Skateboard (Cruiser...
[Closed] Skateboard (Cruiser) Wheel Question
4 Users
 Earl
Last summer I learnt to ride a cruiser board on a £50 D-Street. Recently bought a Penny Nickel an it rolls a whole lot better.
The D Street wheels are a bigger and 65mm x 78A
Nickel wheels are 59mm x 82a (I think its 82a as its not printed on the wheels)
Anyhow swapped the wheels (without bearings) over to the d-street and its rolls much better.
Am I right to day that its not the wheel quality but the hardness that makes a difference? I'm 90kg so the 78a wheels are getting squashed?
Posted : 15/02/2019 1:44 pm
I expect it is the hardness, or the bearings. Doubt you will squash the wheels though. By cruiser, do you mean a long board, or a standard deck with bigger wheels? I know what a Penny is. I ran large softish halfpipe wheels on a standard deck as a cruiser and never had any problems on all sorts of surfaces and I am quiet heavy.
If it's a longboard and you are doing serious speeds downhill then it might pay to be more careful with your choice.
Posted : 15/02/2019 1:54 pm
 Earl
Cruiser as in 32" and I'm just riding it around the park and town.
I tested with both the d-street and penny bearings and the Penny/nickel wheels were faster either way.
I'll look for some harder wheels then. I don't want to get the choice wrong as 1) cost, and 2) a set of skateboard wheels is fairly enviro unfriendly to throw in the bin.
Posted : 15/02/2019 2:22 pm
not sure if harder wheels affect the ride quality though. I wouldn't have thought that they'd make much difference though. They will last alot longer too.
I have a longboard with quite soft wide wheels on it as I think they grip better than harder wheels, although they are wider than standard wheels. I've never felt the need for faster wheels.
I am no expert although I do have some experience.
Posted : 15/02/2019 2:29 pm
A set of old school blue Kryptonics would probably do the trick, 65mm blue 85 durometer would probably be the best compromise.
I’ve still got my old board with a set of those on it.
https://kryptonics.com/wheels/star-trac-blue
Posted : 15/02/2019 2:38 pm
Surface has a lot to do with it. My old 70mm 78a kryptonics fly on typical housing estate chip n seal, but are slow on the smooth concrete miniramp.
Posted : 15/02/2019 2:54 pm
