Stripping paint fro...
[Closed] Stripping paint from front door...
5 Users
...what do I need to know 😊
Years of paint at least one coat from us.
I’ve got a gas canister burner and have tested a patch, comes off nice and easily.
Before I kill myself with inhaling fumes as I’ve no idea how old the paint is underneath ( lead paint !?!?)
Is it safe ? well ventilated as it’s outside, do I need a mask ??
Once door is stripped
Sand the door
Undercoat
Paint colour of choice
Thanks in advance
Posted : 15/05/2019 7:05 pm
Afair, lead paint won't fume until over 600f? ish. So a hot air gun on a low setting outside would probably be okay. You should probably get a cartridge filter mask with a an organic vapour cartridge if you want to use heat, even if you are outside.
Better still use an environmentally friendly stripper with a N100 particukate mask.
Posted : 15/05/2019 7:52 pm
Why strip sound paint?
Posted : 15/05/2019 7:59 pm
Needs stripping as it has about 80yrs of paint and no way to get a nice finish on the door.
Posted : 15/05/2019 8:57 pm
I redo ours every few years. It was custom made from Pine and the knots are a PITA, knot sealer does bugger all and the sun cooks it and the oil lifts the paint.
So last year I stripped it with a hot air gun, then drilled out every single knot and filled the hole with two part expoxy and put knot sealer over that...
[url= https://live.staticflickr.com/65535/46944958955_96c722b9b6.jp g" target="_blank">https://live.staticflickr.com/65535/46944958955_96c722b9b6.jp g"/> [/img][/url][url= https://flic.kr/p/2ewnbL4 ]Front door[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
[url= https://live.staticflickr.com/65535/40894623423_f8f82eef18.jp g" target="_blank">https://live.staticflickr.com/65535/40894623423_f8f82eef18.jp g"/> [/img][/url][url= https://flic.kr/p/25iHCNc ]Front door[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
[url= https://live.staticflickr.com/65535/46944958925_4c213db570.jp g" target="_blank">https://live.staticflickr.com/65535/46944958925_4c213db570.jp g"/> [/img][/url][url= https://flic.kr/p/2ewnbKx ]Front door[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
Then undercoat...
[url= https://live.staticflickr.com/65535/40894623803_2e1f252104.jp g" target="_blank">https://live.staticflickr.com/65535/40894623803_2e1f252104.jp g"/> [/img][/url][url= https://flic.kr/p/25iHCUK ]Front door[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
and gloss..
[url= https://live.staticflickr.com/65535/47808912602_ab5c04facd.jp g" target="_blank">https://live.staticflickr.com/65535/47808912602_ab5c04facd.jp g"/> [/img][/url][url= https://flic.kr/p/2fQHb5A ]Front door[/url] by [url= https://www.flickr.com/photos/brf/ ]Ben Freeman[/url], on Flickr
Almost worked, didn't quite get all of one knot and there is one spot which lifted over the summer.....
Posted : 16/05/2019 9:29 am
 Nico
Just the pointing to get sorted then, Footflaps.
Posted : 16/05/2019 11:50 am
