Talk to me about......
[Closed] Talk to me about... coal bunkers
8 Users
Well, ethically sourced smokeless fuel bunkers in this case. Looking for something with a capacity of between 250 and 500kg but don't know whether there are any really good ones or any that are particularly shit. Is metal better than plastic, plastic better than metal. Does it not matter on fig?...
And any recommended purveyors of such receptacles?
Posted : 23/08/2021 4:14 pm
If you take two roofing slate pallet boxes(building sites burn them) take one apart and the strips of wood fit just nice in the gaps of the other, you end up with a big box basically, then screw a couple of gate hinges on and make a lid, two people can lift it about no problem.
Posted : 23/08/2021 8:56 pm
Coal would get absolutely soaked in a wooden box.
Posted : 23/08/2021 9:18 pm
Sounds like a nice way to spend an hour or 2. Now what's the coal going in .
Posted : 23/08/2021 9:40 pm
Galvanised ones are shit.
Posted : 23/08/2021 10:33 pm
Box/bunker..much the same thing surely?
Wooden coal bunker
Posted : 23/08/2021 10:39 pm
One at my parents is concrete block built with rubble infill rendered over to create a funnel towards the front hatch and takes 2-3t. Old shed roof on top of it.
No longer in use as replaced the multifuel range with a pellet one.
Posted : 23/08/2021 11:00 pm
I made one from leftovers of the shed build. Approx 1 metre cube. Frame from treated stud timber, covered with membrane then clapboard weatherproofing. Roof from some OSB plus a bit of reinforcing, with felt on. Full size door at front. Miniature shed, basically, although the roof is easily removable in easily order to load the thing right up to the top. Looks a fair amount like @espressoals post.
All our coal arrives in 20kg bags, so there's no load on the walls of the bunker.
Unsure if the wood is ethically grown or the felt was hand rolled by the virgins of Mount Olympus, you'd need to ask Wickes.
Posted : 24/08/2021 9:39 am
It has to be a pre-fabricated concrete one.
Posted : 24/08/2021 9:47 am
