Out of frustration of overgrown trails I have purchased some equipment and setup Bushwackers The local council are pretty good, but some trails across certain land owners land don't seem to get cut. One particular individual is a Vice Lord-some-bullshit title who through a farm hand does not like the great unwashed on his land. The sceptic in me thinks that the land owner probably has a direct line to the local Tory MP and people in the council, hence the reason why council clearing on his land doesn't happen.
Now I would get great satisfaction in clearing these bridleways myself, but I am conscious I could be charged with aggravated trespass by clearing the bridleway (utter madness), but does anyone know how else this could be addressed as it's bloody frustrating to watch the bridleways that pass through this land owners land being slowly lost due to a lack of maintenance?
Following with interest.
So, how does that work then? Trespass is the offence of going onto someone's private land that spoils their enjoyment of the land. If you're on a Bridleway, it's public land...can't be trespass, surely?
IANAL though, so happy to be corrected.
If it's a proper, legal bridleway (not sure how it's defined though!) Then I'm sure you'd be fine.
If it's a permissive BW, then I think the landowner has more of a say.
First port if call would be your local ROW Officer though.
If you’re on a Bridleway, it’s public land
it isn't.
you have a right to be on it, that's all.
from a google search:
You must be doing two things to commit aggravated trespass:
1) Trespassing
2) Intentionally obstructing, disrupting, or intimidating others from carrying out ‘lawful activities’.
I don't think you're doing either of those things.
If a BW is 'obstructed', the law allows you to remove enough of that obstruction to make progress along a bridleway. If the trail is so overgrown you cannot pass through, then you are allowed to clear it just enough to pass through. Whether you can clear it enough to pass through at speed on a MTB without getting covered in bramble gashes is another matter.
https://www.bhs.org.uk/advice-and-information/common-incidents/blocked-bridleways
The public right on bridleways is to go along them with related things like stopping to eat a pasty or admire the view. Trail clearing (rather than just clearing your own path if needed) is probably outside that. So once you get your strimmer out you are trespassing.
I can't see how you could be even arguably meeting the other elements of the offence, ie intentionally intimidating other people or obstructing them if you are going about it sensibly.
you have a right to be on it, that’s all.
Still not trespass, which is the important bit.
I don't think it has to be related at all. A case against a chap for trespass failed because he was using an umbrella to scare birds at a shoot while stood on a footpath, and another was using a foot path to protest alongside Stone Henge. Judges ruled that in both cases these things are "normal activities that folk would do in a public space", so were also OK on a footpath or BW.
I think a bit of community minded gardening falls into that.
Doesnt the land owner have an obligation to ensure the path is not obstructed? If you encounter any crap from him you could always counter with that.
If a BW is ‘obstructed’, the law allows you to remove enough of that obstruction to make progress along a bridleway. If the trail is so overgrown you cannot pass through, then you are allowed to clear it just enough to pass through. Whether you can clear it enough to pass through at speed on a MTB without getting covered in bramble gashes is another matter.
But clearing it enough to be suitable for a *horse* to make progress without getting attacked by brambles would be acceptable surely, and that's wide enough for a bike.
The Highways Act states that the local authority can tell a landowner to remove obstructions, so if it's literally impassable OP can try that tack, but I wouldn't expect quick results, though.
I think the risk would possibly be more of an accusation of criminal damage to his Vice-Lordship's bushes, rather than trespass
I don't think the land owner has to maintain the bridleway. It is their land you have a legal right to cross. If they do anything dangerous e.g. dig a big hole or put barbed wire across then they should remove it.
It's the local authority / parish council etc. that maintain them and resurface them appropriately.
I would ask around, is there a parish council? Ask the ROW officer at the council what the setup is?
I think a local "footpath group" i.e. rambling group do some of the clearing around here.
I would ask these groups what the deal is.
Or just crack on. I very much doubt you will end up in court unless you damage and kill the Lord's prized Oak tree or whatever.
I think you're fine unless you accidentally take someones ankles out or a small dog or something.
