I've got a couple of bits of minor electrics to do at home:
1) replace a few halogen MR16s in the kitchen for LEDs which will involve changing the transformer currently wired in
2) changing a big horrible light fitting in a bedroom to a standard pendant
I'm loathed to call in a professional so intend to diy.
My intention was to just switch off the mains power on the junction box but this will mean I have to go around resetting all the clocks/heating controls afterwards.
If I just flick off the appropriate loops (e.g. Upstairs lights, Kitchen) whats the best way of testing there's no power in the wires before i start fettling?
I guess I'd like the reassurance of a power meter/tester of some sort. Assuming this is what i need what is a good/solid/reasonably priced one?
Can I have your bikes?
Well, this kind of makes me think you shouldn't be doing it...
But try turning the light on?
Yes, was going to do that but wondered if a tester would be wise in order to double check.
sure, but i was thinking of wiring up a dynamo light on my bike to get some practise 😉
It's entirely possible that poor wiring can leave wires live even if the lights don't come on. Use a tester, get an electrician, or make sure your life insurance is up to date.
what sort of tester should i get? there seem to be some cheapo things that look like pens or some more pro looking things with dials on???
So turn the light on before cutting the power.
There is a good chance the RCD will cut power to any circuits it is attached to once you start fumbling around. If you have an RCD.
You never know what is wired into which circuit unless you wired it yourself. Always check with a meter or mains test pen first, although if you're standing on a wooden chair / fibre glass step ladder, a mains test pen won't work as you won't be a good ground.
Personally I always do a final test with the back of a finger (as if its live the recoil is away from the wire), but then I've had so many shocks over the years I'm rather blasé about the whole thing....
These only cost a few £, but only work if you're not isolated from Earth:
how not to kill myself?
Hire a proper sparky, that way you get to stay alive [b]and[/b] keep the economy afloat. 😉
The best way to do all this is to wire it all up how you think is correct with all the power off. Then turn the power on and if the RCD trips you've got something wrong. Move some of the wires round and try again. When the RCD doesn't trip and the light works you have it correct. You don't need to know which colours go in which holes.
That's how I do it. Sparkies tell you you need an electrician just to protect their jobs. It's the same reason lawyers use latin to stop us all being able to do our own legal stuff.
I invoke Poe's Law.
[i]You never know what is wired into which circuit unless you wired it yourself. Always check with a meter or mains test pen first, although if you're standing on a wooden chair / fibre glass step ladder, a mains test pen won't work as you won't be a good ground.[/i]
Every day is a school day..., 😯 eek
The best way to do all this is to wire it all up how you think is correct with all the power off. Then turn the power on and if the RCD trips you've got something wrong. Move some of the wires round and try again. When the RCD doesn't trip and the light works you have it correct. You don't need to know which colours go in which holes.That's how I do it. Sparkies tell you you need an electrician just to protect their jobs. It's the same reason lawyers use latin to stop us all being able to do our own legal stuff.
Troll right ? you know it can be wired up to not trip the RCD and still be wrong right ?
What footflaps said ....
Hire a proper sparky, that way you get to stay alive and keep the economy afloat.
"Proper" is the important word here - the qualified sparky who wired up our house thought telephone cable was the right stuff to use to wire up the mains smoke detectors.
I bought one of those battery powered test pens from Screwfix that flashes a light and beeps when it detects AC.
It seems to work well.
I have only given myself one electric shock and that was when I failed to use the dibber, because I was confident that the light switch I was replacing was on a certain circuit and that was turned off.
It was the switch that turns on the lights on the patio and was in fact wired into the garage circuit, rather than the downstairs lighting circuit; logical now I think about it....I think the realisation that I'd just given myself an electric shock was more of a shock, than the actual shock itself, although my wife said she'd never seen me move so fast (and apparently I let out a girlie scream). 😀
I always take loads of photo's of the wiring before I enthusiastically unscrew them; particularly when it comes to light fittings! I'm sure there's more wires in there than strictly necessary just to confuse the keen DIYer....
😉That's how I do it. Sparkies tell you you need an electrician just to protect their jobs. It's the same reason lawyers use latin to stop us all being able to do our own legal stuff.
