Timing belt/chain r...
[Closed] Timing belt/chain replacement Focus 2.0 TDCI
5 Users
I have a 10 year old Ford Focus 2.0TDCI which is due its timing belt/chain replacement. I think but I am not sure that it is a timing chain. If it is a chain is it worth getting it replaced?
The car runs well and I see no reason at the moment why I would be getting rid of it. But it is only worth £2000 ish and therefore I am reluctant to fork out £500 on it. The likely hood is that within the next couple of years I will be looking for a replacement car anyway.
Any thoughts?
Posted : 09/03/2016 8:51 am
it should be a belt.
Not spending 500 quid could very well lead to you spending a few grand much sooner - and your focus being worth 50-100 quid.
the time based intervals on fords seems to be imagineered well ..... i took a belt off a 10 year old escort that had done 44k miles about 10 years ago .... it was in horrendous condition.
Also it should not be 500 quid for a timing belt , find an independant garage for a price. if your located in cults as per your moniker - try malcolm road motors in culter.
Posted : 09/03/2016 9:06 am
Agree with Trail Rat. If there is nothing else wrong with the car then spending money on a cambelt service is worth it. As stated above if it fails your car is worth scrap value.
If you change the car then you could end up with a lemon costing you more or at the very best you will lose a lot more than the cost of a cambelt change within the first year in depreciation.
Posted : 09/03/2016 9:23 am
When I got the timing belt done in my Focus I think it cost around £300, including a service. One of the advantages of the Focus is that the timing belt is quite easy to access, and therefore not too costly to replace.
Posted : 09/03/2016 10:08 am
Find an independent.
Had one done for £200 including water pump on a Mondeo. Ford independent specialist.
Posted : 09/03/2016 10:11 am
