I have a small shaft that needs building up where it has worn under an oil seal and seized bearing. 20mm dia shaft and about 15mm length needs building up by about 1mm. I can machine it back. Anyone know anyone in Sheffield who could do this?
Cheers!
ive used these previously with good results
Is brass going to be durable enough? For crankshaft repair, usually it’s a weld and re grind job - so maybe some sort of automotive specialist?
I do a bit of brazing & have a workshop up off Norfolk Park, drop me a line and I'll see what I can do.
I used to get a lot of emails offering that kind of result…..
Used to? So it works then?
Cheers all, and thanks for the offer podge. I knocked up a brass sleeve on the lathe so will see how that fares for now. The shaft is from a pillar drill so it's not going to be seeing masses of use, and a slow oil leak will just lubricate the quill...
