Stoves on a 12mm He...
[Closed] Stoves on a 12mm Hearth
6 Users
Morning people,
I'm currently in the midst of picking a stove to be installed in our conservatory. As there is no constructional hearth in there I assume I'm limited to a 12mm hearth?
Can anyone recommend a stove that's suitable for a 12mm hearth? I'm finding it hard to single out these stoves from the rest. Must also be DEFRA approved.
Out conservatory is approx 20ft long by 12ft wide. It's 3 meters tall and colder than the arctic in the winter. The higher the output the better.
Thanks
Posted : 24/09/2015 8:19 am
Out of interest as we've been thinking of putting a stove in our conservatory, why are you limited to a 12mm hearth? Can't you just stick something thicker down?
Posted : 24/09/2015 9:35 am
I might be wrong. I really need to ask an expert but its near impossible to speak to someone! I've left messages and emails with 4 different people and not one has come back to me...
I was thinking the extra weight of a big thick hearth and the stove would be too much for a non constructional floor area? We could pull up the floorboards and fill it up with concrete but that sounds expensive and difficult.
Posted : 24/09/2015 9:53 am
Try phoning Building Control?
Given you could put a Grand Piano in there, I can't see an issue with a 20mm hearth....
Posted : 24/09/2015 10:28 am
I'm sure a 20mm one would be fine.
Regulations say that the hearth must be 250mm thick though
Posted : 24/09/2015 10:43 am
I was thinking the extra weight of a big thick hearth and the stove would be too much for a non constructional floor area? We could pull up the floorboards and fill it up with concrete ...
Thanks for the explanation. We've got tiles on a concrete floor so should be OK.
Posted : 24/09/2015 10:49 am
The stove will need a hearth exemption certificate.
It's the heat NOT the weight that's the problem.
Posted : 24/09/2015 4:16 pm
You need to look for stoves that are rated to heat the hearth to 100 degrees or less.
There is a term you need to search for, which I've unfortunately forgotten, to find the right stove. I didn't know this first time round & ended up with a very basic one as it was the only one I could find with the right rating (Stovax Stockton 5 ML). It burned through wood at an alarming rate!
In the new house we took advice & discovered there were loads of others. This time I've got a Morso 04, which is much better.
Posted : 24/09/2015 4:45 pm
Thanks all.
Well I've spent ALL day searching the internet and finally narrowed it down to one of these Ekol stoves.
http://www.defrastoves.com
Seem to get reasonably good reviews and tick all the boxes - 12mm hearth, Defra etc. Local supplier and installer not too far from me either so might pop down for a chat tomorrow.
Either the Ekol Clarity or the Ekol Crystal. Both come in 5 / 8 / 12KW. One is Cast Iron and the other Steel / Cast iron door.
Would I be right in thinking that the higher the KW rating the quicker i'd be going through wood?
Posted : 24/09/2015 5:13 pm
Might be able to help you here .. I've got a Brosley Serrano 7 Multi Fuel stove 7Kw about to go on Ebay - Hardly used more less as new, in Cheshire. According to Defra its on [url= http://smokecontrol.defra.gov.uk/appliances.php?country=e ]their list [/url]as approved. Shout if you want some pictures - email in profile.
Posted : 24/09/2015 6:04 pm
Thanks Paul, just sent you an email
Posted : 24/09/2015 6:34 pm
