The electric car *c...
The electric car *charging* thread
100 Users
193 Reactions
 bruk
We have had a pod point home charger for a couple of years now and works seamlessly with Octopus and the Tesla once all the set up has been done.
Had a couple of issues over that time when the car lost the ability to know where it was so wouldn’t charge because it didn’t know it was at home! Great fun in the morning!
Looking at possibly going electric with a second car and need to work out best way of charging them both. In winter do need to charge the Tesla every day as it does a reasonable number of miles.
Can the average house have 2 chargers installed so both can be charged overnight?
Posted : 15/05/2024 12:17 am
Typical house single phase supply limit is 100A.
you should be able to charge 2 cars simultaneously as the draw should be no more than 56A to 61A depending on your voltage (250 VAC to 230 VAC).
Some older houses have 60A supply fuses.
check with your electrician. You may need to have more ‘spare’ capacity than 40A and thus need to constrain the current for the chargers.
Posted : 15/05/2024 6:46 am
IHN and IHN reacted
Someone on a previous page mentioned that it’s possible to register with tesla as a non owner, which gets use of some of the supercharger network.
Can anyone direct me to which tesla app I would need for that??
I’m on ios.
Tia
Posted : 15/05/2024 7:05 am
 DrP
I think it's literally the 'tesla' app....
I've got it (polestar owner) and have used chargers without issue, once card details put in.
DrP
Posted : 15/05/2024 8:03 am
A related but random question.
Is there any way of finding out the size/strength of the electrical supply to a property? We're pretty remote, and had a passing comment from an electrician once that our supply probably wouldn't handle having a car charger fitted and I'd like to confirm that if I can.
I know for the telephone lines there's an Openreach tool that will give the maximum broadband speed available to a given property, is there anything similar for electricity supply?
Posted : 15/05/2024 9:24 am
https://apps.apple.com/gb/app/tesla/id582007913
You need to create an account and add a payment card to it (suggest a credit card as they do pre-auth). Then a section called “Charge your EV” will appear. Through that you can find open Superchargers and start/stop charging sessions.
Some newer Tesla Superchargers have contactless but the app is usable at all of them that are open.
Posted : 15/05/2024 9:25 am
 mert
Mines listed on the bill (page 3, in the corner, tiny font).
Posted : 15/05/2024 9:29 am
couldn’t find it on my octopus multi-page bill.
1. look at the rating of your supply fuse before the tails to the consumer unit(s). It’d be weird if this had a higher rating than the supply could provide
2. call your electricity network provider (not your supplier) find who they are from your bill or https://www.ukpowernetworks.co.uk/who-is-my-electricity-supplier-and-what-is-my-mpan
Posted : 16/05/2024 7:13 am
 DrJ
Ours was not marked on the outside but of course when the charging point was fitted the installer took the lid off to reveal 60A fuse. The DNO came to check the installation (mandatory; in fact they should have done it first) and upgraded the fuse to 80A
Posted : 16/05/2024 8:58 am
I'm also one that had an old unmarked 60a cut out fuse, when the smart meter was installed the DNO (Northern Powergrid) came out beforehand and upgraded my cut out to 80a FoC. I've heard/read from a few sources that an 80a cut out is up to 100a capable.
Posted : 16/05/2024 9:49 am
Right, checked that, it's 100A. The sparky that raised the issue in the first place said something about a "shared supply with next door", is that a thing? If so, am I right that there's 100A from the pole shared between two properties, and because theoretically either could pull the whole lot each needs a 100A fuse? If I'm right, how does that affect us and/or them getting a car charger fitted?
Posted : 16/05/2024 10:11 am
It seems that the ohme home pro charger now supports charging your car from solar panels.
A new option has appeared today under the 'my charger' section of the app where you can enable or disable solar charging.
Thought some people might be interested
Posted : 16/05/2024 8:25 pm
A new option has appeared today under the ‘my charger’ section of the app where you can enable or disable solar charging
I have a ‘dumb’ charger from years ago. I was  pleased when Tesla updated the software a while back to make it possible to set a ‘charge from any source’ limit and a ‘charge from solar’ limit using the Tesla gateway for our solar + power wall system
as there has been sunshine for the past few weeks all our driving has been solar powered.
Posted : 16/05/2024 8:31 pm
it’s 100A
your question gets into some challenging territory related to peak and typical loads.
Given how safety conscious folks usually are I would be surprised if you and your neighbour each have 100A supply fuses that the joint supply would be incapable of supplying at least 200A. However, the definitive answer will come from your network provider.
and you can always charge an EV with <30A
Posted : 16/05/2024 8:37 pm
Somebody with experience please re-assure me...
