Just need one for a couple of small jobs (breakout kit for a Raspberry Pi + whatever I end up doing with it). Don't want to spend a fortune. Seen a cordless gas one in Aldi, are these worth a look?
Any recommendations? I guess a kit would be nice with everything I need to get started.
Thanks
First of all dont get a cheap gas iron, you cant control the heat anywhere near well enough and with modern lead free solders you need higher temps but with good control otherwise yould burn everything. get a cheapish electric on from maplin and youll at least be able to control it to some extent. soldering properly requires skill and practice so i wouldnt go in on something you actually want to start with. get an old cd player or what ever and practice. laminate construction and component size have a part to play and will dictate what you need to use in terms of tips etc. for desoldering i personally prefer wick rather than suckers but its up to you.
Don't get gas. I would recommend the 15w one from Maplin for small electronics like the Pi
http://www.maplin.co.uk/15w-miniature-soldering-iron-type-c-4052?action=noagentcheck
As an occasional dabbler and having both electric and gas ones in the garage, the electric one gets used every time.
One of the down sides with the gas ones is that there is an exhaust from the burner that can do proper damage to your surroundings / whatever you're fixing.
Gas is great for fixing stuff outside: like on the car.
My 2p's worth.
I just got a cheap one for ten quid from our local hardware shop. It says blackspur on it came with a stand and a solder sucker upper thing but no solder or instructions . I bought some solder and my wife told me how to use it. It worked.
Personally I'd get something bigger than 15 watts. Just not enough power to heat up a joint reliably imo.
Oh, and make sure you get proper 60/40 tin lead multi-core solder. Stay clear of lead-free stuff.
when you say proper solder you mean the solder that now cannot be used in almost all electronics (a very few exceptions) and in my experience lead free is no harder to use... 😉
You can pry my reel of Lead solder out of my weak, [url= http://en.wikipedia.org/wiki/Lead_poisoning ]uncoordinated[/url] hands.
one tip though. It's not a pen. the pointy end gets a wee bit hot...
I keep a roll of proper solder just in case.
The maplin 30W model (yellow) is decent as a general purpose iron. Cheap replaceable tips and feels okay in the hand.
I picked up one of their ESD variable temps ones for an experiment and was impressed for the price at it was on offer for £40. http://www.maplin.co.uk/60w-professional-lcd-solder-station-with-esd-protection-511927
The iron is cheap feeling but it's because I grew up using dads professional weller ones and it's only £9.99 for a replacement iron.
I used to fix iPhones for a bit of college money, I bought a 30W electric Blackspur one off fleaBay for next to nothing. It was fine for me, but in an ideal world I would have had one with a finer tip.
🙂 yep can attest to that... still better than a splash from a solder leveller though, ( down inside a boot!)
You need to add to the end of that sentence 'used in almost all electronics that is commercially sold' 🙂 I'm guessing that the OP isn't planning to go into commercial production. The chances of them getting a lead-free solder that wets as well as a leaded one is slim. And thus the chance of producing a decent joint if you only occasionally solder is also slimmer.
Also lead-free is more toxic to use as the fluxes in them have to be far more aggressive.
For home use it has no plus points. For commercial use it has no plus points either. It's just you've no choice but to use it.
This would be way overkill for you but we bought a Xytronic LF2000 for work and it's a joy to use, especially as we have to use lead-free solder. Bit life is so good that it'll work out cheaper than our previous solder station in about a year. Just an FYI for anyone that's wedded to Weller and Antex. We're soldering some big high current (20A+) components so need all that power!
Lead free solder was the devils work when launched, probably better now. I think you can still use leaded for rework in commercial electronics. Do remember lots of noise about the increased melting points for lead free more than negating any environmental benefits.
I would stay away from gas irons and lead free if you can. Maybe pick up an old fixed temp weller from ebay?
you like xytronic stuff then?. we've been looking for some more iron and did look at them. mostly we paste and then reflow. it would be handy to have something to handle big old heat sinking inductors on singles
Cheers all. Thanks for all the advice.
Cheap electric one will be fine. You can find leaded solder at car boot sales etc, but try to get one that's been stored in an airtight container. Lead free is ok IMO thou.
Go for an iron with a smaller tip.
[url= http://www.maplin.co.uk/solderpro-120-gas-soldering-iron-kit-35516 ]I like my one.[/url] Sure it's no good for SMD - but then what is?
30-120W covers most of the bases 🙂
Lead free solder is fine, if you know how to solder properly it isn't an issue.
If you're just doing a couple of small joints using thin wire to PCB a cheaper leccy iron will be fine. If you're likely to be doing more than that and soldering leads onto larger pieces such as the back of a pot then get an adjustable iron or a high wattage iron, for that, the hotter the betterer.
Any iron (small tip) can be used for SMD prototypes if you know what you're doing but for ease, you cant beat using the proper system.
I'm working on the assumption this is not for SMD and that you can just go borrow one?
I use a Iroda 70w gas soldering iron which I have found more useful than the electric iron it replaced. No problem with heat control and will run between 40-60 mins before needing a refill.
I bought one of these http://www.maplin.co.uk/40w-soldering-kit-399593 when I needed to replace some capacitors in my TV. I was surprised my cack-handedness didn't melt everything within 10ft, even more surprised when the TV worked again afterwards. Soldering iron seemed OK although seemed more hassle using it + the supplied solder than I remember from my school days.
