Apparently they are suppose to be back online (from their instagram feed)
But I fail to see them on the online shop?
Anyone has seen them?
If you get one and it leaks and the handle falls off then it’ll be your own fault for having the wrong sort of kettle as they’ll have been unable to replicate the problem.
And you'll be called a freeloader for using it to drink tea instead of coffee...
And don't try and buy a copy because it'll say "<sub><sub><div><para>coffee ride...."
Good try but I'll still buy one had one big and chuncky from the SSSSDWC thingy back in the good old day and it was absolutely amazing.
If I use an adblocker will they just appear plain white?
Remember if you lose it, you can only start a search from the end of your street, as just searching your house will yield spurious results.
Don't forget it will value your privacy every time you have a cuppa.
Only buy one if it is Dracs. All the rest leak.
Oh, and if you ever want to sell it on. Just use eBay.
The wife dropped my latest mug. 😭
Remember if you stop using it to tell everyone, repeatedly or if mods send you a warning email back saying you were about to buy a mug but you're not now. Bonus points if you say every other mug works but this in unusable.
Be careful when pouring hot drinks into it, because it will suddenly move just as you start.
They should do a special edition Span Style mug
At least the mugs only propose riding and coffee, no mention of trying log on from a mobile device.
Do they allow you to ride and drink coffee at the same time?
Must work better than this place.