Big road trip from the North of England to Carnac, Brittany, starting this Thursday. I've been pretty relaxed about the charging situation, UK I'm fine with and when we've travelled in France the last few years (ICE) the charging infrastructure looks fantastic on the main routes, lots of chargers, available, and not busy! (this has improved dramatically over the last 2-3 years.) However, I assume that the for the most part debit/credit card will be fine in France, or will I need 6 separate apps?
I've got an RFID card through Hyundai which works well and indicates on the Hyundai charge app map it will be accepted at tonnes of charge points / different brands en route, but just wondering if you can just pay and go like most of the UK m/way chargers?
TIA.
Edit: thinking of registering with Tesla as an additional option.
Posted : 20/05/2024 11:30 am
When I've checked the Hyundai app it looks crap. Most places I know of are missing.
Electroverse has far more coverage.
Posted : 20/05/2024 12:12 pm
The sparky that raised the issue in the first place said something about a “shared supply with next door”, is that a thing?
Yes. When I had my charger fitted a DNO guy came with cable detector and checked that my supply cables go to the road, and thus I'm not on a loop. The point is that the peak load that a cable can carry is not the same as the sustained load. A few minutes peak load will start heating the cable, but it won't get to an unsafe temperature unless the load continues, which it does with a car charger. That's also why using a 13A socket to routinely charge a car may be an issue. There's an assumption, for a shared loop, that both users won't put sustained heavy load on at the same time.
Posted : 20/05/2024 12:25 pm
I’m in the early stages of looking into an electric car and my interest was piqued by the link on the car thread to the cheap Nissan Leafs (leaves?).  I think I need to understand charging first, I was looking at some chargers in Dunbar where a woman was hitting the machine! After a brief conversation she advised me not to go electric as the faster chargers are often faulty, I was also surprised that there were two different plugs, is it like VHS and Betamax and one will come out on top? Also, reviews on the Leaf say it’s unsuitable for faster charging, what rate do I need to look for? Any car we buy will have to last and be as future proof as possible. We can’t afford expensive so a leaf at £15,000 or something second hand will be our aim. Any charging advice to add to the advice already given would be welcome!
Posted : 21/05/2024 9:30 pm
Fast chargers can be faulty.  It's usually the older devices; they are improving a lot.
There are two types of rapid charging connection - CCS which is like VHS and CHAdeMO which is like Betamax.  There were only a few Japanese cars with CHAdeMO - the Leaf being the most significant one - but even Nissan have moved to CCS. That said, there are still a great many CHAdeMO chargers out there, and only a few new chargers are CCS-only.  This is for rapid charging when out and about - home 7kW charging uses a different connector, and all cars have had the same type 2 connector for many years.  A CHAdeMO to CCS adapter is now available but it costs a grand; that said the new Leaf deals are so cheap that you would still come out ahead.
The Leaf itself is a decent city car but I would not recommend it for long trips.  It is perfectly feasible (especially if you get a 62kWh model) but other cars are better.  Leafs do not have battery cooling, so they can get hot if you drive a long way leading you to have to slow down; they could in theory degrade the battery a bit faster but this does not seem to be an issue since the current facelift 40/62kWh models.
Older cars all have slower rapid charging rates generally.  Leafs are about 45kWh peak, and they slow down; this is about the same for my Ioniq Electric (not the Ioniq 5/6 which charges extremely fast).  That said, it needn't be a huge issue - we are about to drive to Scotland next week and the charging planner is giving us 5 stops of 15-25 mins each, to give just over 2hrs of charging and 9hrs of driving - and that's in one of the slowest charging cars around.  I plan to do fewer longer stops to match with meal times and I don't think we will be much more than an hour later than if we were driving diesel.
If I were buying, I would absolutely get a used Hyundai/Kia over a new Leaf (and I did).  There are 64kWh Konas around for £12k with 250 miles of range, and with Hyundai you actually get close to that range reliably (unlike Nissan) even in winter provided you have a heat pump - not all Konas do but all Ioniq 38kWhs do I think.  They do bong and bing a lot when you set off though, but not so much whilst driving. They are also CCS.
Posted : 22/05/2024 8:07 am
@molgrips thank you so much for taking the time to write such an in depth reply. It’s very helpful. Have a great holiday in Scotland.
Posted : 22/05/2024 8:29 am
@stingmered Ionity are app/web but your Hyundai card should work. Total have rolled out lots in the autoroute aires, they take card although generally in France most seem to take the roaming cards (Shell/Newmotion, Electroverse, and ones like the Hyundai card). Getting the Tesla app set up just for another option isn't a bad idea.
