Thinkpad has bricke...
[Closed] Thinkpad has bricked. pointers for diagnosis?
9 Users
thinkpad x240 running linux kubuntu.
showing no signs of problems til it shut down un-announced this morning.
restarted it once, 5 minutes later it shut down again.
now
showing no sings of life at all.
plugged in, unplugged, removed outer battery (there's an inner one too) replaced, nothing.
not even the usual flash you get to show its charging/ has power.
any suggestions where to start diagnosis?
thanks
Posted : 06/12/2020 10:18 am
 Aidy
Obvious, I know - but, you've checked the power brick?
Posted : 06/12/2020 11:29 am
its pretty much new, so honestly didnt question it. but i will.
just the sort of obvious pointer i was after, ill get the multimeter out, thanks : )
Posted : 06/12/2020 12:31 pm
Graceful shutdown or immediate off?
Do you use it a lot on carpet / soft furnishings / the cat? Smells a lot like thermal shutdown / fan failure to me, this.
its pretty much new
Send it back, then.
Posted : 06/12/2020 12:33 pm
Also,
I've had several hundred Thinkpads pass through my hands and have not seen a single PSU failure. If one were to fail, it wouldn't come back on again 5 minutes later. And in any case, y'know, battery. I think power brick is a highly unlikely cause here.
Posted : 06/12/2020 12:43 pm
If you bought it new then there is very often one year at home support.  Phone them, they are very good.  I buy mainly lenovo now for just this reason
If you really want to fix it yourself, and I wouldn't want to myself if it was under warranty, then I've had a couple of recent thinkpads go down in the last year with a problem with the connector to the hard drive (can't really call it a disk drive any more I guess.  One place I worked referred to is as bulk memory but I couldn't handle the acronym).   In both cases Lenovo came and replaced the cable (one was a friend of mine at home rather than a business machine).
Posted : 06/12/2020 12:49 pm
 Aidy
I absolutely agree - I'd be surprised if it was. But - worth ruling out? Yep.
Posted : 06/12/2020 1:27 pm
This is generally just a fix for a Thinkpad that won't power up at all but it might be worth a go. Underneath you should find a little hole you can stick a small paperclip or pin through to hold down a "reset" button (this is required because you can't easily disconnect the internal battery). Press this down for a few seconds then release.
Posted : 06/12/2020 1:45 pm
it's the power pack that's new (genuine lenovo) not the computer!
any possible problems if i press reset button?
Posted : 06/12/2020 4:18 pm
cougar, i use it exclusively on the table, the fancomes on only rarely, it doesn't 'seem' to get hot much, which doesn't rule out thermal shut down i guess...
Posted : 06/12/2020 4:24 pm
What "reset button" are you referring to?
Posted : 06/12/2020 4:54 pm
What “reset button” are you referring to?
The one I suggested I imagine and NO. We had a lot of this with later Lenovos at work. I don't know if they still do, I've retired.
Does it come on when you start up the laptop? If not then maybe the fan isn't working at all (fan catching on the casing - yes it's a thing - or full of fluff - or knackered).
Posted : 06/12/2020 5:04 pm
OK.
Remove the battery (the main one, leave the innards alone) and disconnect the power. Press and hold the power button for a few seconds. Reconnect the power, hit the power button again.
Does it still show "no signs of life"? Ie, absolutely nothing, there isn't anything you've failed to mention thus far, lights, noises etc?
Posted : 06/12/2020 5:28 pm
thanks for all the help everyone.
i tested the charger last nigh and seem to be getting no juice at the computer plug. (its arriving atthe brick just fine)
so im off to buy another new charger and hope that's the fix
Posted : 07/12/2020 12:18 pm
i had a thinkpad yoga nuke itself on me. main board power distrubution died at 3am in the morning, in the middle of a sea trials in the middle of the Mediterranean. more than a little inconvenient.
threw up a load of error messages, powered down, came back up for a few minutes and a whole load more error messages and then shut down for good. when i got back to the UK and gave it to the IT manager, he shrugged and said 'yeah, mine did that a few months ago', took the hard drive out and gave it to me to recover any files I wanted and gave me another laptop.
Posted : 07/12/2020 12:25 pm
so im off to buy another new charger and hope that’s the fix
Appreciate you probably need it working ASAP, but thats a warranty issue, surely?
Posted : 07/12/2020 12:56 pm
Last year when my daughter took her laptop but not the charger on holiday, Amazon prime got a compatible one to us on Anglesey twelve hours later. If it turns out not to be the problem, returns are easy.
Posted : 07/12/2020 1:48 pm
Or I suppose you'll then have a spare one if they are dodgy power bricks
Posted : 07/12/2020 3:01 pm
pin out for the square type power plug here.
voltage - Lenovo Trim Yellow rectangular power adapter - Super User
Posted : 07/12/2020 3:10 pm
Thinkpad x240s are ancient so unlikely.
Posted : 07/12/2020 3:15 pm
thank you jam-bo. better go and re check the power supply!...
Posted : 07/12/2020 5:54 pm
ok, latest update:
I've checked the power supply properly this time (thanks jam-bo!). it's giving 20V as intended.
I've removed the battery, keeping plugged-in, and held down the power button.
and i've found the reset pin hole and given it a longish press, plugged in and no battery.
none of these has had any effect. the thing is still a door stop, showing no signs, not even that it has mains power ( flashing red LED normally).
so what would be my next course of action? I'm fine with getting it apart.
Posted : 08/12/2020 4:18 pm
little bump as i could do with a bit more help.
but im thinking take it apart and, starting with power board, check for visible damaged circuitry. and clean out any guff obviously. sound about right?
Posted : 11/12/2020 10:06 am
Point of note,
I don't know specifically about the X-series, but I've worked on a lot of T-series and all the service manuals were freely available in the Support Downloads section of Lenovo's website.
Posted : 11/12/2020 12:12 pm
thank you cougar. nice of you : )
Posted : 11/12/2020 8:53 pm
