Samsung washer issu...
Samsung washer issues
4 Users
4 Reactions
So, the liquid detergent dispenser on our Samsung washing machine keeps filling with water - not sure why. Anyone else had similar issues and what was the solution? Thanks!
Posted : 19/10/2024 9:50 am
Sounds like it's blocked, take it out and give it a thorough clean. Should slide out if you release the clips on the sides.
Posted : 19/10/2024 10:15 am
leffeboy and leffeboy reacted
Yes, we've tried that, it's recurred fairly quickly. Could it be blocked downstream and is that an easy fix?
Posted : 19/10/2024 10:21 am
You could try running some empty cycles with soda crystals in the drawer, that should help clean out gunk downstream.
Posted : 19/10/2024 1:34 pm
Yes try regular boil washes empty with dishwasher tablet, or drop a load of white vinegar in the drum and run empty.  Gunk builds up on 30 degrees washes.  Clean out the filter at drain plug too, they are usually minging.
Posted : 19/10/2024 1:45 pm
It’s not a standard drawer, more a tank that should be full of liquid detergent but in practice is full of water. I’d be a bit worried that soda crystals will just sit there?
Posted : 19/10/2024 3:10 pm
Maybe put some in the powder compartment and a bit more straight into the drum, run it, and see where you are then? They will disolve in hot water, so it might kinda backwash your liquid tank? just a thought...
Posted : 19/10/2024 3:16 pm