@wheelsonfire1 it's fair to say that CCS has "won" in Europe but there's absolutely loads of Leafs and other CHAdeMO cars out there, and thus chargers that support it are still being rolled out and maintained. There are a few sites around that are CCS-only but almost all have some CHAdeMO, and a majority have it on each charger still. I've had no issues travelling around the country and we're driving from London down to near Poitiers this weekend for holiday.
Easy to get a 59/62kwh Leaf for that money, assuming you charge at home you don't need to worry about chargers for any <180 mile round trip and you have the flexibility with range to plan around better sites with lots of chargers. The bigger battery seems to be lasting really well, and isn't as prone to overheating like the 40kwh ones do. It's a robust and well understood platform, the simplicity of an air cooled battery means it's reliable, not much ever goes wrong with them.
I like mine, now that there's a viable CHAdeMO to CCS converter (it's about £1000) there's less need to worry about public charging in the longer term.
Posted : 22/05/2024 10:08 am
@simon_g thank you for the help, have a great trip!
Posted : 22/05/2024 7:50 pm
vive le France. 220kw charging off a 330kw charger, literally in the middle of nowhere. 0.3eur/kw! IMG_0735
Posted : 24/05/2024 9:19 am
retrorick and retrorick reacted
@stingmered - I've done trips to France Belgium and Spain with my EV and have found the chargemap card to be useful alongside my more frequently used Hyundai card. App has issues as with all of them especially via carplay
Posted : 24/05/2024 9:28 am
It's La France, but otherwise good post 🙂
I'm hoping my trip goes as smoothly. I wonder what effect bank holiday traffic will have on my efficiency...
Posted : 24/05/2024 10:16 am
I know I'm very much an outlier here but I've had my EV since Dec '22 and am now charging pretty much exclusively on a granny charger at home.
It's a Megane with a 60kw battery. I used to get free charging at work but that changed a couple of months ago and it's 30p a kw now so obviously home's cheaper. I had a second hand Renault 3 pin cable that stopped working last week so I bought the cheapest similar thing on Amazon and I'm amazed - it's drawing current at 13a now from the (upgraded) socket in the garage and overnight charging used to do 31kw in 16hrs, I did 34kw last night in 12hrs 50 mins. Big difference for a hundred quid. I've been checking to make sure the plug, socket and cable haven't been getting warm and all good so far. A recommended 'upgrade'.
I know a dedicated chargepoint would be better again but this works well for me for my usual 40 or so miles a day.
Posted : 24/05/2024 10:29 am
I've had an id3 for 3 years now and have only used public chargers due to living in a terrace house that doesn't have dedicated parking.
I'm in a very slow conversation with the local council about allowing me to fit a cable channel across the pavement (something like a kerbocharge.com) outside our front door to allow granny charging from a socket in our hallway.
We can park outside our front door 99% of the time and have a very good relationship with our neighbours. We know we have no rights to park there but it generally isn't a problem.
Anyone else in a similar situation and and tips for making progress?
Posted : 24/05/2024 10:39 am
 Ewan
"It’s a Megane with a 60kw battery. I used to get free charging at work but that changed a couple of months ago and it’s 30p a kw now so obviously home’s cheaper. I had a second hand Renault 3 pin cable that stopped working last week so I bought the cheapest similar thing on Amazon and I’m amazed – it’s drawing current at 13a now from the (upgraded) socket in the garage and overnight charging used to do 31kw in 16hrs, I did 34kw last night in 12hrs 50 mins. Big difference for a hundred quid. I’ve been checking to make sure the plug, socket and cable haven’t been getting warm and all good so far. A recommended ‘upgrade’.
We're the same. Rarely do enough miles to justify installing a proper charger. Could you share the link to the amazon charger - I think our MG one is only 10A? The garage was recently rewired to support high drain power tools, so shouldn't be a problem to run a 13A one.
Posted : 24/05/2024 11:30 am
If I were buying now I probably would not get a dedicated charger - I mean they're good, but for me now it's not worth £1k.  Mine was £400 I was one of the last people to get the subsidy.  If you can spare the money though go for it.
Posted : 24/05/2024 11:37 am
I'm on a granny charger for a year now but have downrated it to 10A after melting a few plugs and sockets. That means fewer miles per night but it's still enough for our normal use. We have economy 7, no smart meter yet, so something like 15kWh which is ~60 miles of charge per night.
Going for a 400 mile round trip on Sunday so will need a commercial charger, which will be the first time since last summer holiday. Is it worth hunting around for a good deal? I was assuming I'd just top up once or twice at whatever motorway services was convenient (would be stopping each way for a leg stretch anyway). Starting with a full battery should give me about 250 miles depending how fast we are on motorways, comfortably over 200 for sure which is the one-way trip length.
