Stuff in the garage...
[Closed] Stuff in the garage (bowing to the knowledge of STW)
21 Users
 juan
What is that stuff:
1
This one as the word greenline written on it.
5
Once again I trust the forum on which all questions can be answered to live up to its high standard.
Posted : 11/02/2010 9:42 pm
1, PIPE THREADER
9 ,NUT SPLITTER
Posted : 11/02/2010 9:43 pm
 iolo
2. flywheel puller
Posted : 11/02/2010 9:45 pm
2 = superstar crank remover
2. Car Hub Puller
Posted : 11/02/2010 9:46 pm
2 puller of some description
{Damn too slow}
2 Bearing puller
4 Sheet metal hole punches
1 - pipe cutter?
2 - puller
3 - looks like an impact driver? yeah a punch!
4 - not sure
5 - nut splitter
2. Some sort of bearing or gear puller like [url= http://www.sourcingmap.com/threejaw-legs-gear-hub-bearing-puller-set-p-9950.html?currency=GBP ]this[/url]
Posted : 11/02/2010 9:47 pm
1) Die holder for cutting threads
2) 3 legged puller for bearing removal
3) Looks like a leather punch
4) Sheet metal punch
5) Nut Splitter
Posted : 11/02/2010 9:48 pm
Instruments of anal torture.
what's a nut splitter?
Posted : 11/02/2010 9:51 pm
bakes - Member
Is that a wise question on here? 😯
Posted : 11/02/2010 9:53 pm
Flashheart has already told you.............pay attention ffs
 juan
Thanks everyone.
It gives me some key word, so I can look up in google and try to price them.
For the n°1,the two grey nobs on each side of the stick kinda fix the pattern in the main hole (the pattern can rotate in the hole).
Cheers anyway
Posted : 11/02/2010 9:57 pm
Agree with above, die wrench, gear/anything puller, flareing tool?, sheet metal hole cutters, nut splitter
Posted : 11/02/2010 9:59 pm
CaptainFlashheart - Member
During a house renovation once, I politely enquired what one of these was for, to be advised the very same. 😆
Posted : 11/02/2010 10:02 pm
Juan, the sheet metal punches are commonly called Q max punches and cost a fortune for good ones.
Posted : 11/02/2010 10:03 pm
no 4 is a tool box relatively new invention used for storing tools in one place so you can find them easily 😉
Posted : 11/02/2010 10:07 pm
Nut Splitter, you place the yoke of the splitter over the seized/stuck nut,and then tighten the nut on the treaded bar,the arrow head then slowly splits the seized nut, and doesnt damage the thread.
Posted : 11/02/2010 10:21 pm
1. reversible holder/ratchet for pipe threading, the dies are held in a hexagonal carrier. (probably made by RIGID)
2. 3 leg self aligning puller (for bearings/sprockets etc)
3. Its called a Wad punch set (punch holes in leather/plastic or rubber)
4. Sheet metal hole punch set (drill hole to bolt size, assemble unit either side of hole & tighten till the two parts pull through creating a neat hole to the size selected)
5. Nut splitter (medium size shown)
I have all those and lots more in the workshop 🙂
BTW the Facom pullers are top quality.
Posted : 11/02/2010 10:44 pm
As others have said but I got 4 out of 5
Thought 3 was an impact driver
Posted : 11/02/2010 10:51 pm
 juan
Wow once again, STW did not let me down. Is there one thing this forum cnat do 😉
Posted : 12/02/2010 11:11 am
have a thread about tools that doesn't descend into comments about inserting them up bottoms?
Posted : 12/02/2010 11:14 am
Mt Overshoot is spot on.
Posted : 12/02/2010 11:22 am
Facom stuff is brilliant. I, err, borrowed a Facom Ratchet from work 15 years ago. Still got it. Brilliant kit. Are they not nearly a French Snap-on equivilent?
Posted : 12/02/2010 11:27 am
JonEdwards - Member
I ought to be its how I earn a living.
PeterPoddy - Member
Yes its very well made stuff and a huge range [url= http://www.facom-tools.co.uk/ ]Have a look[/url]IIRC they also own Britool & Sykes Pickavant
Posted : 12/02/2010 1:36 pm
