Tech question ... wifi and or Ethernet (SKY) working fine, Laptop (Windows 10) shows connected but no internet ?
Only recent updates indoors are a SKY box update.
PC has been fine but now, won't connect.
Ideas ?
Presumably already tried offanbackon ?
HAs your W10 decided it's on a public network rather than private ? Mine's done that once or twice
Sounds like your PC has the recent DHCP problem that was patched this week. Have search on Microsofts site for the cure. Then patch with the latest update and away you go. [url= http://www.theregister.co.uk/2016/12/14/microsoft_windows_10_dhcp/ ]Details and how to fix here[/url]
There's been a recent Win 10 patch that's broken DHCP and prevents computers from connecting to the internet. I had to fix my in law's computer (which involved running two commands) but I am damned if I can find it in my search history.
You could get round it by setting a static IP.
I had same problem and found a quick fix on Google. Had to change power up settings to don't do fast load or something. Think it was trying to use preloaded settings that were now invalid.
https://appuals.com/ethernet-doesnt-have-a-valid-ip-configuration/
First item on list, turn off fast startup
I've had to fix 3 laptops with this problem thank to our lovely friends at microsoft. I found the easiest way before the fix update was just to go into device manager and uninstall everything under network adapters, restart the machine and let them reinstall. Jobs a good un. Probably an easier way but did the trick every time! All were showing the wifi symbol with a yellow exclamation mark. Can see wifi network but no ip address.