On a more serious note, I have never understood why people like to have a go at doing the electrics. Do you play with the gas?
I suppose the daisy chaining nature of electrics makes people feel they can do it...until it bites you.
Anyone for a Part P please Bob..
My best electric shock was when I was three, I shoved my finger in a light socket with no bulb in it and burnt the end of my forefinger off (no finger print on that finger now). For this I was given a Penguin biscuit by my mother, since which I have always associated a reward with electric shocks. I blame the parents....
Yes, yes I do. In fact I spent all morning playing with oxyacetylene, which is a lot more bangy than your boring domestic stuff 😉
Turn it around - why do people not learn and do this stuff themselves? I helped my dad rewire their entire house when I was a kid.
No way in hell I'd use or trust one of those cheap chinese screwdriver things. Don't even know how the manage to get a CE mark on them.
My first job in spring (ie when I can work with lights off) is to map where the heck all the wiring actually goes (and water/heating pipes at the same time).
Then I can change the lights.
I have one light, that as far as I can tell is always live. I have honestly never found the switch for it, other than the main breaker. Fortunately, with E24 screw in bulbs rather than bayonet fitting, I can have a bulb left in permanantely that's just not screwed in all the way.
And one set of GU5.3 popped recently, in the kitchen. I can hear the transformer buzz but there's nothing coming out. So I actually need to do something now, rather than put it off indefinitely.
footflaps - MemberMy best electric shock was when I was three, I shoved my finger in a light socket with no bulb in it and burnt the end of my forefinger off (no finger print on that finger now).
Not quite as good as that, but having licked a few 9v batteries I was keen to see if you could get an electric shock from a scalextric track.
You can. And somewhat unsurprisingly it's strength is proportional to how much you pull the trigger and it hurts quite a lot!
Sonor - MemberOn a more serious note, I have never understood why people like to have a go at doing the electrics. Do you play with the gas?
Depends on what you mean by 'doing the electrics'....
I wouldn't think twice about replacing a socket with one of a different type, or a light fitting for that matter. There are no special tools required and it's just a case (assuming the previous one was wired correctly) of taking the wires out of the old one and placing them in the new one in the same positions.
But, putting new sockets in etc. I would always get an electrician in. The electrician we use has put several new sockets in for us, as well as installing our bathroom extract fan. He's does a good job and doesn't charge an extortionate amount, but calling him out just to change a socket face seems a bit unnecessary.
I can't think of a job involving 'gas' that I would consider sufficiently simple to not want to get someone in for.
"Anyone for a Part P please Bob.."
do explain.
240 mains doesnt hurt that much -the act of surprise and the fall from the ladder will hurt more.
go get a 12v car shock and come back to me - that smarts.
well i managed to fit a new battery to the car the other day and survived so maybe i'll be able to pull off the above jobs 😉
stumpy01, be careful with those 9v [url= http://darwinawards.com/darwin/darwin1999-50.html ]batteries[/url]
The final touch with the back of the hand was something a fireman friend told me about many years ago - if you're going through a smoke filled building you clear the area in front of you with the back of your hands in case it's hot or live. Your natural reaction will pull you away from the danger.
Also worth using Tesla's rule - always keep your left hand in your pocket so any shock goes down the right hand side of your body. I wouldn't rely on it but it's extra insurance.
Or do what the guys fixing live tram wires used to do in Moscow when I was there - wear rubber gloves and wellie 🙂
^^^This! This! Exactly this, yes BRAVO!^^^
Honestly why do people just not know how to do this stuff? I watched my dad blow himself across the bedroom floor chomping into what he thought was the isolated 1st floor ring main. Turns out it was the garage supply that some idiot ex-shipyard* sparky had stapled to the back of the skirting board. I learned some really valuable lessons that day: my dad can jump quite far, test everything & always assume its still powered, some "tradesmen" enter a trade as nobody else will have them, as trail_rat suggests 240v didn't hurt my dad that much, him recoiling against the marble fireplace did.
