So I've got this Me...
So I've got this Mercedes and I have questions
151 Users
14 Reactions
Steering rack is off, engine mount bolts are off but I'm struggling to see how to jack up the engine to get the old mount out. The sump is plastic so I can't jack there. The flywheel housing is metal but if I jack up there then the whole car just lifts (it's on its wheels on ramps). I think maybe I need to loosen the other mount as well.
Posted : 25/09/2021 3:17 pm
Can you not hire an engine hoist?
Posted : 25/09/2021 3:28 pm
Back all the mounts off... inc the gearbox ones.
Posted : 25/09/2021 6:16 pm
Just after I posted that J realised that the reason the suspension was going up was because I was taking the weight of the engine off it! Kept jacking and it it popped up as predicted.
The old mount is 4mm shorter than the new one and it has noticeably more lateral play.
Now I have a different problem though. The two new mounts look identical but they have different part numbers. I need to play spot the difference.
The drive slopes, but as above not necessary.
Posted : 25/09/2021 7:22 pm
Ah bollocks. I found them on the website, and it says left and right, with different part numbers. The part numbers are on the boxes, but they are not on the mounts themselves, and I have taken them both out of the boxes!
There is a number on the mount but it doesn't corroborate to anything on the box or the website. They appear to be identical. Is it possible they are identical and simply kept as different lines by the manufacturer? There might be some internal difference i.e. a different rubber pattern inside or something.
Posted : 25/09/2021 8:21 pm
Oh bollocks! Do they look identical?! If so, I reckon it's safe to assume that they are.
As you say, the part numbers are probably just for stock control.
Do you have a set of calipers to measure them up and see if there is any dimensional differences?
Have you stuck the number on the mount into Google?
Posted : 25/09/2021 8:35 pm
Order another pair from the same place, fit them (paying attention to left & right), put first pair in boxes and return them as if they are recent order #2.
Posted : 25/09/2021 8:48 pm
Yeah I'll measure them up properly tomorrow.
Good idea googling the part number on the mount. I get some odd results. A Lituanian scrappy with a picture of a used mount bearing the part number that matches the right hand mount but with the word 'kaire' written on it which is Lithuanian for left-hand side.
Clever.
Posted : 25/09/2021 8:54 pm
Being helpful in atonement for the ribbing!
Posted : 25/09/2021 9:02 pm
I won't do it though, that'd take another 10 days and I am impetuous 🙂
They even weigh the same to within 1g.
Posted : 25/09/2021 9:06 pm
If you fit them, taking a punt on LHS/ RHS any odd vibrations you’ll be wondering if you had them the right way
Posted : 25/09/2021 9:28 pm
Any taper or casting Mark's on the lugs?
Posted : 25/09/2021 10:04 pm
You only need order 1 though
In fact, just ring the supplier or another uk factor and get the code off one side, the other one fits the other side
Posted : 25/09/2021 10:28 pm
Any numbers on the parts that are different?
Posted : 25/09/2021 11:47 pm
They could be the manufacturer production batch codes.
Posted : 26/09/2021 9:07 am
They could be the same size and weight but have different properties (different youngs modulus).
Posted : 26/09/2021 9:36 am
There's a sticker underneath. Googling it as above provides results, but not particularly good ones.
The Lemförder part number for left is 35573 01 and for right is 35574 01. The stickers on the mounts themselves are F036072523D and F036072422D. I think 2522 is the left.
The outer casing on both sides has MLM 3618 647 on it but I think this refers to the casting since the other metal insert has 3618 648.
Posted : 26/09/2021 9:49 am
Can you get on lemforder website is there a pdf catalogue anywhere. Or a euro car parts open as alot of the parts systems have part number comparison functions.
Posted : 26/09/2021 10:05 am
Though I'd go
523d left
Posted : 26/09/2021 10:06 am
ECP didn't have them listed not sure if they'd do that for me.
In reading about this it seems that Lemförder and others can buy parts in from elsewhere andthr quality might not be good. So I've no way of knowing what I actually have here. Arse.
I have found the parts listed on breaker websites with the F number under both left and right.
There's a forum post asking if left and right are the same on this car and someone says yes but doesn't offer evidence. The right one has a heat shield, it may be that it has in the past come with the heat shield although mine does not. Which isn't an issue as I can re use the existing one.
Posted : 26/09/2021 10:13 am
Using  https://www.bestpartstore.co.uk/1273493-lemforder-engine-mounting then clicking on the oem part number link comes up as left side.
Going back to the link one of their photos is of the label showing number F036072422N.
Good enough for me to say you are right about which side is which. Bloody lazy design not to cast in a detail making it impossible to fit in the wrong position.
