towels. We have found that the washing can get washed and dried during the working hours - every time I take a screen break I will fold up the dry stuff and rotate stuff around and generally by 5pm it’s all dry and done - I put the washing machine on to finish at 8am.
Might not work as well with a big family but there once was a time when no one had dryers so surely there’s a big saving to be made there for some people.
No idea how much it’s saving but I’m trying ti reduce usage before our fixed price utilities deal ends in January 23.
FWIW we wash our bed sheets between once a week and once a fortnight depending on if they still feel fresh or not. Towels probably the same but I tend to throw one or two in at a time with the other washing rather than do all at the same time.
Top tip that - in summer hang washing on a washing line! Love it 😀
I know people who do because they feel more comfortable without the radiation. I’m not a believer but it makes them sleep better so why not. Just put the thing on a timer so it has time to reboot before you get up and all is good. You might even find it works better as a lot of these things do a sort of optimisation sequence at startup such as work out how to compensate for your telephone line and the quietest frequency bands to use.
Probably no use giving advice to people who are "uncomfortable with radiation", but as stated above turning your router off daily will likely have a deleterious effect on performance. If your ISPs automatic monitoring sees your connection dropping daily it will keep reducing speed to try and find a point at which the line is stable.
We do this, and for an extra drying boost I stick an old mattress protector over the whole lot, tucked down the back of the radiator. It really hot-boxes inside and dries stuff pretty quickly, in fact I can sometimes get a couple of loads done in a day if there's a decent amount of quick drying sports-type stuff. A big sheet would work just as well, I think the mattress protector holds a bit more heat in as it's slightly quilted.
Top tip that – in summer hang washing on a washing line! Love it 😀
I know you’re probably being sarcastic but I’ve noticed we used the dryer for a lot longer into the year as it’s just easier, whereas when you don’t have a dryer you’re looking for opportunities to get it drying outside rather than going for the easy option.
I’ve just worked out our dryer was probably using about 4-5kwh per load, and at 17p per KWH that’s about 85p a load. Three times a week is £2.56 and week or £10 a month, £120 a year. Not a gigantic amount if you’ve got a decent wage but I’m expecting electricity price to at least double for me in January so £20 a month saving is pretty decent.
Can you get an electricity monitor that will send a signal to an app to log usage?
I did this when we washed the sheets and was very surprised how fast everything dried, as fast and maybe faster than the drier.
I'm hoping the heating bills remain 'low' - house only gets heated to 18c and although we have a smart meter, we don't tend to use it apart from being able to hit a button on our phone to switch heating on (and it then switches off once the temp is up to 18c).
Washing is done once a week for clothes and there will be an extra wash every second week for towels.
I think the household stuff we are ok with i.e. not massively wasteful (cooker/hob gets used daily, fridge/freezer and washing machine. However, our household 'toys' probably are more wasteful than they could be - TV is off at the wall and only turned on when it is being used, but we have work computers switched on and plugged in all day; Smart speakers and smart display thing showing a photo album, they will all be drawing power. I also have wifi lights so these are on 24/7 and will also be drawing power.
Have to say though, house is feeling freezing but I'm wearing a t-shirt and I'm refusing to put the heating on (smart temperature thing suggests house is 15c) - I'll stick a jumper on and move about a bit.
The sheet over the airer trick is great but I do wonder where all the moisture actually goes - definitely a good idea to use a breathable sheet but I've often wondered if the sheet traps the moisture rather than letting it escape 'properly'. Now I'm typing this out, it sounds stupid!
I’ve often wondered if the sheet traps the moisture rather than letting it escape ‘properly’
It doesn't, it's fine (assuming it's not a plastic sheet 🙂 )
It does escape to the room though, obvs, so you should keep a window open
Yeah, as soon as I typed it out I realised it was me being thick!
Jumper now on as temp is now 12c apparently...I'll put the heating on boost just before lunch! Might also try and find my slippers that I got for a christmas present one year - the ones I vowed never to wear as I wasn't old enough for slippers!!!
Putting the plug in the bathroom sink and filling with hot water will heat your bathroom. Not alot but enough to be noticeable.
Wca needs to build some solar panels. 250mm C section perlins.
100mtr 10mm copper pipe
2mm polycarbonate sheeting
Matt deamon black spray paint
Solder
12mm celotex boards
Tiny pump
Crazy foam
Bag of push fit 90s
Spray perlins, solder pipes every 50mm apart. Crazy foam celotx onto back and sides, silicone polycarbonate onto front. Aim at sun.
