Ruby on Rails help
Ruby on Rails help
6 Users
2 Reactions
I've got an app running in a docker container, I can access the container and rummage around on the filesystem. There are lots of .rb files. I know nothing about Ruby at all.
The problem is that the URL I have been given to access it returns a 404 all the time. Turns out this is the 404 page from Ruby itself - I have proved that by changing it. So how the heck do I figure out what URLs the application will respond to? I have a routes.rb file but I cannot make sense of it.
Posted : 31/08/2023 5:09 pm
Oh, nevermind. In the best tradition of asking IT questions, I've fixed it just after posting the question. There was a whitelist...
Posted : 31/08/2023 5:14 pm
mrchrist reacted
What is the correlation between asking an IT question and solving the problem within 15 seconds?
And why? I've lost count how many times that has happened.
Posted : 31/08/2023 10:01 pm
Posted it on my work channel too, and had to retract it almost immediately 🙂 And yes, it was in the manual!
Posted : 31/08/2023 10:11 pm
It causes your brain to think of it a different way when explaining it to others. See also looking at your code first thing in the morning and fixing something that you couldn't do the previous day.
Posted : 31/08/2023 11:06 pm
leffeboy reacted
The answer to the question (for whoever lands on this in the future) is that you can run rake routes from the application’s root directory (so you’d need a bash shell into the container).
Posted : 31/08/2023 11:16 pm
You should really see a 401 error rather than 404 is it's denial of access via a Whitelist...
Posted : 01/09/2023 1:46 pm
I had a bash shell in the container, I rummaged around but did not know what I was looking at.
You should really see a 401 error rather than 404 is it’s denial of access via a Whitelist…
Well arguably no, because getting a 401 instead of a 404 confirms the existence of a page, which is giving out information about the system. Then again, if all unauthenticated requests returned 401 that would solve that issue. Problem is this particular application is a composite with two UIs and two sets of credentials (because reasons) so all requests to the one with the whitelist get through the reverse proxy, so you see a 404 form the app itself not from the proxy so that sort of gives the same information anyway.
Posted : 01/09/2023 2:34 pm
