Runners: Carrying w...
[Closed] Runners: Carrying water
31 Users
At what point (meaning length of run) do you start taking water with you? When you do take water, what do you use? A bottle? A Camelbak? Recommendations?
I really don't fancy carrying a bottle with me so I'd probably err towards a Camelbak-type arrangement myself.
Posted : 24/05/2015 4:30 pm
Only for 1+hour runs only, and yes, a camelbak.
Running carrying stuff is a PITA and it makes **** all difference to your performance (and a little to your recovery) for a shorter run.
Posted : 24/05/2015 4:34 pm
I carry water for runs that last more than 90 minutes or so. I have a waist belt bottle carrier which is good for shorter (<2hr) runs, and a camelbak style thing for longer.
I've just started using a bottle (the running ones, with a 'monkey' grip.) Holds 500ml, wasn't an issue at all (carrying it)
I can only imagine running with a camel back would be even worse than using one on a road bike?
Posted : 24/05/2015 4:40 pm
That sounds about right. I've just done a 1.5hr run (20km) and it's the first time I've wished I had a bit of water with me.
I've looked at those belts before: Do you notice them much? They look a bit uncomfortable, certainly compared to a Camelbak-type thing.
Edit: I have no problem wearing a Camelbak on the mountain bike.
Posted : 24/05/2015 4:42 pm
I only take water for runs over 2hrs, then I use a small (about 1 litre) Decathlon camelback job.
If you 'bleed' the air out of the bladder upside down they are actually nicer to use than a bottle in one hand.
Matt
Posted : 24/05/2015 4:49 pm
Depends on the model, I had one (cheap Decathlon) which was awful, another (also Decathlon) that was OK but died, and now have a Salomon belt which is fine. Obviously not as comfortable as running without, but not an issue. And a lot better than running with a bottle in your hand.
The Salomon backpack I have is pretty comfortable too, your back does sweat a bit but it's not something you particularly notice when you're running. The new Decathlon running backpacks are getting good reviews, a couple of friends have them and are very pleased with them.
Posted : 24/05/2015 4:54 pm
I think the answer is it depends on you. you could say only long runs but when I was running in Cyprus (or UK last summer) in 27 degree heat I'd carry one for short ones too.
I hate carrying a bottle in my hand find it incredibly uncomfortable so you need to find what works for you. I have an ironman running belt which holds three small bottles which is good and doesn't move about. I also have a camelbak style bag (cheap from Decathlon) for longer runs however the sloshing noise I find quite irritating sometimes. You can train yourself to drink less depending on the circumstances etc.
Posted : 24/05/2015 4:57 pm
Up to a certain point - your body does adapt to warm weather - but there are limits.
Posted : 24/05/2015 5:00 pm
I guess something like this would be OK:
[url= http://www.camelbak.com/en/International/Sports-Recreation/Packs/Delaney.aspx ]Camelbak Delaney[/url]
Posted : 24/05/2015 5:03 pm
For trail runs of over 60mins I use a waist belt with either a .5ltr or 1ltr bottle. The belts a good fit, tight and comfortable. It doesn't "wobble" much for me, in fact once it's on I don't really notice it. The bottle is angled at about 30 degrees in the sleeve so easy to reach behind with my right hand and grab the bottle, easy to slip back in too. Also it's got a small elastic retainer that slips over the nozzle to hold in place when bumpy but invariably I don't need it.
Posted : 24/05/2015 5:06 pm
Up to two hours in training then nothing.
I use a 1liter Camalback for trail races over 20km, depending on race facilities.
I've tried good waistbelts but found them to move too much.
Posted : 24/05/2015 5:09 pm
 cp
Over an hour for me. I use a small 1 litre camelbak type thing for anything more than an hour.
Carrying water, what? As a once usefully fast club runner, I can't believe the nonsense I've read here. Trendy joggers, that's what you all are.
Posted : 24/05/2015 5:22 pm
A mate who was training for a marathon left plastic bottles (old coke, 7up etc filled with water) outside his house and did circuits which brought him past every x minutes/hours so he could grab one as and when needed. He's just dump them in a bin once empty.
Posted : 24/05/2015 5:37 pm
oldboy - Member
You are Alf Tupper and ICMFP.
