Or is it the dirtiest way of producing energy known to man ? Sure it doesn't produce the easy to see pollutants of more traditional energy pollution , but there are the issues of containing the waste , which can be radioactive for thousands of years , accidents and leaks of radiation can , and do , also occur. What's the consensus on here ?
I think you’ve answered your own question there. If it produces toxic waste then it isn’t clean. Is it better than burning fossil fuels though?
Does sound a bit like you have made you mind up.
Ask the folks no longer living in Tchernobyl or Fukushima.
Or watch the coverage of the clusterf8ck of nuclear waste recycling that is Sellafield......
It’s not clean but it produces a lot of energy and doesn’t produce emissions.
Yep. This might be a lesser of two evils thing. Of course, we should try to reduce consumption and we should be prepared to spend more on renewables. Looking at the cost of nuclear (and nuclear research), if we'd been spending that much on renewables research then things would now be a lot better.
Nothings clean everything has a byproduct.
Just depends which ones most palatable to you
I think nuclear is important as part of a wider energy resilience
It has pros ace cons. I don’t think its one or the other
The uk has lots of horrible waste to sort out. It’s expensive. There is the risk of accidents. It’s not really a solution for the world. Most countries didn’t have access to it.
But it is low carbon
I think the uk were fine for one more generation if power stations. I’m just annoyed the decision was made late so we couldn’t develop our own new technology and ended up buying in the tech
Which one has the lowest impact potential should be the main driver. Health of people and planet should come first. Does that mean nuclear, wind, solar, wave, fossil etc? They’ve all got pro’s and con’s to them. Fossil fuels clearly aren’t great for starters. Nuclear seems good but if things go a bit wrong the shit hits the fan big time.
Ridiculously safe compared to coal, oil, gas. Tiny amounts of waste, like a few hundred cubic metres for everything done worldwide ever, compare that to huge spoil heaps around every mining town. I'd have one of those small modular reactors Rolls Royce were touting on the edge of every city.
@drac it doesn’t produce carbon emissions (although it does, everything being done to manage the waste at sellafield is being powered by a gas fired power plant) but it does produce significant quantities of aqueous emissions and, despite filtration, some emissions of radioactive material to air but the big issue is the waste.
How clean does clean have to be? We are inherently dirty as a species just by our existence.
One day we'll probably create the technology to clean up radiation or something.
High level waste perhaps but there are thousand of tonnes of low and intermediate level wastes at drigg and other sites, all of which requires active management fro another 100 yrs plus
the high level stuff is going to need a geological disposal facility which will cost tens of billions, whereas Yorkshire’s coal tips are now parks and housing estates.
Yes, it produces no emissions, waste can be managed effectively and if we progress it as we were pre Fukushima, we'd be in a decent position for the next generation or two. Through life management is required and costed at the outset, it all falls apart with historical arrangements that tend to leave the bill with the government
Not against it btw but you have to be honest about the impacts
So what, sounds like a very small problem to me, a basic warehousing and access control issue.
I suggest you give Drigg a call and let them know
The active management is up to disposal, when it's in the ground the management tends to be over, bar the usual site assessments, we do it better than a lot of others, who tend to just find a mine, chuck it down there and then pour concrete!
Wrong. No active waste is in the ground in the uk (we’ll mayb some stuff from the 50’s/60’s) all the stuff at Drigg is above ground, containerised and monitored continually. The high and higher intermediate level stuff is still on site at sellafied. They’re encapsulating it in 3m3 boxes filled with concrete and then storing it in facilities, there are 3 encapsulation plants and about a dozen product stores working or in construction. These are replacing the silos built in the 70’s 80s that are dropping to bit and each facility costs ~£1bn. The only reason they’ve built these stores is that getting the geological disposal facility built before the MSSS and other silos disintegrate is proving impossible as nobody wants it in their backyard.
admittedlythey could do what the Russians and the septics do, as you describe, but would be very illegal over here
Yes, but isn't the plan to do this by 2030 or something at Drigg, as it's meant to be closing down at some point, not looked at nuclear stuff in years to be honest, so have no clue what the future plans are these days, bar that we're behind whatever plan we had by at least 10-20 years now.
When it's in the ground.......
