Have a Sonos ZP100 Amp. In the workshop and wet room I am putting in ceiling speakers all to run from the ZP100. The manual says to run between 4amps and 16 amps from it (no more no less). I am putting in 8 speakers, each one is 8 amps. The manual says you should run them in in series. How can i connect all 8 to the amp?
Sonos instructions https://sonos.custhelp.com/app/answers/detail/a_id/269/~/connecting-speakers-to-a-connect%3Aamp#4_speakers
C
Ohms?
That link says you shouldn't run them in series but in parallel and only shows connection of four speakers, two pairs. Running two 8Ohm speakers in parallel results in an impedance of four Ohms which is within the spec given
Yes but I want to run 8 speakers.
C
The manual says you shouldn't. What you need is another amp.
If you really must run eight despite this connect two in series on the left channel, another two in series on the left channel then do the same again on the right channel. Impedance will be in spec but the result will be crap.
Yeah, what RB said. Running two series pairs in parallel will meet your impedance requirements. I can't begin to imagine whether or not that's a really bad idea though.
Or get 16 Ohm speakers and connect them all in parallel
Mmmmm ta. Looks like I'm spending some more money then!
C