Posted : 24/05/2015 5:41 pm
mickey74, I've got one of those Delanys. They're comfy, and you can get keys in the wee pouch, the bottle is too big for the holder though, and as it doesn't have a strap, it gradually bounces out. I use it now only with a smaller 1/2 Lt. bottle which sits deeper in the holder and doesn't bounce about nearly as much.
Good info, cheers. I don't think I'd need anything more than a 1/2 litre bottle anyway. I do notice that Salomon and Deuter also do similar alternatives so they may be worth checking out.
Posted : 24/05/2015 5:44 pm
I found once I CBA carrying water I wulould drink a lot, why not? (It'd usually be energy drink).
As for oldboy, your willy waving response time is a disappointment.
Posted : 24/05/2015 5:54 pm
I have an Inov-8 waist belt which is super solid.
If over an hour and warm I carry 2 old fruit shoot bottles, nice small size to stop a dry throat!
Bigger bottle if longer, don't enjoy the camelbak sloshing around!!
Posted : 24/05/2015 5:59 pm
 Kuco
Got a Salomon waist belt. Not used it yet as most runs are just under an hour but I couldn't resist it when it was in a sale for £10.
Posted : 24/05/2015 6:18 pm
Is that the Race Ultra 1 Matt?
Posted : 24/05/2015 7:34 pm
 ajc
In summer I take a drink over about 8 miles, but more like 12 in winter. Also depends how hard you are working and amount of hills. I have a waistband with 2 small bottles which I prefer to 1 large one. Not tried running with a camel back although see most long distance runners round here with them. A 50 miler went past my house this weekend. Most with camel backs.
Posted : 24/05/2015 7:37 pm
I always take water in varying amounts regardless of the length of run. I sweat a lot and always feel thirsty at the end of my first climb at the start of my route. I only sip at the water but feel better for doing so just get rid ofthe claggy mouth/ throat.
I started with one of the oval runners bottle but found the spout a pain to use. I now use the Camelbak Quick Grip which uses a Poduim Chill bottle and a bite valve. It felt a bit odd to use to begin with but is so much easier to drink from.
Posted : 24/05/2015 8:49 pm
These are spot on for long runs where you just need to fend off thirst in the last 1/4
Stick it in yer pocket when its gone
Posted : 24/05/2015 8:52 pm
Waist pack for me, you just have to find one that fits and doesn't bounce too much. Only take it for 2h plus runs or very hot days, and can't remember the last of those! Partly do it for the practice as I need to eat/drink on the move in a marathon. I'm thinking of carrying a small empty bottle if I do another marathon so I can pour a plastic beaker of water in and drink properly rather than spill it all over my face like I usually do.
Posted : 25/05/2015 7:54 am
After about 2h, bit less if it's hotter. Bumbag with a soft bottle so it crushes down without sloshing. Long day in hills small omm rucsac
Posted : 25/05/2015 8:19 am
 tomd
My old man in his marathon days used to swear by a sandwich bag filled with a few hundred ml of water and knot in it. He'd carry it for 45mins / hr the drink it and bin the bag. Just enough to keep the thirst off.
Posted : 25/05/2015 9:16 am
Now I'm in the >2hr run range I've started carrying a standard bike bottle - doesn't really bother me in terms of awkwardness but my wife doesn't like carrying hers (plus I fade before she does, so I can't carry hers all the way round because she disappears off ahead of me after about an hour, in case anyone suggests that!)
We're leaning towards belts, but she's concerned about them rubbing on her hips - any female-specific (for those with narrow waists and significantly wider hips at least) belt designs/brands out there?
Posted : 25/05/2015 9:54 am
I'm not sure whether that's really an issue*, most of the material is at the back (above your bum) and not on the hips. That said, Salomon has a variety of models, I've got a Sensibelt which has more material on the sides, there's also the Hydro 45 which has a thinner belt. I've not tried this particular model, but I have used belts with this style of strap.
I've never had any problems with rubbing, and I've used quite a few different models, although I'm not a woman so my experience is obviously not entirely relevant to your wife's question.