But most of it isn't in the ground...not anywhere near...and that's going to remain the case for decades to come if not longer
And as for building new nuclear, we'd be better off spending billions investing in renewables of all types, and getting a rapid return on it, than spending billions on not quite building sizewell C.
2030- ROFLCOPTAZZ
The product stores they are building now are designed to last 50-100years so that tells you something about how optimistic they are about the GDF
I’m not anti but anti think people are down playing the waste.
I was involved , as a teacher, in the consultation about what we will need to do with out waste. The consultation was really to fund out what the students thought.
Storage I’d likely upto 100,000 years. The problem is that anything other than deep burial assumes a continuity in out society. The consensus is that on these time scales we can’t assume that continuity. I remember the look of anguish on a 14 year old girls when asked “If some one is harmed by the waste in 10,000 years do we have have a moral responsibility.”
I think it’s questionable that we are building more capacity with out worksble plan for the waste.
I meant closing down to any new arrival, so a locked site after that, not abandoned, not sure what the plan was for future disposal, again going out of scope of the question again, as there has been no issues with the storage at places like Drigg from what i remember.
It’s not sustainable. With current gen2 and even gen3 reactors and the latest reprocessing, there’s around a 100-160 years of fissile material available in the crust and that’s assuming CURRENT levels of consumption.
Low level waste has to be continually guarded as it’s easily incorporated into dirty bombs, this vastly increasing their effectiveness for area denial. This massively increases disposal and storage costs.
The environmental footprint of a modern reactor build is absolutely bloody enormous. A single reactor like HPC is an order of magnitude worse than all the offshore wind turbines that all of norther Europe have installed.
I’d prefer us to install more wind and just burn gas until such time as chemical or electrical energy storage can be scaled to fill the gap.
Nuclear is a knee jerk reaction to on demand energy (which it still can’t actually provide) with a MASSIVE head and tail that substantially outweigh its benefits.
That's a hypothetical harm against a current and ongoing harm caused by our use of fossil fuels.
The solution to waste storage is plasma drilling technology and then to dump it in the mantle. That’s the only long term storage solution.
Yeah sorry, conflating two things, the LLW at Drigg will likely go for landfill or incineration dependant on characterisation but it’ll still cost millions to store it until then and require new facilities to do the disposing
i can see the high level stuff being lost in a subduction zone once the roofs start caving in on the product stores c.2150
Renewables are great, but we will need something to power us through windless nights and (especially) windless stints in winter. We will also want a whole bunch more power in the future for our EVs and heatpumps. Nuclear is far from perfect but is much better for the planet than fossil fuels.
I agree with the concerns over storage. It seems like we’re just passing the buck to our kids and their kids.
As far as I can tell, the geological disposal facility is nowhere near being decided and will likely be in an area of low population with potentially complex geology, rather than a geologically more appropriate site.
The comment about no waste tips like coal is wide of the mark. Uranium is mined so also results in large mine waste dumps in parts of Canada, Australia, Niger, Kazakhstan etc.. just not Yorkshire, Notts etc..
there is CO2 produced - in the building and commissioning of the plant as well as in generation but total lifespan orders of magnitude less than fossil fuel. Radioactive waste no one has come up with a proper solution.
A single (quite big tbf) oil refinery can cost 15 times that.
Every form of power production is dirty if you start looking at building and commissioning, especially when you're talking the levels of rare earths and metals that we're using for a lot of the green energy production, there's a lot of pollution and contamination, but that's in other countries i guess, so at least here we can talk about how green it is.
I don't like it but I think it has its place at the moment, hopefully it will die out as we get more renewable sources and grid storage.
Out of interest, how many of the 'very against' posters have deliberately chosen a nuclear free green tariff? (As opposed to a green tariff that may include some nuclear) And who does them, I'm currently with EDF so the majority of my energy mix is 'carbon free' and of course a large portion of it is also nuclear.
I have to teach this at a basic level.
I feel quite strongly people need to know the pros and cons.
I come down in the side as uk nuclear being just better than fossil fuels. But i wouldn’t want to sell it like a used car
I am an engineer and strong supporter of renewables.
My take is that nuclear is relatively safe, far more harm is caused by extraction and burning of fossil fuels, just as an everyday background that doesn't make the news.