Posted : 24/05/2024 12:02 pm
I was assuming I’d just top up once or twice at whatever motorway services was convenient
This has always been my plan. Rapid chargers always seem to accept debit card so you just plug in and beep - or beep then plug in, depending on what it says. Bear in mind there are usually two card readers - one for your app or RFID card and one for your debit card - they have slightly different symbols. This confused me a few times.
You might save a couple of quid hunting for the cheapest chargers or signnng up, but for the occasional trip it's not worth it IMO.  On my trip next week I will be using Electroverse though, because I am an Octopus customer so I'm already signed up and I save 8%.
Posted : 24/05/2024 12:21 pm
Me, however I'm just using a cable protector channel ramp thing across the pavement. My situation is we are a row of 4 terraces, short residential back street dead end, front doors straight onto the pavement. the pavement is more weeds than pavement in the summer as only us residents and the post man use it.  I have an ally way behind a  locked gate next to my front door which the charger is mounted in. Even tho I've had EVs since 2019, I've only just started home charging (previous cars came with public  charging as part of the monthly fee). I was planning on installing a drainage channel across the pavement to feed the cable thru, but then read that you had to get council permission, so I'll just use the cable ramp. I'm planning on getting a longer 10-15meter type2 cable so I can still charge if someone parks directly outside my house and I want to charge, but hasn't happened yet in 4 months. Good luck with the council, I've decided not to go there, not to draw attention from the council. If they do come knocking, I'll cross that bridge if /when it occurs.
Posted : 24/05/2024 3:08 pm
@Ewan - the 3 pin charger I got from Amazon is this one, now showing at £125 less a 5% voucher. Still working OK here, added 39kw yesterday (car was down to 22%) in just over 15 hrs. Can't seem to link to Amazon at the moment but this is the charger if you use their search - EVDANCE EV Charger Type 2 UK 3 Pin 20ft/6.1m [6/8/10/13A]
https://www.amazon.co.uk/dp/B0CYSLGZ73
Posted : 28/05/2024 8:29 am
 Ewan
Great! Thanks
Posted : 28/05/2024 1:10 pm
That 30 cent charger in Stingmered's photo is IECharge, they're the cheapest in France but usually in the middle of nowhere.
https://iecharge.io/fr/iecharge-autocharge/
Posted : 09/06/2024 3:40 pm
IECharge, I assume there was some sort of kickback to the farmer who owns the land, it doesn’t make much sense for a location, but definitely worked for us.  As it happens it only took us about 10mims off route, there and back. But really did wonder where the hell we were going until I literally drove past it!
Posted : 09/06/2024 5:13 pm
So to charge an ev using Octopus Energy and a smart charger we have to get all our leccy via Octopus is it?
Posted : 13/08/2024 9:21 am
yes, your car charger uses your house electricity supply, so your house electricity supply has to come from octopus.
I found that my total electric costs are about £5 per month lower with the electric car on octopus , compared to before we had the electric car when we used shell energy. Mostly due to shifting washing machine and dishwasher to the cheap night rate, plus the whole house getting cheap electric whenever the car is charging .
Posted : 13/08/2024 11:20 am
Had my first long trip the other day, Cork in the south of Ireland to Stirling in Scotland, about 600km. Usually just charge at home and had never been on a motorway or used car fully loaded so was nervous about range and catching the ferry. Have to say the range hardly changed from my usual despite 4 adults/luggage and 125km/ph. The car could do the trip in 2 stops but I was nervous about range and wanted to arrive at my mums with a decent charge left to give me time to suss out the local charging options so I planned in 4 shorter stops using ionity as these are handy and cheapest for me.
first stop was more of a test stop to ensure app etc was all ok, got the last free spot out of the 4 bays for just a quick 70-80% top up but only charged at 35kwh? All was fine so headed off aiming for just south of Dublin. Got there and just1 of the 4 bays was in use and went 35-80% in the time it took us all to have a loo break and get a quick leg stretch. My third planned stop was just north of Dublin but when I got there it was full so I just carried on to Belfast as I was now more confident with range/app etc. I got to Belfast with 20% left and plugged it in to one of the 9 empty bays and went to grab a burger and when we got back to the car 40mins later it was at 100%. Popped on the ferry and got to my mums with 35%.
I normally do this trip with 1 stop in an ICE and costs about €60. This time it took an extra 30 mins and cost €50 on public chargers. Next time I will be more confident and happy to run the % down before charging as I found the car was way faster charging (as per charge curve) when I let it run down more so my plan of 4 short top ups took longer than 2 bigger charges, which is the plan for the return leg.
happy to my range anxiety is now gone.
