Surely not beyond u...
[Closed] Surely not beyond us.....
12 Users
Why oh why can someone not make a hot chocolate drink that doesn't result in a big mess of choc choc in the bottom of your mug at the end?!?!
poor.
Posted : 25/10/2011 7:53 pm
I find using a fork to stir it helps
Posted : 25/10/2011 8:07 pm
You know you have to stir?
Posted : 25/10/2011 8:08 pm
User error. Add wet to dry, work from mixing plaster to mixing cakes to err, making hot chocolate.
Posted : 25/10/2011 8:10 pm
Handheld battery electric stirrer
Posted : 25/10/2011 8:23 pm
Add a little bit of water and stir until it's dissolved, then add the rest of the water - seems to do the job 😛
I want hot chocolate now...
Posted : 25/10/2011 8:28 pm
I do find that adding abit of water to the mug first, then choc, then water again helps as it stops it sticking to the bottom of the mug!
Posted : 25/10/2011 8:36 pm
 kevj
Same rules (generally) apply for gravy and cup o soups. If it is powdered, small amount of cold water mix to form a paste then add hot water to thicken. If it is granular, straight in with hot water and beat out the lumps.
Posted : 25/10/2011 8:41 pm
why can't you get granular hot chocolate? works for coffee...
Posted : 25/10/2011 8:53 pm
Spanish Hot Chocolate - that's the stuff of winners, none of this Options/Galaxy pish for us!
Try it if you're man enough: [url= http://www.spanishchocolate.co.uk/ ]http://www.spanishchocolate.co.uk/[/url]
Posted : 25/10/2011 9:06 pm
Cos of gravity.
Posted : 25/10/2011 10:00 pm
Stir with a spoon and pour at the same time !
Posted : 25/10/2011 10:04 pm
Chocolate con churros....
Mmmmmmm nyomnyomnyom.
Posted : 25/10/2011 10:08 pm
 rogg
Stoatsbrother - Member
Just make sure you put it back in her bag...
Posted : 25/10/2011 10:14 pm
Posted : 25/10/2011 10:16 pm