Having said that I do not support nuclear development as I do not consider that we should be generating products that will be harmful for hundreds of years. That just seems like pushing the problem onto future generations.
Just my input, I do not consider the choices available to be simple black/ white.
I suggest people might want to have a look at David Mackay's book (downloadable free from https://www.withouthotair.com/). He was a Departmental Chief Scientific Adviser and I always felt had a very objective view of energy matters. The book is a bit dated now but the basic facts and arguments still stand.
One thing which is not clearly appreciated is the scale of our current use of fossil fuels- only about 20% of current energy use is electricity, much of which is generated by burning gas, and an awful lot of the remaining 80% is also fossil fuel. When you start to think about a 100 GW grid, or large scale hydrogen production and distribution, things get prohibitively complicated and you find you need a North Sea full of large offshore wind turbines or a Wales covered with solar panels. It is very difficult to devise a credible net zero energy mix which provides energy in the quantities we require at reasonable cost.
Of course, one of the difficulties in all this is that opinions reflect 'heart' or 'head' and there's no point trying to rebut 'heart' opinions with 'head' arguments, and it's very easy just to talk past one another.
Fusion must be just around the corner. Surely by now.
Will be interesting to see if the current government’s policy of funding early stage design of small nuclear ever leads to anything tangible. Rolls Royce and Hitachi seem to be taking it seriously.
I'm not well enough informed to give a valid opinion, but the WHO estimates 6.7 million deaths per year from air pollution, mostly caused by burning fossil fuel. Some studies think that number is too conservative. So that's what we should be comparing nuclear against.
I think you haven't to forget that a chunk of the Sellafield (insert previous names here) site legacy is because it started as a production site to urgently produce nuclear weapon raw materials with electricity generation as a useful by-product (with very little consideration of the waste generated). This was then followed by various good ideas for power generation that never quite made it to widespread acceptance. I've no idea how this compares to the waste from current designs, but unfortunately it all now needs dealing with.
Our eldest is one of a wide ranging PhD cohort working on some of the current and future problems from this legacy. So I'm slightly encouraged that at least they aren't ignoring it and actively addressing the need to home grow the future workforce to continue dealing with what they have created.
Can't keep burying the waste. It's too dangerous a substance to be 'out of sight, out of mind' and takes so long to decay its likely there wont be a human race to say thats it ok now.
At least fusion reactor power is only 20 years away...
Dpfr has the nail on the head, we have a serious amount of energy needs in the next 25 or so years and we need to invest in EVERYTHING if we want to be able to produce what we need.
Full disclosure, I'm in the industry, technical now but was previously a plant operator. You have no idea how tightly regulated we are, a lot of that low level waste (that incidentally is bloody useless for a dirty bomb, you'd be better stuffing fireworks into a dog shit bin) and emissions is lower activity than households and industry chuck out every day and we have to account for all of it. Hands up who ever threw a smoke alarm in the bin? Yeah, that Americium-241 is nuclear waste and has to be sent to Drigg even if it came out the canteen.
Gen 2? Things have moved on a lot and what we (as in the UK) have is a lot more robust than a PWR with no automatic shutdown system. Yes, SMRs are in the pipeline and some of the more conventional PWR types are going through GDA (Generic Design Assessment), there's an LFR (Lead Fast Reactor) been put forward for Justification (basically DEFRA decide whether that reactor type would be allowed to be developed. No, I have no idea why they are involved.) which looks pretty cool and has obvious safety benefits.
So yeah, it's not a case of one or the other, we need everything and we need it yesterday.
Afaik, nuclear power isn’t the carbon neutral panacea.
By the time the Uranium is mined and processed, it’s generated an equivalent amount of co2.
After a wee sojourn to Amsterdam in march, I’d say that UK road traffic will require a staggering amount of electricity, but the Dutch approach to transport is long overdue.
Can’t keep burying the waste. It’s too dangerous a substance to be ‘out of sight, out of mind’ and takes so long to decay it’s likely there wont be a human race to say thats it ok now.
I tend to agree. I remember watching a program on Horizon (or similar) many years ago which was explaining the plans for designing a nuclear waste storage site and how to stop future access in 100,000 years when you might not have any currently known languages and they might not know the hazard symbols etc we currently use.