Good luck, and I presume you were chasing a rainwater leak in that Passat photo? My mk1 Kuga has looked similar, I ended up driving it round with only the drivers seat in whilst the carpets dried out and I was sealing it, testing it, sealing up a bit more, testing it... difference is I do it out of the public eye, credit to you for providing entertainment 🙂
Posted : 26/09/2021 10:26 am
Thanks oldnick 🙂
Yeah the leak, I think it was coming in via the replacement windscreen. It was a rainy spell of weather that prompted that effort and it rained hard whilst I had all that stuff out so I could see the water was dribbling in from the interior box section under the windscreen. So I filled it with expanding foam! It's been fine since. Fortunately I didn't need the car at the time.
Posted : 26/09/2021 10:33 am
They're both in place, they both fit. The engine is as expected a few mm higher. When looking for rattles earlier I noticed that the plastic strut that hold up the I take pipe was resting on the fan cowl and rattling, and I couldn't understand why it was just resting there and there wasn't a fixing. Well now the strut clears the fan cowl. It's fascinating how these tiny little things all contribute to the general condition and age of a car.
Having given the engine a wagfle it feels a bit more mobile than it was. Will be interesting to see what difference it has made.
Posted : 26/09/2021 11:28 am
 IA
I assume at that point you’ve double/tripled checked all the bolts are done up properly…
Posted : 26/09/2021 1:04 pm
Good luck Molly, hope it works.
Any pics? 😃
Posted : 26/09/2021 1:13 pm
Pics of what exactly? A Merc with the bonnet up? It's nothing dramatic.
Posted : 26/09/2021 1:54 pm
Well done Molgrips, how does it drive now?
Posted : 26/09/2021 4:34 pm
Pics of what exactly? A Merc with the bonnet up? It’s nothing dramatic.
Well you do have history with amazing pictures! And as mundane as is to someone competent with the spanners, it's also genuinely interesting to people like me that wouldn't dare tackle a job that involves such possibilities as 'jacking up the engine'.
I really hope you've sorted it.
Posted : 26/09/2021 5:00 pm
Ah sorry, I'd have taken pictures if I'd realised you were interested in the mundane 🙂
Anyway, it's done. There's good news and bad news.
The good news: All the issues I identified and took to TCW are gone. Barely any vibration at idle, the hard shift into D and R has gone, there's no rattle when the engine stops or you slow to a near stop, and best of all the shifting is absolutely mint now. You can (or I can!) feel the tiniest sensation when it shifts at certain loads but otherwise it's invisible, double cream all the way. This is what many people have said on forums - the mounts generally only last 80-100k miles, they don't fail the car just gets worse but you don't necessarily realise it until you have them changed and it's loads better.
The bad news: I've buggered up the steering and the ESP somehow. When I start it up, the car wants to go left, Then when I turn the wheel more than a slight right turn it meets resistance; push past that with a clunk and it's ok. After this happens once or twice the ESP gives up and disables itself, at which point the steering moves lock to lock freely. Sometimes the ABS will grab the offside wheel just before throwing in the towel. Stopping and starting resets the process.
There are two possibilities I'm thinking of.
1. I bent the steering column when I removed the rack - stupidly I didn't realise you could disconnect it and push it clear before lowering the rack, so it was a bit of a thrutch. But after the ESP goes off it seems ok generally.
2. The most likely one is that I inadvertently span the steering wheel one complete revolution to the left before reassembling it. So when I drive straight it thinks I am turning right, and when do turn to the right it thinks I've gone all the way to the lock and stops assisting. And when I push past that, it realises something's wrong and stops. The ABS activating might be because my direction of travel doesn't match what it thinks the wheels are doing so it thinks I'm sliding.
Posted : 26/09/2021 6:46 pm
Most likely it’s a steering angle / rack position sensor issue
Posted : 26/09/2021 7:22 pm
Yeah I was right, the wheel was 360 to the right. Spun it back, it appears to be fine on a short trip. Almost reversed over the undertrays that I'd pushed under the car though whilst testing it. Balls.
If anyone tells you Mercedes quality isn't what it was - the rear undertray is gold plated on the inside.
Posted : 27/09/2021 11:21 am
Nice one.
Lucky you didn't damage the squib drive.
But fair play. Nice job
Posted : 27/09/2021 1:40 pm
Thanks, yeah I was lucky it didn't break when going lock to lock.
Pretty pleased though, normally I do this kind of job to try and improve perceived problems and it makes no difference. And all in all wasn't that hard, the big job was figuring out how to undo the top bolt on the one side. After that it was easy really.
Posted : 27/09/2021 3:05 pm
Happy endings all round hazaar!