Posted : 13/08/2024 12:31 pm
 5lab
heading off to rhodes for october half term, one of the rental options is a fiat 500e - it officially has 200 miles of range, but I'm guessing I might have to charge it a couple of times (if I have to give it back full).
could anyone take a quick look at the chargers there to help me figure out if any can just be used with a credit card/single app? there's a bunch of them on google but googling the name of the charger doesn't seem to give any info that I can make sense of
Posted : 02/09/2024 10:08 pm
There are half a dozen rapids and half a dozen fast in Rhodes according to Chargemap. They take the Chargemap RFID card (in theory, it often doesn't work IME) but other forms of payment aren't mentioned. They're run by PPC Mobility but their site blocks my computer. I suggest contacting the rental company and asking where and how to charge.
Posted : 03/09/2024 7:33 am
 5lab
thanks, that's also the confusion I'd got stuck with.
a bit more digging found incharge who seem to have a bunch of chargers on the island - might risk it..
https://www.nrgincharge.gr/en/xartis-fortiston
Posted : 03/09/2024 8:38 pm
Can anyone recommend an outside socket for a 3-pin plug granny charger with a rather thick cable (and the springy rubber ‘flex’ st the plug end)?
Posted : 03/09/2024 10:10 pm
I have some questions around smart tariffs for existing users, as I will hopefully be moving to a house where I can get a proper charger installed.
Intelligent Octopus Go looks like the default choice. Looks like it's 7p/kw.hr for 6 hrs each night, but what happens during the day if it schedules a charge - does the whole house switch to the 7p rate? I'm thinking it would be easy to "game" the system by ensuring you need to charge in the day - i.e. don't plug in at night, plug in at 9AM,and charge the car through the day, hey presto a 7p day rate. I can't imagine Octopus would let that happen - so is there some system to prevent it ?
Posted : 05/09/2024 8:26 am
Intelligent Octopus Go looks like the default choice. Looks like it’s 7p/kw.hr for 6 hrs each night, but what happens during the day if it schedules a charge – does the whole house switch to the 7p rate? I’m thinking it would be easy to “game” the system by ensuring you need to charge in the day – i.e. don’t plug in at night, plug in at 9AM,and charge the car through the day, hey presto a 7p day rate. I can’t imagine Octopus would let that happen – so is there some system to prevent it ?
Yes and no. You tell it how much you want added and by when, so you would plug it in at 9am and tell it you want eg. 75% added by 7pm. Octopus then decide when they want to deal that out to you, it's unlikely to start immediately, or be for the entire 9am to 7pm period. When it is charging you will get 7p rate for the whole house. I actually don't know what happens if you ask it todo that type of thing and Octopus don't think they have the excess capacity to give you cheap electricity during the day, but would presume the charger app would tell you what it can do. If you plug in at 9 am (or at anytime) and just hit the "Charge Now" you will always get charged full whack as you are not giving them any control.
Posted : 05/09/2024 9:21 am
 DrP
as above..
I've found that MOST of the time, once you plug the car in, it'll start charging but for like 15 minutes per hour.. (of course, at night it'll charge through the cheap hours).
The later in the day, the more likely it is to charge all the time.. so getting back from work at 1800 and plugging in, more often than not it'll start charging.
What's useful (for me) is that the polestar doesn't 'talk' to the charger, so the charger ALWAYS thinks the car is on zero %, so will 'force' a charge...
(i have the Ohme set to charge to 100% by 0700)
DrP
Posted : 05/09/2024 9:36 am
My new motor has a offer for a free Ohme charger or £900 electroverse credit, we already have pod point charger and are on the normal Go tariff (8.5p 12.30-5.30).
I'm not convinced I'd see the return on moving to Intelligent Go so I'm taking the £900 credit, it'll make 100% stress free for the next 3 years.
Posted : 05/09/2024 10:31 am
I'm diving into the electric car world shortly and wondering about charging. Currently with Octopus so imagine we will be moving to the overnight tariff - I can't see any reason not to? Wall chargers are expensive so won't be getting one until the old car is sold most likely. I'm assuming I can make do with the standard 3 pin plug for a while as the car won't do huge miles frequently (bit of a pain though as it only comes with the type 2 cable so I have to fork out for a 3 pin one!)
When it comes to wall chargers, what is good these days? Is it worth an intelligent one over a 'normal' one to be able to get on the intelligent go tariff?
I've been looking at public chargers as we will likely have to rely on those occasionally without a decent one at home, they all seem to be around 80p/kwh - is that normal ?
Posted : 05/09/2024 2:24 pm
Tesla open to public are usually under 50p
Posted : 05/09/2024 2:50 pm
When it comes to wall chargers, what is good these days? Is it worth an intelligent one over a ‘normal’ one to be able to get on the intelligent go tariff?
IMHO, yes get an intelligent one for future proofing as then you can access smart tariffs independent of what car is hooked up.