Like Cornwall, for example? Houses there have to be properly vented due to radioactive emissions from the granite underneath.
Have a read of this, see what you think; this popped up yesterday.
https://arstechnica.com/science/2024/05/two-seconds-of-hope-for-fusion-power/
This is not a place of honor...
https://en.m.wikipedia.org/wiki/Long-term_nuclear_waste_warning_messages
Fusion is still in the realms of sci-fi. Even if someone manages to prove that it is technically possible to produce a self-sustaining fusion reaction that is a net producer of energy, there are even more technical barriers involved in scaling it up to being commercially viable that are just as big as the ones that so far have taken us 60+ years to solve.
Currently living in the down under home of climate change deny....nuclear is being proposed as clean power...I had a nuclear power no thanks sticker on my first car and recall following the early 80's Sizewell B inquiry...one of the longest public enquiries ever I believe. We were promised waste wouldn't be an issue...technology would fix it...
For me interest -
To generate the same amount of electricity, a coal power plant gives off at least ten times more radiation than a nuclear power plant.
Out of interest, how many of the ‘very against’ posters have deliberately chosen a nuclear free green tariff? (As opposed to a green tariff that may include some nuclear) And who does them
Good Energy do one. I'm not 'very against' but that's the leccy tariff I'm on. Quite expensive as they're not bound by the cap (bah) but on the other hand, very good customer service at least!
Sellafield is the consequence of a nuclear arms race, not atomic energy. I don’t think you can count it towards “nuclear power is evil” in that regard.
Works fine in France. Wouldn’t be bothered about having one in my back yard from a safety perspective, nor any concern about living near a nuclear waste storage site. Although I don’t know why you’d want to store it since dropping it into the sea in a subduction zone would recycle it nicely.
The most convincing idea I’ve heard is burying it deep enough that geothermal heat is sufficient to deter access (eg 80-90C).
well, someone turned the entire wtc complex into dust on 9/11.
Regular background radiation levels, but an abundance of tritium.
tbh, there’s something inherently spooky about nuclear fusion…levitation, ‘pulling’ atoms from out of ‘nowhere’, etc.
As well as mirroring the claims of medieval alchemy, it makes the claims of ‘free energy’ seem relatively mundane in comparison.
Yes, by flying two planes into it and then it collapsed.
The David McKay book that @dfpr has suggested is brilliant. I read it prior to starting my MSc in Sustainability. Like he says, it's a great overview of Energy in the UK. Fairly sure @dfpr is a Professor with expertise in Nuclear, so probably a good poster to listen to on this subject!
A fascinating problem, 100,000 years is difficult to imagine but 100 000 years ago early 'humans' were just about leaving Africa. Because of the language issues mentioned by J4amie it has been suggested that a 'religeous' order be set up to live above a deep waste facility, the Atomic Priesthood being a proposed system of communicating the history, infrastructures, and science of nuclear waste materials on geologic timescales through the use of ritual, allegory, and superstition.......................
If you bury it deeply enough, only civilizations with advanced technology will be able to access it. They will understand what it is.
One thing with nuclear waste is that the most radioactive stuff has a very short half-life so it will be harmless within decades. The stuff with long half-lives is much less radioactive, that's the stuff that will still be around in tens of thousands of years.
he most radioactive stuff has a very short half-life so it will be harmless within decades. The stuff with long half-lives is much less radioactive, that’s the stuff that will still be around in tens of thousands of years.
So Finland is wasting millions in building a long term waste facility then???????
Half-serious, half-joking question: if there’s so little atomic waste, can’t we just fire it off on a rocket into space?
Have you seen how much fuel a rocket burns?
No one wants to pay for that when you can just bury it or ship it to a different area.
Elon Musk is missing a trick here.
They've been talking about burying it for decades, but it never seems to happen because it's so damn difficult and expensive.....
Not forgetting the vast public subsidy required to make it economically viable, with a strike price getting on for twice that offered for offshore wind.
Not accepting that without facts, "AFAIK" isn't good enough. You could fit the core of an EPR into a very small cube and only partly refuel it every 18 months. That's a lot of fossil fuels.
But the stuff that takes millions of years to decay is much less radioactive than the stuff that decays in a few years.
