(Solar) AA/AAA batt...
[Closed] (Solar) AA/AAA battery charger recommendations.....
2 Users
So, following last weeks helpful and informative thread ( http://singletrackmag.com/forum/topic/high-capacity-rechargable-aa-batteries) I am now sorted for batteries!
I currently have a pretty basic charger, but it would nice if I could replace this with something a bit more high tech that:
- Charges up to 4 AA/AAA's at a time, but manages each one individually/can charge a single battery
- Can cope with up to 3000 mAh capacity batteries
- (Moon on a stick time....) Ideally solar powered, but I'll take 240v recommendations
- (Second moon on the same stick) Ideally, not be too pricey.
What do you recommend? Ta 🙂
Posted : 05/11/2012 8:51 am
It does not suit your requirements but for a low cost bit of fun you could use a garden solar powered light and charge 2 low mah Ni/mh batteries. The big single lanterns are about £5.00 for 2 in morrisons if memory serves me correctly. Perhaps if you are technically minded you could adapt them for your needs. At that price it's worth a go just for a bit of fun and as a learning exercise.
Posted : 05/11/2012 8:59 am
I've done a bit of prior research, and what you suggest is possible, but:
- my 2900 mAh AA's are going to take a looooonnnnng time to charge from the garden solar light panels (unless I buy loads and then it becomes uneconomic)
- The circuit needs modifying with a diode to stop the batteries discharging as soon as the sun goes down
- Something of comparable cost can be had ready to go http://www.ebay.co.uk/itm/ECO-FRIENDLY-SOLAR-BATTERY-CHARGER-8-AA-AAA-NIMH-RECHARGEABLE-BATTERIES-/360499230300?pt=UK_Sound_Vision_Battery_Chargers&hash=item53ef6db65c
The problem with the above is, by their calcs, my 2900 mAh AA's are going to take more than 50 hours to charge from that 0.75W panel. I guess I'm therefore looking for something with a 1.5W panel (at least).... which probably puts me into the the range of a separate panel and charger arrangement, which isn't as neat as an integrated unit, but I could live with if it was better and (again) didn't cost the earth.
Posted : 05/11/2012 9:11 am
Bump for the afternoon crowd....
Posted : 05/11/2012 12:56 pm
