Running Shoes - Fla...
[Closed] Running Shoes - Flat Feet
8 Users
Hi all,
I was hoping somebody could recommend me some running shoes for flat feet.
I get pains in the outside of my knees when running and also in my metatarsals which I believe is caused by flat feet.
I would like to keep the cost under £100 and preferably around the £60 mark. I am not too fussed about how fashionable they are either.
Thanks all
Posted : 09/03/2015 9:44 pm
Best to seek proper advice from a running shop so you can try them on.
Posted : 09/03/2015 9:49 pm
I had my running style analysed a few years ago in a nike running shop and they recommended me some nike lunar eclipses.
Was kind of hoping I could order a pair online without having to go into town.
Posted : 09/03/2015 10:29 pm
Is running gait analysis really that helpful? Try on loads and see which feel most comfortable is my approach.
Posted : 09/03/2015 11:10 pm
Err - you can! http://www.sportsshoes.com/nike-lunareclipse/
Gait analysis is useful yes. It helps you buy a trainer which is designed to work best taking into account the way your feet strike the floor whilst running, which is usually different to how your feet move around/strike the floow when walk.
If you buy the wrong type (like i've just done with my trail trainers!), you can end up with sore feet, painful arches, and a whole host of other ailments, etc..
Posted : 09/03/2015 11:15 pm
Flat and wide feet here and suffered all sorts of pains when running. Did the gait analysis thing and now have no issues at all.
Ended up with a pair of Ascics GT1000 (I think. I'm at work)
Posted : 09/03/2015 11:20 pm
I don't think I'd bother with running shoe shops as a first step if you're hitting this issue. First, find a good local orthotist, get them to sort you out, then choose the shoes. You may have more issues going on than the shop will pick up.
I had an old left ankle injury that I thought had fully healed, but found a while back that any distance over 13 or so miles brought the pain back. Running shoe shop was helpful with gait analysis and recommended a supportive shoe, which helped a bit.
But the pain got worse, despite the shoe. The local orthotist did a full gait analysis, and a bunch of other tests, and my left arch is pretty much collapsed: no shoe on the planet will help with this. So, I've now got insoles to wear (partly custom-made) which have really done the trick. Unfortunately, I need to wear them all the time, in all shoes.
I'm not saying the shop wouldn't have picked this up of course- they might have done. But the orthotist does this all day every day.
Posted : 10/03/2015 8:54 am
Shoes can help but its what's going on above the foot thats most important, most likely your glutes and stabilising core muscles that have a biggest impact on knee pain.
A good running shop is a must, some are better than others. Whereabouts are you?
Posted : 10/03/2015 9:09 am
I had some really bad knee issues, but I found some really useful stretches to do, and worked on stability and the fine muscles and it has improved, I no longer have knee pain.
I found a mix of stretches and a wobble board helped (can be found on physio room) Doing one legged squats and standing squats on the board helped. Along with stretching the glutes and the ITB. Plus find a good sports massage!
Posted : 10/03/2015 9:18 am
