towing a small trai...
[Closed] towing a small trailer
9 Users
What's it like?
I used to have a fairly large tent-trailer and I hated it. I always felt like it would lift the back end of my car (a Volvo 740 estate) off the road, and constantly worried about simple manoeuvres like pulling in to a petrol station. (I probably should have got lessons from someone experienced.)
In any case, I now have a VW Caravelle T4, and think that a small trailer [url= http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_772577_langId_-1_categoryId_165519 ]like this one[/url] could be perfect for hauling my camping gear on a long trip.
Any thoughts? Is a small trailer like this easier than a substantially bigger one?
Posted : 07/05/2012 4:23 pm
I've always found when reversing, the bigger the trailer the better. Always helps to be able to see it
Posted : 07/05/2012 4:25 pm
Reversing with a small trailer is much harder than with a bigger (twin axle) trailer. Otherwise just remember it's there, you'll need to pull out and extra foot or so, so the trailer doesn't cut the corners. There shouldn't be a huge amount of weight so snaking shouldn't be a problem and you won't be going so fast that bouncing will be a problem, or will you?
Posted : 07/05/2012 4:27 pm
I promise I shall keep my speed at the limit or less.
Posted : 07/05/2012 4:29 pm
Pah! Just learn to take your foot off the accelerator, then floor it if the trailer does start snaking. 😉
Posted : 07/05/2012 4:37 pm
I have a little trailer that I can't see at all out of the back window
It's fine in normal driving but you look a right tit undoing it rather than reversing with it (suppose I could learn to do it through wing mirors but it's narrow too and only becomes visible at about 45 degrees)
Posted : 07/05/2012 4:54 pm
So, if I undo the thing to reverse, is it otherwise easy to drive with?
Posted : 07/05/2012 5:30 pm
They do bounce about a bit if unloaded or have a very light load on rough roads (see Sheffield).
Found that sticking a small flag on an old tent pole helps me when reversing as I can't see mine behind the ScoobyVelle. It also helps reduce your paranoia that it has parted company some miles back if you can see the flag waving to you.
Posted : 07/05/2012 6:13 pm
If you previous trailer felt like it was going to lift a Volvo estate off the ground you must have had it badly loaded. Slight bias towards the front, probably 50kg - 75kg max over your hitch would be about right.
As far as the small ones are concerned, they are a bit of a pain, especially when you can't see them in your mirrors. They are also much easier to jacknife the shorter the distance between the trailer wheels and the hitch.
Fiamma / Thule roof box?
Posted : 07/05/2012 7:03 pm
 Muke
It will be too small, its simply trailer law, you always need one bigger than the one you bought 😕 Bigger trailers tow better as well.
Lots of towing/trailer advice on [url= http://www.ukcampsite.co.uk/chatter/ ]http://www.ukcampsite.co.uk[/url]
Posted : 07/05/2012 7:18 pm
Bought a 5x3 trailer off the bay for £100. Wouldn't pay that kind of amount from halfrauds, just look a bit flimsy to me
Posted : 07/05/2012 7:21 pm
Always had trouble reversing my small trailer until I put a small flag on an old fibreglass ariel on it
Posted : 07/05/2012 8:03 pm