Posted : 27/09/2021 3:14 pm
Give yourself a pat on the back 🙂
Posted : 27/09/2021 4:31 pm
My wife told me the other day after a glass of wine that she didn't really like the car, it was too uncomfortable and this bothers me because it's meant to be a family car. Today, after basking in the glow of my mechanical success I realised I could get an E-Class estate for what I could sell this for.
Someone please shoot me, or at least take my driving license off me.
Posted : 27/09/2021 4:50 pm
Maybe she's just jealous of having to compete to be the object of your affections? 😉
Posted : 27/09/2021 5:31 pm
Maybe she’s just jealous of having to compete to be the object of your affections afflictions
Fixed that for you 😉
Posted : 27/09/2021 5:37 pm
Boblo nails it.
Posted : 27/09/2021 5:41 pm
Noooo, not when we've got so much emotional investment in Marvin!
Posted : 27/09/2021 7:23 pm
I had the clock spring / steering rack issue when I had my Volvo in a million bits recently. Lots of careful measuring and gentle lock to lock of the wheel to find straight ahead on both components before rejoining the steering column.
yeah!!! watch out Brexit and Trump threads - Molgrips Merc postcount ain't finished yet!
Posted : 27/09/2021 10:39 pm
Clearly cause for a new thread.
"So I've got this other Mercedes and I have more questions"
Posted : 27/09/2021 10:59 pm
So, the choices are:
Stick with this car my wife doesn't like
Get an E class estate same miles and age
Get a Passat, a bit newer and lower mileage. They are available on Autotrader for much less than locally.
Posted : 28/09/2021 1:07 pm
Good god man! Someone shoot him.
Does she not like driving it or just being driven in it? Don't you have the electric car for day to day use?
Posted : 28/09/2021 1:12 pm
Come on, this is STW, you forgot the patio option
Posted : 28/09/2021 1:38 pm
Posted : 28/09/2021 1:42 pm
She doesn't like being driven in it, it's too uncomfortable. It's main useage is going to be holidays and longer family trips.
Posted : 28/09/2021 1:46 pm
 ctk
Passat.
 ctk
Holidays and longer family trips?
VW Touran
Posted : 28/09/2021 1:47 pm
Stick with this car my wife doesn’t like
Who wear the trousers in your house?
*ducks and covers*
Posted : 28/09/2021 1:57 pm
My wife hates my car - she has her own car though and I hate that so all's good! 🙂
Posted : 28/09/2021 2:04 pm
E class for sure!
Posted : 28/09/2021 2:22 pm
Jesus wept! Can you not just buy a cushion for the passenger seat?
Posted : 28/09/2021 2:24 pm
She doesn’t like being driven in it, it’s too uncomfortable
A cushion?
EDIT: 5mins too slow
Posted : 28/09/2021 2:30 pm
At least enjoy it for a bit first now you've fixed it.
My Mrs thinks my car is now too uncomfortable. Only happened since she got an SUV, we've had my saloon for 18 years ! Yes the SUV is lovely and wafty, but you aren't going to 'press on' on a country road, and it's a bit wallowy round bends.
Pick a car from a more reliable manufacturer.
Posted : 28/09/2021 2:44 pm
There *is* an alternative use for that cushion that could be considered...
Posted : 28/09/2021 2:51 pm
We both do, of course.
Touran - considered it. Bit less plush than Passat, no?
E-Class estates are ugly, but they do have the self levelling rear suspension as standard which is a big plus. Passats don't have it even as an option any more as far as I can tell.
Posted : 28/09/2021 3:00 pm
A cushion?
Go the whole hog and fit an air suspension passenger seat from a lorry cab.
Posted : 28/09/2021 3:12 pm
I could get new wheels for the CLS but that's expensive and I don't have any idea how much difference it'd make. It has stupid 19s on it now.
Posted : 28/09/2021 3:17 pm
Having had a Touran for 3 years (after a Passat) I would urge you to look elsewhere. Horrible narrow wallowy thing it was. 5 of the 7 seats are cramped for adults. Joyless car.
Posted : 28/09/2021 3:24 pm
No one sets out to buy a Touran. They just end up with one.
Posted : 28/09/2021 3:27 pm
Does your wife like the E-Class?
Posted : 28/09/2021 4:02 pm
She thinks they look ugly (as I do) but we haven't been in one. I should find one to test drive I suppose.
Posted : 28/09/2021 4:08 pm
Do you want to buy a nice low mileage Renault Scenic?
Very comfy for your wife and a host of irritating electrical problems for you to entertain yourself and the forum with?
Special price for you.
