My son (6) wants to go up a hill with snow on it. I was planning on doing that this xmas hols. Should be easy I thought earlier in the year, but it seems the mile winter has scuppered my plans for the peaks or berwyns (options 1 & 2) as they appear to be a bit barren of snow at the moment.
So where's the nearest snowy peak to Leicestershire or Oswestry to give my lad a winter dadventure?
We have some here in the Cairngorms
cheers! bit far for a day out. 😆
I'd have thought North Wales would be most reliable location for snow near to you.
Chances of real, outdoor snow - zero currently, unless you're way North 🙂
I had some on the ground outside the office in Stirling at lunch.
If there's any webcams around you that you can check on then that will be a start. Also keep an watch on the weather and which direction systems are coming from: if there's a mass of cold air coming south due to the jet stream moving along with some precipitation then you stand a good chance. Sometimes it's just the first line of hills that gets the snow, everything else is in the rain (snow) shadow. So a North easterly could cover the Berwyns and Arennig but leave Snowdon itself clear, similarly a westerly storm could cover all the main Snowdonia ranges but there'll be nothing further inland.
Good luck!
Lakes is not a good bet http://www.lakedistrictweatherline.co.uk
Pennines neither http://yadmoss.co.uk
Snowdon summit Forecast
http://www.metoffice.gov.uk/public/weather/forecast/gcmjghxpx#?fcTime=1482451200
the Sahara desert perhaps http://www.independent.co.uk/news/world/africa/sahara-desert-snow-first-40-years-rare-photos-atlas-mountains-algeria-karim-bouchetata-a7488056.html
seems to be colder than the arctic this year...
Some sleet blew through at lunchtime ,I shouted at it to come back when it was proper snow.
