Scart to VGA (and a...
[Closed] Scart to VGA (and audio) conversion
6 Users
So, I've got a Bush Freesat box, and an old LCD monitor with built-in speakers I'd like to connect together. The monitor has integrated VGA cable and a headphone plug.
I've tried a HDMI to VGA converter which didn't work. The Freesat box also has Scart output, so being analogue already, I reckon i might have a better chance with that.
Any ideas how to go about it? I can't find any converters to do exactly what I want, I'm thinking converting to RCA an then to VGA might work
Posted : 26/08/2012 8:15 pm
tbh I think you will struggle to find anything. There was a thing years ago called a cheesebox that converted between old TV and VGA signals.
Probably less hassle to buy a cheap LCD TV.
Posted : 26/08/2012 8:24 pm
less hassle but more expense, not to mention having to get rid of a perfectly good monitor that just isn't needed any more.
Posted : 26/08/2012 8:36 pm
thanks falkirk-mark, obviously I've seen all the stuff on ebay. The problem is getting the audio out at the same time.
I was hoping someone here might have done it and know of an amazing box of tricks that will do exactly what I want: Scart in, VGA and headphone socket out.
Posted : 26/08/2012 8:42 pm
You could just break into that SCART wiring loom & dab some on for the speakers onto a 3.5mm jack. You'd only need a few to do it.
Bit dirty but with some heatshrink over the lot might look ok. ish.
Posted : 26/08/2012 8:45 pm
Is there no separate audio out on the Freeview box?
Posted : 26/08/2012 8:47 pm
There's SPDIF
dave rudabar- how easy is it to locate the audio wires?
Posted : 26/08/2012 8:50 pm
Does the box output RGB?
That would probably be easier to convert to VGA
Posted : 26/08/2012 8:54 pm
Nope. Its got HDMI, Scart and SPDIF outputs.
Posted : 26/08/2012 9:17 pm
jota180 - Member
ir_bandito - Member
I meant RGB via the Scart [pins 7,11 and 15]
The box may well allow RGB output, then again, it may not
Posted : 27/08/2012 10:21 am
Off the top of my head, I'd expect HDMI > VGA to be the preferred route. SCART > VGA will require an analogue to digital conversion and thus will either be expensive or rubbish.
Posted : 27/08/2012 11:28 am
That Amazon gizmo does the conversation the other way to what he wants
Posted : 27/08/2012 4:05 pm
Ah, good spot. Bother.
Posted : 27/08/2012 5:24 pm
I would think anything that looks like a cable with a scart one end and VGA the other will just be a cable to adapt connection types and not actually work. Audio from scart is easy. Can be as simple as a scart splitter box with a scart to audio cable or get a male to female scart cable first and break out the audio.
Posted : 27/08/2012 5:45 pm
some of these should do it: http://www.ebay.co.uk/sch/sis.html?_nkw=External%20CRT%20VGA%20PC%20TV%20Tuner%20Box%20NTSC%20PAL%20I%20B%20G%20AV%20In&_itemId=300307437052
You can get a scart connector which has S-video and RCA audio output which can go into the right box to connect to the lcd via VGA.
Or there is this thing: http://www.ebay.co.uk/itm/1080P-PC-HDMI-to-VGA-3-5mm-Audio-HD-Video-Converter-HDTV-SKY-DVD-PS3-Apple-TV-/320929883993?pt=UK_Computing_Sound_Vision_Video_Cables_Adapters&hash=item4ab8e96759
tbh I have no idea if it will work. Video conversions can be a bit ropey to achieve.
Posted : 27/08/2012 5:58 pm
