Snorkeling and car ...
[Closed] Snorkeling and car keys.
37 Users
Back in the old days it didn't matter if your key got wet.
Last year I put the hire car key in a plastic bag and then in my pocket.
It leaked a bit so would like something better this year.
Whether it be a tow hitch key safe our some super duper waterproof bag.
Not sure how heavy those tow hitch locks are as we will have it in hand luggage.
Posted : 21/08/2017 9:36 am
My other half got a 'dumb' key cut that would unlock the door, but wouldn't start the car (cos there was no transceiver chip in it).
She'd lock the 'real' key in the car using the 'dumb' key and swim with the 'dumb' key on a string round her neck (under her wetsuit).
Posted : 21/08/2017 9:39 am
Lomo have some good waterproof cases
http://www.lomo.co.uk/acatalog/DRY-BOX-YELLOW-TUBE.HTML
Standard practice is normally to get key cut that just opens the door, but does not have the electric gadgetry, then put proper key inside car and take low tech key swimming/surfing/kayaking
Might not Timspns in L'Estartit though
I used to use an otter box when UK shore diving. They do nice little ones with an eye for a clip
edit: this one: https://www.amazon.co.uk/OtterBox-1000-Drybox-Case-Yellow/dp/B001DAU10U although it seems they've stopped making it
I've also found the dry bags with the clip top to be absolutely fine. Happy to put my phone in one when kayaking and snorkelling so would be fine for keys.
Like this: https://aquapac.net/store/shop/waterproof-phone-cases/waterproof-phone-case-small/
Posted : 21/08/2017 9:40 am
Nature's pocket is the best way to go.
Posted : 21/08/2017 9:45 am
It's a hire car so getting a key cut is not an option.
[s]Buy[/s] Rent a Land Rover with their fancy activity key.
Or if you can't get a Land Rover: depending on how deep you plan on going, get an Otterbox or an Aquapac Keymaster.
Posted : 21/08/2017 9:46 am
Another vote for a dumb key. Keep the proper one in the boot or glovebox.
"It's a hire car so getting a key cut is not an option."
Why? Worth the few pounds it'll cost rather than breaking the key or having the car stolen.
Posted : 21/08/2017 9:49 am
We once lost the second fancy electronic key for one car, for several months. Turned up in one of the many pockets in my Endura Humvees. They'd been on many rides and been washed many times. Key still worked.
Toyota ftw.
Posted : 21/08/2017 9:52 am
a lot of surfers / kite surfers around our way use those key safe padlocks and put the key in that - usually see them attached to tow bar eye or even on spokes of alloy wheels or door handles - though few cars have those now - bit of an unknown with a hire car but would have though somewhere possible grovelling underneath - bit heavy in luggage though
Posted : 21/08/2017 9:54 am
Put the key in a condom and tie off.
Or....
Any flip key can be opened and the metal blade removed. Its how they put them in the first place.
Just flick it open or unscrew and remove the blade from the key.
Reassemble before handing back.
Posted : 21/08/2017 9:56 am
Isn't that just for wris****ches? Mine's supposed to be good for 200m but I like to play it safe...
 spot
Aloksak
Posted : 21/08/2017 9:58 am
Unless he hires a Koenigsegg CCXR that is.... 😯
Posted : 21/08/2017 10:01 am
TheBrick - Member
i thought that was some sort of orifice suggestion - not sure if want to google it
Posted : 21/08/2017 10:05 am
If you going snorkeling you must be near a beach. Simply bury the key in the sand. When you have finished playing in the sea all you have to do is locate the correct bit of beach in dig it up again. What could go wrong?
Posted : 21/08/2017 10:13 am
For extra help, mark the position with a shell or a stone.
Posted : 21/08/2017 10:18 am
When I went scuba diving I used to hang the keys over the top of the suspension spring. Don't know how my car didn't get stolen!
Posted : 21/08/2017 10:55 am
Cintinue using a plasticbag andwrap it in tape.
Wrap itit clingfilm.
Condom would be perfect but careful it doesnt go flying out your hand after you remove it!
Posted : 21/08/2017 11:02 am
Us lot use a number of options:
Keysafe's (little coded locks with flap for keys) deterrent at best, easily opened with a screwdriver unfortunately, but it's the better option because it's seen on the car.
Aquapack's, sealed leak proof bags with lanyard for your neck. Nice enough by the lanyard can throttle the life out of you if not careful... under wetsuits not so bad because the neoprene presses against your body trapping the bag to your body, but they do work thier way down to the weight of the bag/key. We hang em' around our necks and throw the key back over our backs so not to interfere if we land on our chests climbing on/off boards etc.
