Theory test - Any a...
[Closed] Theory test - Any advice?
11 Users
Got my driving theory test tomorrow, is there anything i should be looking out for in particular?
Posted : 08/03/2010 8:18 pm
If you've revised, its not hard. In my opinion (did mine in Feb)
Posted : 08/03/2010 8:26 pm
It's really really really easy!
Posted : 08/03/2010 8:36 pm
I flicked through the Highway Code on my way to the test. Passed first time.
There are some questions that aren't "common sense", but otherwise it's straightforward.
Posted : 08/03/2010 8:45 pm
I passed even when totally hungover, you'll be fine.
Posted : 08/03/2010 9:10 pm
A, A, D, F, B, C, C, A, E
little girl on the left
lorry pulling out
128m
Posted : 08/03/2010 9:19 pm
Thanks for the reassurance, sounds like it should be ok!
Posted : 08/03/2010 10:27 pm
 Ewan
On the awareness thing, click the first time you see the danger and then click again at the last moment it'd be safe to avoid it. That way you'll def get the points (you can be a bit early if you're alert!). Worked for me.
Posted : 08/03/2010 11:01 pm
Read the book, apply some common sense, accept that if you get any questions about trams you'll get them wrong- sorted.
Posted : 08/03/2010 11:43 pm
Posted : 09/03/2010 2:37 am
just click loads & loads at anything and everything on the Hazard perception. One or 2 clicks here n there won't do it.
Posted : 09/03/2010 12:18 pm
Got to be careful on clicking lots as it recognises that you are clicking regularly and guessing and can give you a big fat 0!!
Posted : 09/03/2010 1:45 pm
 Olly
if you fail congratulate yourself on being really really rubbish and give up your driving career before it ends in tears.
its REALLY easy, you have to be properly miles away to fail.
good luck!
Posted : 09/03/2010 2:16 pm
Olly that's what I thought but didn't want to write that in case he did! I got 100% in mine and had finished it in 12 minutes .. don't they give you 40 minutes!!
So did you pass OP????
Posted : 09/03/2010 3:25 pm
Passed! That was easy..
Posted : 09/03/2010 9:16 pm
