SingleBaxicombiboil...
SingleBaxicombiboilertrackworld help.
7 Users
I suspect I already know the answer - "get a man in who knows what he's doing".
But, I have the low pressure warning light coming on even though the pressure gauge is high (much higher than it should be). Faulty sensor or faulty gauge or something else?
Posted : 03/04/2024 11:58 am
Pressure sensor person here.
The gauge is less likely to be faulty than an electronic sensor.
Posted : 03/04/2024 12:03 pm
although our old boiler (which we've had replaced) did have a faulty gauge (always showed low pressure) and the plumber said this was not uncommon with an ageing boiler... 🤔
Posted : 03/04/2024 12:07 pm
We had a baxi back boiler - be glad flames aren’t shooting out the side of it and you’re wondering “what’s that sooty smell?”
To be fair, it was probably close to 25 years old.
Posted : 03/04/2024 12:19 pm
Conversely on my old Worcester boiler the pressure gauge went a bit wappy, came back from holiday to find out that it had leaked. Replacement guage fixed it and was cheap from plumb centre.
The pressure light never came on.
Posted : 03/04/2024 12:21 pm
That's what I would have thought. I did the diverter valve last year so I might try replacing the sensor. I am very tempted to change the boiler though, it is getting on a bit. Has anyone any experience of heatable.co.uk?
Posted : 03/04/2024 12:29 pm
So... I knocked down the pressure to what I would consider normal by bleeding the rads. Fired up the boiler, low pressure light flashed a couple of times and went out. Turned on heating and it fired up straightaway. Hmm.
Posted : 03/04/2024 3:23 pm
Are you sure its a 'low pressure warning' and not a 'pressure out of range warning'....
Posted : 03/04/2024 3:43 pm
we still have, serviced yearly it's been running for a lot longer than 25 years (it was old when we arrived here 15 years back).
Posted : 03/04/2024 3:49 pm
Are you sure its a ‘low pressure warning’ and not a ‘pressure out of range warning’….
Well it's described as low pressure.
Posted : 03/04/2024 3:52 pm
we still have, serviced yearly it’s been running for a lot longer than 25 years
Look after it, and it will probably keep going - from what I recall it’s a pretty simple thing.
Sadly the one we inherited with our house hadn’t been, hence the flames.
Posted : 03/04/2024 5:07 pm
