Looking at sun creams the other day. On the front of the packaging there's the usual SPF ratings, and on the back there's a little circle with "UVA" and stars. So you can get for example something that's SPF30 with four stars, or SPF50 with three. What gives, which is best? How can something have a higher SPF rating but lower UVA protection?
Yours, baffled of East Lancs.
I bought some yesterday, its says:
"Advanced UVA + AVB protection with photostability"
So I think it helps me take pictures as well..
Star rating system[edit]In the UK and Ireland, the Boots star rating system is a proprietary in vitro method used to describe the ratio of UVA to UVB protection offered by sunscreen creams and sprays. Based on original work by Prof. Brian Diffey at Newcastle University, the Boots Company in Nottingham, UK, developed a standard method that has been adopted by most companies marketing these products in the UK. The logo and methodology of the test are licenced for a token fee to any manufacturer or brand of sunscreens that are sold in the Boots retail chain, provided the products to which the logo is applied perform to the standard claimed. Own Label products exclusively sold in other retailers are now excluded from the terms of the licence. It should not be confused with SPF, which is measured with reference to burning and UVB. One-star products provide the least ratio of UVA protection; five-star products are best. The method has recently been revised in the light of the Colipa UVA PF test, and with the new EU recommendations regarding UVA PF. The method still uses a spectrophotometer to measure absorption of UVA vs UVB; the difference stems from a requirement to pre-irradiate samples (where this was not previously required) to give a better indication of UVA protection, and of photostability when the product is used. With the current methodology, the lowest rating is three stars, the highest being five stars. In August 2007, the FDA put out for consultation the proposal that a version of this protocol be used to inform users of American product of the protection that it gives against UVA,[32] but after concern this would be too confusing this was not adopted.[27]
I reckon you copy & pasted that
To clarify - It's UV-B that does the burning of the skin, but UV-A causes other nasties and deeper tissue damage, so now they are adding stuff to help prevent UV-A damage.
The star system is a way of indicating how much it's geared up for UV-A or B.
Cut and paste - me? never 😉
I have the ginger gene big time, However i have never gone wrong with a good quality suncream.
Aslong as it has at least 3 stror is uva +UVB minimumof 15 max 20 (i do want a tan) and reapplie every hour.
Ah. So stars = UVA, SPF = UVB. Innnnteresting.
(I should've just googled that, in hindsight. Ta.)
[i]Aslong as it has at least 3 stror is uva +UVB minimumof 15 max 20 (i do want a tan) and reapplie every hour.[/i]
*Nods* yeah mm-hmm.
White PVA. Apply once for 100% protection. (and easy wipe-clean)
It looks like it's relative to UVB though? If so would that mean a 5-star UVA rating on an SPF-5 suncream is probably less effective (for UVA protection) than say a 4-star rating on an SPF-30 cream?