* if your wife says it's an issue, it's an issue. I realise this 😉
Posted : 25/05/2015 10:13 am
So, the consensus seems to be >2hrs, which I'm not at yet. The main issue yesterday was really just a dry mouth/lips so I can MTFU there, and therefore 2hrs seems about right for me. However, I do hope to increase the times so I'll look into some water carrying device then.
Posted : 25/05/2015 10:32 am
In recent years my running sessions are 1:30 to 2:30 and I always carry water in my Camelbak. Carrying something in my hands feels totally wrong - it kind of invades my mind. And belts don't do it for be either.
Posted : 25/05/2015 10:36 am
I'd say 1:30 in hot weather. But if you're already getting thirsty on your runs why not take something anyway? "Back in the day" people didn't carry water, but then again decent water carrying belts or backpacks weren't available.
Posted : 25/05/2015 10:46 am
I either buy a bottle of water, and carry it in my hand till its gone down a bit, then shove it in the back of my waist band of my shorts (on longer runs I wear compression shorts under my shorts) then just bin it once I've had enough of it.
I also have a Nathan waist pack which I sometimes use.
every method I've tried has been a compromise of sorts.
Posted : 25/05/2015 11:11 am
Camelbak Delaney for me, and anything over an hour. It's not bad, doesn't slow me down anyway and have used it for runs up to 2.5hrs.
Posted : 25/05/2015 11:53 am
If serious, that is a really shitty nasty post. **** you too.
Nothing constructive to add over the above except that Camelbak do an interesting vest type thing that looks like a lifejacket. Saw one in TK Maxx the other day, forget the name.
Posted : 25/05/2015 2:24 pm
Trendy joggers post so very true
Posted : 25/05/2015 7:38 pm
What's wrong with being a trendy joggers?
Posted : 25/05/2015 7:48 pm
I've recently switched from a camelback back to a small sports bottle either on a waist belt or small rucksack. - it sounds counter intuitive but I wasn't drinking enough from a bladder. I'm now making myself stop and drink at regular intervals And bottles are easier and quicker to fill up from streams.
Posted : 25/05/2015 8:03 pm
Apparently Steve Way gets his missus to drop bottles off for him in the car.
Another trendy ****ing jogger!
Matt
Posted : 25/05/2015 8:06 pm
Make sure your nutrition strategy is sound- water on its own is not going to be sufficient for very long runs especially in warmer weather. chewy sweets are good/cheap, but you may want to also add electrolyte tablets to water in order to replace vital salts lost through sweating etc.
Camel back type things are ok but strap rub can be an issue- if you go down this route make sure it is comfortable and fits nicely (ones with the additional link across the chest may be an idea.) You may not like the hot back you get either (this ruled them out for me)
Try taking a bike bottle- it's what I used to do when marathon training and didn't bother me. Refillable too, depending on where you run. It also gets lighter so the burdern lessens as the run goes on.
A rough rule of thumb is to consume around 750ml of fluid/hour running. If you are well hydrated when you start you may be able to do a run of 90 mins or so without any in normal conditions, but if longer than this or it is very hot then you ought to start drinking after 40 mins or so. If you get thirsty, it's already too late.
Same goes on the bike too btw- drink plenty, just like those trendies in the Giro.
Posted : 25/05/2015 8:39 pm
So, runners can be just as pompous as MTBers: Who knew?
Thanks for the advice folks. As I said previously, I don't think I am quite at a distance/time where I need to take water yet (I do try and stay hydrated as a general rule) but when I am I will try one of those belts and see how it goes.
Posted : 25/05/2015 9:13 pm
Camelback - I don't need water for anything less than an hour even in heat and there's no way I'm carrying anything in my hands for that long.
Posted : 25/05/2015 9:29 pm
I prefer carrying bottles to a back type one, this is so only I can see how much water I have drunk.
It also depends on the weather, distance and terrain I am plodding over.
If it's warm and a short run, then I just carry a small plastic bottle in my hand.
Up to 4 hrs then I carry a bottle or two on my waist.
Posted : 25/05/2015 9:31 pm
If I'm running anything over around 90-120 mins I tend to put a pound in my pocket then plan to run to go past a shop. I then buy a small bottle of water or sports drink and drink it gradually over 4 or 5 many miles, and then bin it. At least then I'm only carry the bottle for a short part of the run.
Posted : 25/05/2015 9:37 pm