I know exactly why we have the wretched part P - because people forgot how, or were too scared to do electrics themselves proficiently, made stupid mistakes & didn't necessarily do themselves in, but put the next occupier or some unfortunate other sparky in danger. My current house is like this: previously wired by an alarm "engineer", everything is spurred off everything else, no boxes behind some of the sockets & one socket in the lounge randomly wired into the kitchen ring. The guy clearly had a common sense bypass.
*Victorian house, previously owned by MD of Austin & Pickersgill. Outfitted by shipyards, so electrical cabled nailed to trunking like on a ship, fitted wardrobes from a 1950s ship's cabin, asbestos-lagged 3" (yes 76mm) piped central heating clearly nicked from a ship's engine room, kitchen units with special lips to stop veggies rolling off while at sea etc etc..
It does have an occasional side effect of "death" in the right (wrong) circumstances though.
Never mind 12V, the HT circuit can properly focus the mind. I once had a crack off a faulty coil lead, that was something like 35,000V on my Escort (and I think newer cars are a lot higher still).
erm, aren't we wired top right to bottom left? So right hand in pocket & test with left?
"240 mains doesnt hurt that much -the act of surprise and the fall from the ladder will hurt more.
go get a 12v car shock and come back to me - that smarts."
I'm not saying don't do it, in fact you're legally ok to do it, but you should then have it checked & signed off by a qualified sparky afterwards. Or at the very least have a good idea & be confident in what you're doing if you're going to wing-it.
Part P- http://electrical.theiet.org/building-regulations/part-p/faqs.cfm
240v mains does hurt & people die from it every year, either directly or falling off ladders etc. Then there's the deaths caused by electrical fires..
This is the sort of thing Part P was introduced to try & prevent-
http://www.telegraph.co.uk/news/uknews/1473919/MPs-daughter-electrocuted-in-botched-fitted-kitchen.html
-Recording a verdict of accidental death, the coroner said: "I am going to record that the death was the consequence of home improvement work."
footflaps
It "may not" work, rather than "won't work" because your body (and the chair etc) may have enough capacitance to allow AC enough current to flow to light the indicator lamp in the tester!
newer cars are coil packs now, so I'd assume that's LV DC sent thru cables from (and back to) the ECU, and the HT bit comes straight out of the coilpack unit into the sparker(s). spose you could poke a screwdriver inside to find out.
If you dont know what you are looking for how will you know if you have found it ?
On an interesting note along the lines of the MP's daughter. My old next door neighbour asked me to have a look at her washing machine as she was getting "Slight tingles" off it.
I spent a while trying to find out why there was 240 volts between the tap and the case of the washing machine, which if you would have grabbed both a severe shock would have occurred.
Turns out her husband had recently added a bit of work surface and drilled and plugged the wall for support. The screw had gone straight through the twin and earth of the spur to the socket supplying the washing machine. It had cut the earth wire in two and the screw was touching the socket side of the earth wire and also the phase.
Must happen often ?
True, however when wearing trainers I can never get one to work so just rely on the back of the finger test, which normally works as you just get a tingle with a good pair of running shoes on your feet.
On a more serious note, I have never understood why people like to have a go at doing the electrics. Do you play with the gas?I suppose the daisy chaining nature of electrics makes people feel they can do it...until it bites you.
How about the fact that we were all (?) taught about electrical circuits at school? As I recall part of the assessed, practical element of my GCSE physics was wiring a three pin plug. So most people know at least some fundamentals about how electrics should work..
but wiring a 3 pin plug is now pretty much obsolete, and there's nothing there about how the house is wired up, or supposed to be wired up. and then you unscrew a light rose to find 2x as many wires as you were expecting. and whilst there are conventions about where wires and pipes and batons etc. should go, often they don't go there
one reason I need to map all of mine - 3 lots of holes for light fittings all put there by previous occupants in a concrete wall, with a wire poking out, none of which are likely to match up with new light fittings, and half of which have been painted over... where can I drill?
all I know is, that some where in there is 230V.
Yep, do my own gas work as well...
The back of the finger equivalent test for gas is a to run a lighter over a fresh solder joint, if it leaks you get a small flame you can just rub out with a finger and then re-solder (after purging). I believe this is no longer recommended though.....