Condoms, useless. They break/rip and you loose the key to the water ingress.
Sandwichbags, fine for short periods, tend to leak if not fully wrapped and maybe taped up.
Hiding key under/on top of wheel or under bumper.. well, can be ok but the wheels the first place anyone looks on the beach, the bumper recesses are ok if you are lucky, alloy wheel gaps are useless as wind gets through and key can get blown away/lost in sand.
Hiding key somewhere on beach, effective if you can remember where it is, but kids and detectorists scour the local looking for buried treasure..and hey presto' they've found a key!
Swallowing it.. not an option unless happy to wait until morning for the inevitable..
And the whole proximity key fiasco is proving absolutely hilarious these days for these keyless entry fangled dangled modern solution to a problem that never existed..
HtH's
 MSP
This is what I use for open water swimming.
https://www.amazon.co.uk/Aquapac-604-Keymaster/dp/B0012BQZ0A
[url= http://gear.landrover.com/gb/en/discovery/interior/function-technology/lr091580-activity-key-wristband/ ]Hire a Discovery. [/url]
Posted : 21/08/2017 11:08 am
rather than a condom, a kids balloon. Far cheaper too.
Posted : 21/08/2017 11:33 am
park car with it in gear. roll car back a little and put key under wheel. let the car roll back onto the key.
used to do this with a mate when we shared a car for a few months back in my teens.
Posted : 21/08/2017 11:44 am
Why not just hide in some part of the body work?
Ive done it loads of times
Posted : 21/08/2017 11:47 am
How about sliding a tight(ish) fitting sleeve of inner tube over your snorkel ,pull bottom half of this up over the key entombing it in a nice little snug, super secure and probably waterproof cocoon-works well on bike too 😀
Posted : 21/08/2017 11:54 am
I use one of these for surfing... it was ideal, just can't remember where I packed it when we moved!!!
[url= https://www.surfsurfsurf.co.uk/surfing-gifts-and-surf-accessories/keypod-car-key-safe-for-surfers?gclid=Cj0KCQjwierMBRCHARIsAHl9i4FUJqL0wGx3lxX_c_FvQ0OmZ5mFi54OUOwWJXevTFeEY2d9NpdjC_AaAuWfEALw_wcB ]locking box thingy[/url]
You can usually find somewhere to hang it on a car, if not then on a bit of nearby street furniture... just need to get creative!
Posted : 21/08/2017 12:03 pm
Although something like this may also work - less secure, but easier to stash about the car (on chassis)
[url= https://www.amazon.co.uk/Magnetic-Key-Extra-Large-Size/dp/B004DJ7WL4/ref=sr_1_2?s=automotive&ie=UTF8&qid=1503317124&sr=1-2&keywords=magnetic+key+box ]magnetic key box[/url]
Posted : 21/08/2017 12:06 pm
[quote=bikebouy ]Hiding key under/on top of wheel or under bumper.. well, can be ok but the wheels the first place anyone looks on the beach
I normally put my key in the spring next to the front wheel. Given nobody else has mentioned it I presume it's not the most obvious place for people to look. There are more obscure locations on the bodywork to hide a key if you're creative though. Alternatively under a nearby rock, though I get that's an issue if you have people looking for things under rocks - maybe not the best solution for the beach.
Alternatively I've taken my car key in a waterproof dry-bag designed for mobile phones when going sea-kayaking - usually also with a mobile phone in it. Though in that case it's just getting splashed or at worst in less than a metre of water if I get knocked in, not sure what depth such things are rated to.
Posted : 21/08/2017 12:22 pm
Every kayaker since the dawn of driving to rivers has used that - so common that people use it as a means to hide a key in plain sight. inside the bumper was slightly better...
if you lose the car (stolen) because the keys were left then isn't your insurance invalid ?
Posted : 21/08/2017 12:31 pm
This. My key has a quick release button which makes it dead simple.
Posted : 21/08/2017 12:32 pm
The key on the wheel has been used for yonks, hence it's well known place to look.. still doesn't stop some of my mates doing just that method... not me mind.
I use one of these (I mentioned above) you can get in it if you wiggle a screwdriver in between the flap and the box (it's a well known penetration method) but anyone willing to carry a screwdriver and ram it into the key lock is open to other beach goers scrutiny... or they may not say anything... but at least it's visiable as mines normally on the roof rack.. but mates do lock them onto door handles, and I've seen someone with thier door handle ripped off and the lock gone missing...
