Rotten door step - ...
[Closed] Rotten door step - can I replace just the step?
3 Users
The external door on a concrete 'shed' has a hardwood doorstep that has rotted. It is no longer connected to the bottom of the frame and wobbles a lot when you stand on it.
Is it possible to just buy the doorstep/threshold or do I need to get something made up? If so, should I fix it by simply sliding it into place and screwing down through it into the concrete base?
Posted : 08/06/2012 9:43 am
Yep, cut it at the base of the frame and also in the middle so you can wiggle it out.
Get some damp proof course from toolstation, comes in a roll double it up, and a door step from the local timber yard.
Treat the underside of step with preservative,or get in a profesional like me to do it for you.
Posted : 08/06/2012 9:45 am
We just did this and bought a step from a timber merchants.
Cost £17 for the step. Stuck a bit of unibond at the back and then screwed it into the brick. Already had the existing DPM which didn't need replacing.
Posted : 08/06/2012 10:14 am
Nice one, thanks guys
Posted : 08/06/2012 12:55 pm