Not true. You're thinking of intermediate level waste like the graphite core and stringer bits. That's your 70-100 years timescale hence why AGRs and Magnox take so long to deconstruct. There is some high level stuff that decays away fast but that gets addressed either post-trip or in the fuel route after it gets sent to the ponds. The actual stuff in the fuel besides the uranium and plutonium is the geological scale stuff and is highly radioactive.
If you don't believe me look at the table of nuclides, you can use it to plot the decay path from Pu or U all the way to stability.
https://www-nds.iaea.org/relnsd/vcharthtml/VChartHTML.html
Breeder reactors aren’t new, it’s what France has been trying to develop for over 20y in order to reduce their nuclear waste stockpile. It’s what we had a Dounreay (weapons research) in a smaller form and it’s what the Indians, Russians and Chinese now have the lead in, but, it’s still not commercially capable. They’re loosely referred to as Gen IV reactors.
I was all for nuclear if the UK Gov had been willing to invest in that technology. It decreases the current waste and relies less upon new fissile material as it’s capable of using “spent” fuel.
Saying that, even Gen III reactors are rare, so can you imagine what it would’ve cost the tax payer?
Dounreay isn't a weapons research facility, the only military activity up there is HMS Vulcan next door who develop reactors for submarine propulsion.
Gen III isn't that rare either, they've been knocking them out since the late 90s.
On breeders, Superphenix was actually commercially proven by the time they got it working but it got canned for political reasons, most of the later downtime was down to politics rather then technical difficulties.
I'm quite a believer in nuclear energy, I view the fact it's a zero carbon form of grid energy is more important than whether it meets the more loose definitions of 'green' or 'clean'.
I think main the arguments against include are the safety piece, but here in the UK we have some of the most stringent regulations in the world and have never had a major radiation incident in either a commercial reactor or a submarine. Windscale is often cited but it was so long ago when nuclear theory was less understood in a rushed military plant. Chernobyl was a completely different design to modern PWRs and even then operator error/procedure was a primary cause. Fukushima took a Tsunami and earthquake to cause issues which could have been avoided by better identification/management of the flood risk.
Then you have the waste question, which is tricky but honestly to me boils to down asking whether future generations would they rather some waste stored deep underground or an increase in the impact of climate change, and the former to me is the better choice. This does need proper investment however into suitable storage.
I think the most valid argument against nuclear power is that it has a high CAPEX compared to most renewables and that could be money better spent elsewhere. I think that does have some legs though I also think nuclear power is immensely useful in a zero emission grid to act as that base load. In the UK we lack the hydroelectric or geothermal resources that can do that, though I am also very frustrated the Swansea Tidal lagoon was scrapped, and tidal should be something explored more.
Gen III/3+ is still pretty rare. There are are only 2, maybe 3 non Chinese developers of Gen III and there are very few western installations of them anywhere. I think HPC will be the 3rd in Europe and the previous two (Finland and France) were 7years late, vastly over budget and incurred several compromises on their way to commissioning.
For Dounreay, I meant military, not weapons.
EDF have stated that the Gen 3+ is prohibitively complicated for them to make commercially viable at current power generation costs/rates. That in itself says plenty.
ABWR as built by the Japanese and Koreans is Gen III as are plenty of Russian VVERs, there's a wiki list which shows who has built what. EPRs and AP1000's are Gen III+.
And it's still not that, the military site is HMS Vulcan next door. Dounreay was a civil research facility.
Wasn't the Swansea tidal project a massive grift? I think private eye wrote extensively about it.
I view the fact it’s a zero carbon form of grid energy
Its not. Its lower carbon but not zero. a lot of pollution in the lifetime of the plants.
We have had several serious radiation spills and still have loads of reactors to dismantle yet.
Up to a point. It's heavily reliant on imports and exports from other sources (and countries) to balance the grid, and is vulnerable to high river water temperatures in heat waves.
The same is true for solar and wind. Don't make perfect the enemy of good.
co0rrect. But understanding all energy comes at a carbon cost stops greenwashing. the only sustainable solution is use less energy.
The only sustainable solution is use less energy.
When is it that the EU/UK/US want to go fossil fuel free for transport and so on?
Using less energy as a nation that is growing, is not going to be an option!
Gigadeath then. those are your choices