I tempted to do the same. Was thinking of electric as its a little stealthier. Probably a hedge trimmer is all I'd need, how are they on brambles etc? Would I need to lug out all the offcuts or just leave them there?
isn't there a difference between 'responsibility of maintenance' between footpath and bridleway?....I'm sure this was recently given as a reason why a landowner opposed the proposed 'upgrading' of a footpath to b'way
EDIT: quick bit of googling suggests that may be nonsense as per LB Enfield info below:
The Council is responsible for protecting and asserting the rights of the public to use rights of
way, including footpaths and bridleways. Responsibility for keeping footpaths clear of
obstructions rests with the landowner as does the requirement to cut back vegetation and
maintain gates and stiles.
The Council is not required to maintain footpaths and bridleways to a defined standard (i.e.
to provide a hard surface or ensure the surface is not broken) but must ensure that the ways
are safe and, as established by legal precedent, “reasonably passable for the ordinary traffic
of the neighbourhood in all seasons of the year”. Government advice on the matter states
that “footpaths and bridleways should harmonise with the general appearance and character
of the surroundings”. This is particularly relevant on bridleways and those footpaths outside
of the urban areas of the borough. It should be noted that some footpaths and bridleways
are not maintainable by the Council at all, including those created after 1949 that have not
subsequently been adopted by the Council.
Interesting replies. I have tried contacting the local area Rambler and the associated Parish Councils, but one word always comes to mind "apathy" for doing anything differently. I report overgrown bridleways to the council on a regular basis and some of them are quickly and others cleared 3 months later. I purchased a Hyundai £200 multi tool last week and have absolutely blitzed 2 local trails that were at risk of being lost due to no proactive maintenance over the years. The brush cutter clears the brambles and the pole saw was ace at removing overhanging 2-3" branches.
I'd highly recommend getting some and sharing it with your friends as I was really surprised at how much trail you can blitz in 1 -2 hours.
On a side note. When I asked the local Ranger if I could drive my van up to clear the trail that runs over Lord Pompous-Git's land I was told best not as he rides around on his horse and can be a bit aggro.
But clearing it enough to be suitable for a *horse* to make progress without getting attacked by brambles would be acceptable surely, and that’s wide enough for a bike.
horses are notoriously difficult to reverse, ideally it should be wide enough for two horses to pass eachother.
Top tip if you do any clearance is to work from the middle out, so the entry/exit are the last bits - that makes it far less obvious that you're doing anything until it's pretty much done.
I expect at least at local authority level there is a width definition for both FP and BW from a maintenance perspective. Definition of maintenance might not include who can do it but only that it should be done to a maximum width.
In a nutshell it’s an unclear shambles of legislation.
From a hants gov doc
“ Removal of obstructions. The powers of individual users to directly affect path conditions are restricted to the ancient, limited, but still significant, power of abatement. Abatement is the common law right to take action to remove a nuisance that is affecting the exercise of a right. The action taken can only be sufficient to enable the right to be conveniently exercised. In practical terms this means that if, say, a walker comes across a path blocked by excessive vegetation they have the power to remove so much of the overgrowth as is necessary to get past.
If they can’t get through, they also have the right to detour around the obstruction. Although the bulk of the obstruction may remain, once a person can conveniently carry on their journey they no longer have the power to remove material and further action could even constitute criminal damage.”
From bucks cc
“Vegetation
Trees and hedges
In most cases, it is the landowner’s responsibility to maintain hedges and trees adjacent to rights of way. We have the power to require owners to remove overgrowth within a period of 14 days (Highway Act 1980 section 154). If the landowner fails to comply, we may remove the obstruction at the owner’s expense. (Highways Act 1980 section 150 (4)).
Undergrowth
We are responsible for clearing any vegetation naturally growing on the surface of a path. We have an annual maintenance schedule to clear the routes and respond to requests for clearance as required.”