Posted : 05/09/2024 2:54 pm
I'm 3 pin charging my Ioniq at a leisurely rate of 1.5kwh. I don't do many regular miles but can do 25 miles a day when I use the car for a commute. Takes around 5 hours to recoup the range. Easily done over night. Octopus Agile tariff so I try to avoid anything higher than 15 pence KW. A fast AC home charger would be nice but I'll hold out for the time being as I can if needed use my partners charger.
Posted : 05/09/2024 3:17 pm
Not sure if its been mentioned on here but i read yesterday that a park & charge site in blackpool has finished installing 3 x 480kw chargers.  They accept that cars do not have this capability in the UK yet but if successful they plan to put in in about 6 other sites too.
Thats got to start being game changing if the car manufacturers up their game too
Posted : 05/09/2024 3:34 pm
Yes, but don't game the system. They know people are doing it, but they cannot afford to sell you most of your electricity at that price. If people take the piss then they'll have to stop doing it and we'll all lose out. It's a dick move.
Posted : 05/09/2024 4:35 pm
I guess that seeing as it will be visible in the data down to the user level that hopefully individuals would get a "please stop" notification or to before being shunted off the tariff unless a half-decent reason can be provided (night shift workers maybe?). At least I hope so otherwise as molgrips says everyone will ultimately lose out.
Posted : 05/09/2024 5:20 pm
I dunno if it'll change the game. The fastest cars now get 250kW which is absolutely fast enough. It'll take more engineering to boost that and be more expensive, so you'll see if customers are prepared to cough up big money to charge in 9  mins instead of 12.
Posted : 05/09/2024 6:44 pm
Hasnt that always the case with all things electric involving battery and charging technology.  Its extremely important to see the top end getting bigger/faster and those that use it do indeed pay extortionate amounts.  But as well, the trickle down effect is what used to be top of the line (250kw) technology becomes readily available and cheaper for the masses.
Posted : 06/09/2024 9:48 am
sniff and sniff reacted
As in like park and ride into town for visitors? Wrong use case/location for an uber fast-rapid charger then I'd suggest - those venues are perfect for the 11kw max most cars can charge at so 3-5 hrs (usually 22kw ac chargers).
The mega fast chargers need to be on arterial routes and more in outlying areas like west wales, cornwall devon that have seasonal peaks that create big queues if not >150kw.
Posted : 06/09/2024 9:59 am
Not got an EV but am toying with the idea, so doing a bit of research. One thing I hear a lot is that the public charging infrastructure isn’t there yet, making longer trips a nightmare. But I wonder whether there is really much evidence for this claim.
Yesterday I had to pick up my son just outside Aberdeen at rush hour. I had some time to kill so went to a location where there are two sets of high speed (350kw) chargers. Each location has 12 chargers but in the 30 minutes I was there no more than two were being used at any one time (so at least 20 free). Interestingly Zapmap always said that only one was in use, so that’s obviously not perfect.
Ok, Aberdeen is a bit far from civilisation, so I had a look on Zapmap just now to see what a drive to Norwich might be like. A few specific sites look busier than the others, but none seem to be full and there are loads of options for >100kw chargers on the route. Probably a different story on the Friday/Saturday before a summer holiday, but travelling then is a nightmare whatever type of car you are in.
Posted : 06/09/2024 10:47 am
I will be joining the EV brigade on the 25th of this month, have Ohme being installed as part of deal from car dealer.  Although I have been reviewing prices and I may use the public charging network upto 50khw I am finding some good prices using various apps 25p -39p and I understand Tesla chargers are around 50p.  Still cost effective compared to Petrol.
Posted : 06/09/2024 11:27 am
This may be useful to some:
https://www.google.com/maps/d/viewer?mid=1DOswN-GODssM2XmKV4oQ9r-mkGcbGno&ll=52.154601057615075%2C3.374081062500033&z=5
Its a maintained map of just larger(5+) hubs, something that is hard to find on the existing apps.  Avoids having to chance it on 2 chargers behind McDs.
Posted : 06/09/2024 12:27 pm
A lot of things said about EVs apply to the USA where the infrastructure is indeed absolutely shocking. Here though it's really pretty good in most places. The only place where I have to even think about it is going to North Wales on the A470, because it's a long way for my short range car and there really are very few en-route. But they're there. And I don't actually have to drive that way, I can go up the A49 which has many more chargers. And of course, I only need one charger somewhere on the way up and one on the way back because you don't have to wait til you're empty and charge to full. When I went up last time in the EV I needed a place to top up on the way out to get me back to Corwen or Oswestry area where I knew I'd be eating and charge up enough to get all the way home.
However this is a niche situation caused by being in Mid Wales. Everywhere else just drive, and stop when the car says to stop. Or when you want lunch etc.