Posted : 28/09/2021 4:13 pm
Life's too short to be having ugly vehicles - stick with what you've got (with higher profile tyres if required) or choose something you both admire 😊
Posted : 28/09/2021 4:23 pm
Maybe it’s time for a new wife?
My wife is pretty picky about cars - she didn’t like my Jaguar XE much as it felt too claustrophobic. She didn’t like my Seat Leon as it sounded like a tractor and was a bit low rent inside. She didn’t mind my Citroen DS5 at the time - but in hindsight it was her favourite car to be driven in as the seats were so comfortable. It was a pretty good car tbh - other than being a bit wallowy.
If you want a bit estate then a Jaguar XF Sportbrake is worth a look - I got one a few months back and I love it. Drives well and is pretty fun for something so big, has a decent interior, plenty of toys, a zf 8 speed gearbox, self levelling rear suspension and the boot is pretty big. I’m running it in portfolio spec with the 250ps petrol engine but for the same price I could have had the 3 litre diesel V6 if diesel is more your bag.
And the wife thinks it’s comfortable and feels more solid / safer than any of my last cars. Win / win.
I’ve got 245 / 40 / 19’s on it and it isn’t crashy/ bumpy at all. I think Jag have done a brilliantly jog of balancing wafty suspension with something that still steers and handles well.
Other than petrol fuel consumption - 25mpg seems to be about the average. I’d assume the diesel is considerably better.
Posted : 28/09/2021 4:52 pm
Hmm I might take a look at the Jag but max budget 15k, preferably 13k. That gets you a facelifted E Class or a facelifted Passat.
The CLS only gave me 39 today which is frankly shocking. My old Passat would have been at least high 40s on that trip probably more, and the newer ones should be better again.
It's not exactly crashy with 19s on, but it is pretty firm. When driving it's not sombad but as a passenger I can see howmit would be annoying. It is also pretty noisy from the boot. Not sure if it's the P-Zero rear tyres, or the fact they are 19, but it's annoying and the reviews praised the quietness.
I'd dearly love a V6 diesel which are plentiful and not expensive in the E Class but fuel economy.
Posted : 28/09/2021 4:55 pm
That's a fair bit more rubber - mine are 285/30/R19 on the back.
Posted : 28/09/2021 6:20 pm
[url= https://i.ibb.co/PQ3MGkq/160301-E0-7-A2-C-4728-A8-F0-1-E4-F33-EE221-F.gi f" target="_blank">https://i.ibb.co/PQ3MGkq/160301-E0-7-A2-C-4728-A8-F0-1-E4-F33-EE221-F.gi f"/> [/img][/url]
Posted : 28/09/2021 6:27 pm
If it helps, RNP, I feel like that myself at times 🙂
Posted : 28/09/2021 6:49 pm
If you want a comfortable estate, I'd have thought Volvo's would be worth a look.
Posted : 28/09/2021 6:58 pm
Mmm yes, which one though? V70 for big holiday trips I suppose.
Posted : 28/09/2021 7:02 pm
I looked at the first two posts and jumped to the end wondering why there a 20 page thread about a Merc estate. Still none the wiser, maybe I should read it haha
However, noticed the gearbox comment - probably mentioned before, but Merc boxes are notoriously bad. Even the prevcious gen C63 AMG was reportedly ruined by the box
That's what you wrote - but did you mean
She thinks (as I do) they look ugly
Posted : 28/09/2021 7:39 pm
I think it’s about time you bought something French Molls.
Posted : 28/09/2021 7:47 pm
😄 @greybeard
Posted : 28/09/2021 7:55 pm
@Greybeard lol
However, noticed the gearbox comment – probably mentioned before, but Merc boxes are notoriously bad.
Well... hmm. Thing is, reviewers praised it at the time. Now there are some foibles that I can appreciate an AMG owner would hate. For example, in manual mode the shifts aren't quick. They are smooth and they don't break power, but they happen about a second after you actually press the paddle. That would drive me nuts on a performance car and is possibly why AMG now have a dual clutch system instead of the TC. However on a normal car, not much of an issue. Mine is generally pretty good now since I did the work on it. It's smooth, but not what you'd call crisp like a DSG; but it is more intelligent than the one on the Passat. It holds its gears through corners, and it changes down when you go down a hill. Basically a lot more like you would drive yourself in a manual.
Posted : 28/09/2021 8:05 pm
Funny you mention it, I'm actually thinking we could do a trade over the weekend, my C8 for his Merc. See how long Mrs Molgrips lasts before begging him to trade back the Merc. I have sod all better to do on a week off right now and if you really want to seal the deal you can have her help you trace the intermittent fuel leak and find out why/where it appears to spray oil all over the engine bay.
Posted : 28/09/2021 10:24 pm
Page 10 / 15