Generally (I say tongue in cheek) nobody ever hangs around or tampers with cars these days on beaches, you do occasionally hear of someone having issues, but I really can't remember the last time I heard of someone having their car broken into.. other than that lad who had his door handle ripped off (was in Newquay, so he may have pissed someone off on the water)
Posted : 21/08/2017 12:37 pm
 DrP
Make sure you get ribbed, for Junior's pleasure, though.
DrP
Posted : 21/08/2017 12:46 pm
Rent a Mercedes, a metal key that opens/locks the car slides out of the top of the remote fob.
Posted : 21/08/2017 1:09 pm
From memory, I think with every remote locking car I've ever had, separating the physical key from the remote was trivial. Usually a clip or button. It was so easy on my Hyundai that it used to separate in my pocket.
Posted : 21/08/2017 1:46 pm
So how do all these solutions work with a proximity key?
The keysafe won't work as too close to car - I guess if you were in 2 seperate cars you could lock them to each others!
If you remove the blade can you manually lock the door with the proximity key inside? You can't normally lock my keys inside
I use an Aquapac keymaster
EDIT - just tried with my blade and leaving the proximity key inside - worked fine! Thats great, as the key blade is much smaller and can get wet. Thanks for that
Posted : 21/08/2017 1:55 pm
I just leave mine under the towel on the beach.
Where I live too many reports of shmbags watching surfers place their keys under the car somewhere or in key safe (very obvious to see them do it) and it makes stealing the car in a very quiet area nice and easy.
Mean while when I put my towel down somewhere with key under its both discrete and make determining which car it is a bit harder - esp as I don't have remote central locking
Posted : 21/08/2017 2:33 pm
You could belt and braces that by burying the key (in a condom/balloon/bag or whatever) too.
Posted : 21/08/2017 3:41 pm
....I don't have remote central locking
Leave it unlocked with the keys in. Nobody wants to steal it 😉
Posted : 21/08/2017 4:12 pm
Au contraire. Seems theirs a healthy trade In land rover theft.
Posted : 21/08/2017 4:47 pm
Have kids: the endless amount of stuff you end up dragging to the beach is enough to disguise your keys from any family member who know without doubt where they are, let alone anyone who doesn't.
Also, hide the keys inside what looks like a used nappy, hidden with the actual used nappies. No one's looking there!
Posted : 21/08/2017 5:15 pm
Not snorkelling but... when surfing wrap mine up in lots of cling film pop it in the specific wet suit pocket job done.
Posted : 21/08/2017 5:45 pm
Usually cars with fancy keys have a simple basic key supplied as well, for emergency purposes like the main key being lost and the spare being elsewhere, like at home.
If the car's a rental, surely the company should supply the basic backup key along with the whizzy master key?
As someone said, some of the posher cars have a little key 'blade' that slides out of the main fob.
Posted : 21/08/2017 5:54 pm
Is a Fiat Doblo classed as posh?
Posted : 21/08/2017 7:01 pm
Doubt it.
Why lock it ?
Posted : 21/08/2017 7:33 pm
In 25 years of regularly driving hire cars all over the UK/ Europe, I've never seen it happen so far.
Posted : 21/08/2017 7:40 pm
The ones I've driven I wouldn't call that, but I hadn't noticed if they had the slidey-out key jobby, most cars I pick up have the full complement of two or three, I think it was on Mercs I noticed the extra key that slides out of the main fob, possibly a couple of other makes as well.
It's not something we're required to check for.
Ok, it was just a thought, I've only had one rental in my life, and that was tied to a trip to LA I won back in '93, before they had such things, so I've no way of knowing what they do now.
Posted : 22/08/2017 12:33 am
Excellent idea. Filled with helium, he could tie his keys to it and the other end to his snorkel and his keys would safely follow him around floating clear of the water. 🙂
Posted : 22/08/2017 3:22 am
2 freezer bags and double bag the key...cheap, light and very effective. Just make sure as much air as possible is removed in each bag and they are both properly closed then stuff it in your shorts.
Posted : 22/08/2017 6:14 am
Also these proximity sensor keys...
If you want them not to work, say because you are using a key safe thingummy or fancy leaving your key under the bumper or whatnot, well simply wrap the key in tin foil.
Ey, tin foil works a treat as it stops the signal see..
HTHs.
Posted : 22/08/2017 6:29 am
I usually solve this problem by having a car so shite that no-one's gonna steal it anyway - even with the keys in the ignition (which is where I normally leave them).
Works when biking/surfing.
Posted : 22/08/2017 9:43 am