I’d Ask the council who owns it, if they don’t own it (which seems to be fairly unlikely but not impossible) I’d ask for written proof with copies of any documents and exact references to any law to clarify ownership, if they own it try a nice approach saying that with their permission you’ll happily help clear it etc etc, if he owns it (and this seems to be a minority of paths) ask the council to clarify what the legal requirements are.
Re widths
https://www.legislation.gov.uk/ukpga/1980/66/schedule/12A?view=plain
“ For the purposes of this Schedule the “minimum width” and “maximum width” of a highway shall be determined in accordance with sub-paragraphs (2) and (3) below.
(2)In any case where the width of the highway is proved, that width is both the “minimum width” and the “maximum width”.
(3)In any other case—
(a)the “minimum width” is—
(i)as respects a footpath which is not a field-edge path, 1 metre,
(ii)as respects a footpath which is a field-edge path, 1.5 metres,
(iii)as respects a bridleway which is not a field-edge path, 2 metres, or
(iv)as respects any other highway, 3 metres; and
(b)the “maximum width” is—
(i)as respects a footpath, 1.8 metres,
(ii)as respects a bridleway, 3 metres, or
(iii)as respects any other highway, 5 metres.”
Just walk though casually carrying a 5l weed killer spray. Wave the wand from side to side and a few weeks later the path is pretty much clear with no evidence that you caused it.
Maybe not the STW approved method but clearing a 4 foot trail width of undergrowth allows you to manage the grow back far more easily and less obviously than a bush whacker.
I've learned over the years that you can do pretty much any unsanctioned trail repair/clearing activity you like, as long as you're wearing a green fleece and a hiviz. The only downside is that you lose a lot of time to giving people directions.
As Northwind says - wear green/brown outdoor clothing, hi-vis, orange hat, ear defenders and safety specs. You will never be challenged.
Doubt the above will work if you are on an estate, reality is that the chances of being charged with aggravated trespass is pretty much zero for what you explain, the actual loss to the landowner is zero, as it is overgrowth, on an area that is ROW, i'd expect the maximum that would happen would be a discussion with police/landowner and the usual don't do it again if you do the good citizen routine.
Best course of action though is the ROW officer with the council, if there are any potential areas that are risk of injury then that works a bit better, as at least they'll go and see it themselves quicker, as they aren't fans of having that raised without follow up.
[i]as long as you’re wearing a green fleece and a hiviz. The only downside is that you lose a lot of time to giving people directions.[/i]
Where a white cotton onsie with bright yellow radio active stickers and be overly careful when lifting and carrying things and no-one will question you or come near you. In fact you will probably have the trail to yourself for a few months afterwards, especially if you deny doing anything and deny there being any problem to anyone brave enough to ask you
Isn't any type of civil suit dependant on the claimant showing they have suffered financial/material damages which require recompense, essentially?
It's pretty difficult to argue that clearing some brambles is costing them anything or requires them to do anything to remedy it.
OP, you are frustrated.
Therefore I would recommend you just ignore it and avoid further frustration.
It seems you will either be frustrated by daft laws, daft councils and daft interpretation of daft laws. You are likely to be further frustrated by the daft land owner.
Go and do some fun cheeky riding, preferably at night, somewhere enjoyable with no risk of frustration. That will take your mind off it.
Seems daft to waste precious time banging your head against this problem.
Isn’t any type of civil suit dependant on the claimant showing they have suffered financial/material damages which require recompense, essentially?
I used to think so as well, but reading up a bit on trespass, the claimant just has to prove that they suffered loss of enjoyment of their private property. i.e. It's enough for you to just go onto their land to have trespassed, you don't have to have damaged anything.
Isn’t any type of civil suit dependant on...
You being identified and/or apprehended/located after the fact ?
Seeing as how you can get away with "wasn't me mate" for driving at people on bikes with your car on a public road with video evidence showing the encounter then I can't see it being too tricky to get away with a bit of hedge trimming on a BW.
The Highways Act states that the local authority can tell a landowner to remove obstructions, so if it’s literally impassable OP can try that tack, but I wouldn’t expect quick results, though.
