Had some recent issues with a honda Izy and the drive.
I Thought that it just need a new belt (which ive replaced) but it seems that the drive will only propel one wheel. The drive sounds a bit noisy too..
Any ideas apart from take it to my LMS
Posted : 28/05/2019 4:32 pm
Worn gear cog wotsit on the end of the drive shaft.. new part ordered and should be a nice easy fix.
Posted : 29/05/2019 5:02 pm
Its meant to only propel one wheel isn't it. It does not have a differential, so if it propelled both you wouldn't get it to go round corners without slipping a wheel.
Posted : 29/05/2019 6:32 pm
It's definitely got drive to both back wheels... It currently is a pain to mow in straight line, won't mow uphill and makes a Grindy slippy noise on the offending wheel.. plus all the teeth are worn on the drive cog..
Posted : 29/05/2019 8:54 pm
