Seagate hard drive
[Closed] Seagate hard drive
2 Users
I have a 3tb seagate desktop hard drive, the connector on the back was getting a bit flaky so i took it out of its enclosure and bought a Probox enclosure for it. I've just tried it on my PC and it says I need to format the drive before i can use it.
It that how it has to be? It'd be better if i can read whats on the drive (although its backed up elsewhere).
Posted : 18/12/2016 10:43 am
I can't immediately think of any reason why that should be the case other than a faulty enclosure. Does it work if you put it back in the old enclosure again?
I'm assuming they're both USB > SATA and there's no sort of encryption in use?
Posted : 18/12/2016 11:57 am
I'll try it back in the original case and see what happens.
No encryption and USB/SATA although the original enclose had one of those flat style USB connectors with the little bulge on one side while the new one is USB3 with a square connector.
Posted : 19/12/2016 12:49 pm