Footflaps: did you used to own my house? Small bungalow in Blyth, copper gas pipes set into concrete, electric plumbed into the water, boiler riddled with air traps, alarm system from a department store?
All pretty standard in my day, I'd expect nothing less 🙂
Must happen often ?
All the time. Doing some DIY for my dad, involved drilling about 1' below a lightswitch. "Dad, are you sure there's no cable behind here?" "Definitely, it comes down from above..."
It's amazing how much of a drill bit will just vapourise.
Still, not as good as a friend who was restoring an old town house and, up in the attic, he managed to drop a live mains cable onto a gas pipe, blowing a hole in it. He was left in the dark in the attic, with the gas rushing out, slowly realising how lucky he was.
ot_fiat - Member
No. The idea is to somehow let current flow down the right hand side- heart is mostly to the left.
You'll see roadies (musical roadies) doing this.
somehow
somehow = ignoring physics, the current will flow through your whole body, dispersed according to the relative impedance of your guts.
However, holding L & N in each hand (which I've done) probably isn't a good idea as the voltage will be across your chest and therefore across the heart. I managed this changing a ceiling rose when I'd pulled the wrong fuse (my fault) and then tested with a test pen (which didn't work as I was on a wooden chair wearing trainers), so I went on to separate the cables with my fingers and ended up with L in one hand N in the other. Stung a bit....
Yeah, I know FF.
I didn't say that roadies were right.
Part P isn't needed for this type of work as it's not a new circuit it's pretty much like for like. You actually don't need to be an electrician to become Part P registered
Don't trust those stupid voltage pens, go to screwfix buy a decent multi-meter.
Make sure everything is dead before working. Fit what you need to fit power back up and test. Never work live
there's history of electrical tinkering in my blood....
my grandad's loft was like a spiders web there were so many cables criss crossing the space from his tinkerings. after he died (natural causes!) and we were clearing out his place I found a strip of wire 10m long with a plug attached at either end!!
I wouldn't have one of them screwdriver testers in my tool box!
The official way is to test using a two pronged voltage tester across L/N and L/E but only after it has been "proved" on a known live source or a proving box (small battery powered box).
I mostly use the pen type that lights the end up but I do test that it works first.
But tbh it's just as easy to switch the lot off as the rcd (if fitted) normaly trips.
I always use a multi-meter and check it on a known live source. They're only about £15.
something like [url= http://www.screwfix.com/p/lap-voltage-tester/3516f ]this[/url] is what you need. a multi meter is a bit more complicated to use, with the ability to measure capacitance, resistance, continuity, both ac and dc voltage. you just need to measure voltage at this stage. make no mistake, electricity can kill, and often does, but the knowledge is out there, go and learn. i've worked with loads of sparkies and plumbers, i wouldn't let half of them anywhere near my house...the things i've seen on site would make you shudder...
Always found the pen testers work ok, but you should test it in situ while the mains is on to make sure it definitely lights up as it will rely on some leakage to ground (through your body) and depending on the surface/your footwear it may not work.
I'd also recommend rather than just flicking off the relevant fuse/RCD you physically pull it out and put it in your pocket. You don't want your misses to come home and think it has tripped and flick it back on while you are working on it.
a well made test lamp / or similar 2 prong voltage tester like the following is far superior to a neon srewdriver (remember to test what ever Equipment your using on a known supply 1st)
http://uk.rs-online.com/web/p/voltage-indicators/7068577/
The old man across the street from our last house was a shop fitter. He'd done two noteworthy bits of work to his own home. Firstly - and appropriate to this thread - he'd done his own kitchen up, shopfitter style, ie with a metal frame and boards on this frame. The frame was live.
Secondly he'd built a two brick deep and two brick high 'wall' across the end of his driveway, in front of his bay window. A year or two before we'd moved in he was coming home drunk from the pub one night (as per usual) and smashed his car into the front of his house. He vowed it would never happen again and took steps to make it so!
When he died, his son found a note stuck to one of his many bin bags full of golf balls (his hobby was collecting them) asking that they be given to me! I've given most away now, but still have a few hundred (balls, not bags full of balls) in the garage...