Yeah Zap Map wasn't very accurate on our Scotland trip, the car's on-board system was spot on.
Posted : 06/09/2024 2:19 pm
I checked through the junk mail earlier and found a Charge Place Scotland headed envelope! Inside was a shiny CPS RFID card.
Posted : 08/09/2024 8:57 pm
 DrP
Those with an Ohme charger - it looks like they've updated the app/system so intelligent octopus go is no longer a beta mode..
Not that anything will change, but they have changed the app appearance...
DrP
Posted : 10/09/2024 10:04 am
Yeah I got an email from Ohme today - but it seems to be describing all the changes that came with v.2.0.0 of the app which was released two months ago?
Posted : 10/09/2024 10:41 am
zntrx and zntrx reacted
I was driving a plug-in hybrid on the Tour of Britain so my first foray into the world of actually charging the thing.
OK, I was very restricted in where I could go - specific hotels, a defined race route and so on, it wasn't a case of seeking a charge point and going to it. Thankfully the car ran on full petrol because it would have been completely unworkable to have a pure EV or something that "needed" a portion of charge to function.
I charged it twice (the hotels which actually had charging points, 2 out of 5) and had to download two separate apps, set up payment etc for each and work out which of the points were actually compatible.
I appreciate that it's a very specific usage - I didn't "know" the car (didn't even know what car I'd be getting until I actually picked it up at Race HQ) and I'd not prepared any advance info on charging points but I just found it all such a faff. It should not need a different app for each version of charge point, should not need the thought of "oh I can use this one but not that one".
I have a similar complaint about parking apps. I don't want a ****ing app, I want to pay some money. It's that simple. Or it bloody should be.
Posted : 10/09/2024 10:52 am
 DrP
OK, I was very restricted in where I could go – specific hotels, a defined race route and so on, it wasn’t a case of seeking a charge point and going to it.
Doesn't sound like an ideal use for 'full EV mode' in a hybrid with a limited range.
BTW, were there petrol stations on your limited route as well?
DrP
Posted : 10/09/2024 11:08 am
Petrol stations, no issues, the organisation had provided fuel cards and a list of stations en route / near hotels etc, that was no problem. The car I had would do about 350 miles on a tank running in petrol mode (and there was actually a proportion of the battery that'd self charge cos it would often switch itself to EV for low speed stuff even when the main battery had no charge).
But 350 miles was fine for driving from hotel to race start, doing the race distance and then driving to the next hotel with a stop en route to fill it up.
Could never stop at a charging station on a motorway though, we didn't have the time to sit there and wait an hour for a supercharger to top it up.
Finish race, sort everything, get to next hotel.
As I say, it's quite a specific use case! It's also why the majority of team cars are still full petrol or diesel estates. And it's getting increasingly difficult to get proper estate cars as everything evolves to SUV styling.
Posted : 10/09/2024 11:16 am
binman and binman reacted
 5lab
I'd disagree. The hyundais that are getting that sort of speed still take 20 minutes to do a 5-80% charge (approx 210 miles of range being added). That still means that there will, when busy, be queues at charging points and a delay in your journey. To get to the long journey convenience of ICE (where you just don't need to think, at all, about range and filling up, just stop when it gets towards empty) you need to be getting that time down to ~5 minutes, 480kw would get it to 10 mins, which for sure is a step in the right direction, but imo faster will help massively
Posted : 10/09/2024 11:19 am
I’d disagree. The hyundais that are getting that sort of speed still take 20 minutes to do a 5-80% charge (approx 210 miles of range being added). That still means that there will, when busy, be queues at charging points and a delay in your journey. To get to the long journey convenience of ICE (where you just don’t need to think, at all, about range and filling up, just stop when it gets towards empty) you need to be getting that time down to ~5 minutes, 480kw would get it to 10 mins, which for sure is a step in the right direction, but imo faster will help massively
I'd disagree with you....Done 45k around UK and europe in that type of car and anything above 150-175kw charging speed is absolutely fine for the user. Most of the time you're not going to 80% on an expensive charger, just enough e's to get you home to a cheaper charge. Even if you are, sometimes that speed is too quick by the time you've been to the loo and bought a sandwich, done.
The factor that needs addressing which you've confused with personal charging speed, is adding more rapid chargers to have the capacity as the number of cars on the road increases - in the way that petrol stations have been sized for the market demand. Increasing to 450kw is not practible as there would be very few locations in the country available where the in-ground supply can provide that.
Personally I'm more than happy as long as the future has plentiful rapid chargers at 150+, that work, that aren't stupidly expensive. One change I'd make is ensuring my next car has a really good battery pre-conditioning as having slow speeds in the winter is a pain.
