Stove-ists why does...
[Closed] Stove-ists why does my neighbours chimney stink?
10 Users
like the springfield tyre fire. He swears he only burns logs but it always smells acrid and it is getting a bit blimmin annoying.
Could there be a problem with his chimney/stove such that even burning normal logs makes a smell like burning rubber/oil/chemical waste?
Posted : 31/01/2014 10:50 pm
He's lying, probably. Round here, they'll chuck in anything that burns. The number of stray dogs has massively decreased...
Posted : 31/01/2014 11:02 pm
Chimney not sealed so smoke coming through to you. He needs to get it lined. Or burning any old treated painted or wet wood.
Posted : 31/01/2014 11:05 pm
Oh noes smokes.
If its coming into your house he needs to cease using it now.
If your outside and getting a whiff of it not and again and live outwith a defra zone - not alot you can do - unless his chimney is not the required distane above roofline /your opening windows
Posted : 31/01/2014 11:09 pm
Maybe Not burning it hot enough... So you get tar and creosote condensing in the chimney and can stink
Posted : 31/01/2014 11:11 pm
My guess, his starters. Magazine paper and bad cardboard.
I learned this week that a couple of sticks of kindling and one logs run up better than loads of paper, twigs and logs.
Keep your grate clean and have air flowing across your nethers.
samuri - Member
[Lesley Phillips] I say...[/Lesley Phillips]
Posted : 31/01/2014 11:28 pm
Wet unseasoned wood creates creosote that sticks to the inside of a chimney. This not only f*$ks the bricks up but also stinks when lit by high temperature.
Posted : 31/01/2014 11:50 pm
hmm we are in a smoke control area. I think his is an open fire.
Posted : 01/02/2014 7:48 am
Right I have it sussed, he is burning chippies offcuts. Its smokes like ****. Can I do anything about it?
Posted : 09/02/2014 5:49 pm
I can't see why waste timber from joinery work would be smellier or smokier than anything else - it'll just be seasoned, clean, dry wood, unless he's storing it or collecting it somewhere where it can get wet, even then that would just smell a bit smokey - not smell terrible.. Even panel products like ply or MDF would burn cleanly. What would be smelly is anything with a laminate on it - bits of kitchen doors / worktops etc
Posted : 09/02/2014 5:58 pm
You can only burn wood in a Defra approved stove in a smoke control area.
Clowns like him need to be reported to your local authority.
Posted : 09/02/2014 6:12 pm