There are a few stiles around here with barbed wire wrapped around them by local farmers. I've occasionally wondered what I would do if I was to injure myself on the barbed wire as I walked along those footpaths.
It's the landowners responsibility to keep the ROW in good order (ie repairing stiles, clearing vegetation). In practice, some take it more seriously than others.
They can get grants for things like stiles, bridges and gates.
Sounds like he won't do anything unless forced but try to sell the benefits of a clear route ie. his horse could use bridleways too.
Or, organise a trail 'party' with 20 mates riding through every week!
To play devil's advocate- you may think you have a legal or moral right to clear bridleways so you can indulge in your hobby/interest.
Land owners are, invariably, well connected to the local great and good - including councillors and police.
Your proposed actions could be very easily spun against you and used to generate adverse publicity for bikers in the area.
Your bushwackers site, if viewed by the the other side or councillors or police, sends out completely the wrong message when looking at the kit you have or would like to acquire.
From the other (your) side do you want to be responsible for the fallout which could result from your proposed actions?
Why not contact the land owner or their agent direct and politely ask for their permission to clear an overgrown bridleway; copy of this to LA and, if any response, also copy that to LA.
If no you can't or no response either forget it - as Trimix says - or pursue through LA.
There are a few stiles around here with barbed wire wrapped around them by local farmers. I’ve occasionally wondered what I would do if I was to injure myself on the barbed wire as I walked along those footpaths.
just wrapped around the wood or placed in a way that makes using the stile difficult?
the stile is there so you can cross a fence but livestock cannot (basically as we cannot be trusted to close gates) perhaps it is needed to keep the animals from wriggling/scrambling over or through it.
I'd happily walk on a path that was adjacent to a barbed wire or electric fence, so I'd be happy to cross one appropriately too. Knowing that hurting myself while doing so is my own damned fault.
Blocking the stile of course is a different matter.
I disagree. I think the site is excellent and might spur landowners into action!
Fail to see so many complications. As Martin said, you can clear enough to permit your access. End. Taking tools will/could chuck in another set of problems to do with insurance etc. Any chemicals could well lead to trouble but why bother? Access isn't the potential to hammer through but get there some how, so enough brambles gone to push your bike through is enough.
Can anyone link to a court case where a member of the public has been successfully sued for trespassing in connection with outdoor leisure pursuit?
Just my opinion. Whilst advocating bridleway clearance if the local council are too lazy to do it themselves I certainly wouldn't advocate using heavy machinery nor herbicides. In fact using herbicides is one of the dumbest things I've read on this forum in a while.
As far as I know minimum widths should be maintained. Footpaths are landowner's responsibility, bridleways are council's responsibility.
Felled branches blocking the paths could be cleared by you (though shouldn't) but the hand tools that you carry could land you in deep water so be prepared. Secateurs are pretty much useless for the scale of work involved in bridleway clearance but very much more discreet than slashing away with a brushcutter.
You have to think about liability cover for flying debris when brushcutting and pollution of nearby waterways for herbicides, not to mention drift (what a ****ing daft idea).
Personally, if I was paid then I'd love to hack away at some of the bridleways near here (I have the tools and some of the tickets) but the local council will already have their 'favourite' contractors and it's not a level playing field with respect to competing for small contracts. In fact if you merely express an interest to find out what the contract involves then they'll think you're a terrorist, but that's another (s)tory 🙂
It's dumb (not the idea of clearance). You're willing to provide a public service and, if it's for free that's great both for the council and local tax payers, but it's not legal and if someone has a grudge against you then you're potentially ****ed.
I just put up with the scratches and stingers and jump everything else. Virtually immune to them now.
I work in grounds on a private estate with a bridleway running through it, I would be pretty pissed off if someone came along with their own tools and started clearing (though would hopefully never be an issue as I do maintain it and keep it clear) and extremely pissed off if someone sprayed weed killer!
I just looked at your link properly and I think you're a bit mental trying to get hold of that machine and use it on someone else's land TBH!
Ajaydoubleyou has it. BW has to be wide enough for 2 horses to pass safely. So greater than 2 metres.