Posted : 10/09/2024 11:47 am
Spiny and Spiny reacted
You just have to get your mind right.
My first trip in my EV (the day after I got it) was from Manchester to Leven - a 500 mile round trip. Started with 100%, charged at Abingdon on their new Gridserve chargers for 20 mins, went to my appointment in Leven, did  the same thing in reverse. Two 20 minute rest stops in 500 miles isn't unreasonable.
48 hours later - Manchester to Sidcup - 550 miles. Same deal - top up at a loo break on the way down, top up again with a late lunch on the way back. My previous car (320d) could do the round trip on a full tank, but only just. And I would need to fill it anyway rather than just plug it in when I got home.
Currently with Octopus so imagine we will be moving to the overnight tariff – I can’t see any reason not to?
Why wouldn't you? My usage for Sept so far is 156kW that cost £11.27. Saving £26 over standard tariff according to the Ohme app.
The car was better at finding empty chargers than Zapmap, the inaccuracy of the app undermines confidence.
It should not need a different app for each version of charge point, should not need the thought of “oh I can use this one but not that one”.
It doesn't. Just get an Octopus Electroverse card which covers all the charging networks that are worth using including lots that operate destination chargers at car parks and hotels.
Posted : 10/09/2024 1:22 pm
Ok so my work situation is becoming clearer - it’s Octopus EV 100% via salary sacrifice - choose a car and go.  What’s more the car I’m looking at - an I4 or Polestar 2 seems to be cheaper than the random lease sites I looked at - about £640 pre salary sacrifice.
So now what I need to know is others experience of wiring the charger from mid-house under the stairs to my (mains powered) garage 50m away without destroying the house or garden….
Posted : 10/09/2024 1:41 pm
A full month after I emailed chargeplecescotland about my non-functional account and their non-functional website, they eventually replied to me asking for full details of my account "due to GDPR rules".
Needless to say, I have heard nothing more from them in the fortnight since then.
Posted : 10/09/2024 1:57 pm
I contacted several installers and most wanted loads of images sent to them of my mains fuse, consumer unit etc and the route to where I wanted the charger sited and then quoted based on that. I went with the company that came back with the most sensible follow up questions based on what I had sent them in the end.
Posted : 10/09/2024 4:44 pm
@Kryton57 this sounds like a job for a local electrician who can visit and discuss options with you.  Underground, overground wombling free.
Posted : 10/09/2024 5:28 pm
But that's not much of a delay. You can deal with that.
But that's exactly what I do with my EV...
Some people really are a bit too precious.
The factor that needs addressing which you’ve confused with personal charging speed, is adding more rapid chargers to have the capacity as the number of cars on the road increases
I've probably said that 15 times on this thread 🙂 I didn't say you need 250kW, I said it's fast enough.
Posted : 10/09/2024 5:56 pm
A full month after I emailed chargeplecescotland about my non-functional account and their non-functional website, they eventually replied to me asking for full details of my account “due to GDPR rules”.
My CPS card turned up recently. I ordered one, the £12 payment didn't seem to be taken from my bank account, I thought I'd made a mistake somewhere along the way but it turned up anyway. It arrived in a hand written envelope so it seems that CPS are doing part of the process manually.
The card will be used soon.
My other half has misplaced the octoverse card which was going to be another backup card. I thought I'd ordered one myself but it seems not to be the case. Unless one arrives in the post soon I'll be reliant on the app assuming there's a signal.
I have a chargepoint card as well which will be my 3rd choice of card on route.
Posted : 10/09/2024 6:41 pm
Lots of chargers appear on the app and you can click 'start charge ' but it will never work because they are not app enabled. However you can call CPS and they start it remotely.
Posted : 10/09/2024 8:30 pm
The battery technology is starting to improve, with solid metal batteries starting to be introduced. That will mean full-charge ranges of between 500-700 miles. With my old diesel Skoda, a full tank gave me around 500 miles, the Insignia I had on loan gave me just under 900 miles from a single tank while I was mostly commuting to and from work over nearly a month and a half.
I don’t think it’s unreasonable to expect to be able to charge a car up once a month, and not keep needing to hunt for available charging stations if going away from the local chargers, like somewhere away from urban areas.
I’m not in the EV market, or ever really likely to be, unless something extraordinary happens to my finances, but, should the unlikely scenario happen, I wouldn’t be looking at anything with less than 500 miles/full charge; it’s bad enough now having to have a bunch of different apps in order to use a car park or parking meters, let alone doing the same to be able to charge a car, when I can just drive into any available filling station and fill my car in five minutes.
Posted : 11/09/2024 1:48 am
Or you can plug it in when you get home and never visit a filling station again. It happens while you sleep. For pennies.
Posted : 11/09/2024 7:06 am
Page 2 / 7