You’re willing to provide a public service and, if it’s for free that’s great both for the council and local tax payers, but it’s not legal and if someone has a grudge against you then you’re potentially ****.
Really? This sort of bollocks puts off so many people from volunteering to do anything, it's akin to the sort of scare mongering that goes with clearing snow off pavements.
I've reported a shared use path to the council 2 months ago as being impassable, nothing has been done so I've taken to clearing it myself & have advised the council of this - if anything goes wrong I'm pretty sure the council would be in the firing line not me 🤔
My dad used to clear the local bridleways with a petrol strimmer. Noisy as hell. Never had a complaint from a landowner.
Will also just mention that during nesting season, March - end of August, hedges, trees and bushes shouldn’t be touched*, hence why councils, farmers and landowners won’t cut them during that time.
(*yes there are exceptions)
Just saw from the link this is in Dorset. Where about? I have had nothing but excellent responses after filling in the on line forms numerous times over the last few years. Always sorted quickly and kept up to date with swift action if the landowners ignore the request clear the RoWs.
I also started strimming the local mtb track 'cos it was un-rideable. Met the guy who was contracted to be doing it in the process! Gladly let him carry on and get on with him fine anyway so now it's clear.
I don't take tools out on long rides but will remove the odd overhanging branch etc.
Just go and clear it, if you get any problem with the landowner or his staff give a false name or just walk/ride off. I doubt the police will come just for someone clearing a path so no one will ever know your name to prosecute if that is a worry
no advice to give, but I was arrested (and usually subsequently de-arrested) for aggravated trespass with tedious regularity pre- hunt ban, so the subject is quite nostalgic! A clear demonstration on where the allegiance of Essex/Suffolk constabulary lay, or at least which hunt the chief super belonged to.
Having checked the link as others did, i'd say taking a full sized rotovator on to a bridleway to clear is a bit OTT, unless you have sought the landowner and/or ROW officers permission, i was thinking you were more about some secateurs, lopers or a trimmer at most, but a rotovator is a tool i'd be using to create a bridleway or path through a wooded or grassed area.
Would definitely make more sense to offer a service around your area to 'assist' landowners in carrying out their duty of care for RoWs on their land, and those that reject this offer without an alternative would be worth then raising to the RoWs Officer.
As others have said, dark green jumper, hi-vis, quiet tools, start in the middle and work out, only as wide as you need, look official, clean up as much as you can after yourself and if stopped, accepting it and move on (and consider an alias if asked for a name).
Surely the easiest way to clear a trail is offer some neds a bottle of buckie to rag their motobikes up and down it a few times?
Will also just mention that during nesting season, March – end of August, hedges, trees and bushes shouldn’t be touched*, hence why councils, farmers and landowners won’t cut them during that time.
This thing about nesting birds is increasingly used as a diversion imo - if the foliage wasn't allowed to overgrow RoWs in the first place then the birds wouldn't be nesting there.
Our local development trust has taken on insurances - and some simple risk assessment / SOP's for doing work like this.
You can now volunteer with them and they cover all sorts of work the council would do - repainting benches or railings, clearing paths, repairing water damage on paths, maintain street planters etc. All stuff that is 99% hand tools and some labour.
It works with the powers that be and landowners, and is a good way of local development trust getting the windfarm funding every year. It has become quite a social club for some of the retired folk.
https://dunblanedevelopmenttrust.com/what-we-do/paths-and-maps/
Thing is foliage doesn’t grow much sept-feb, so a good cut back over winter is needed, still the risk of it growing back to cause an issue in spring
It is - a tad 'exclusive' at times, ahem, but it works well.
The only powertools are simple things like drills, as the council wanted the LANTRA (?) qualifications for strimmer's and reciprocal saws for branch removal.
A couple of the landowners still seem rather reluctant, but at least improvements are made where they can be.
Having relooked at the link I'd agree with Grum, this
is taking things a bit far without anyones permission
Yeah, very commendable work in clearing what you have, but maybe tone down the machinery aspirations.
“ @matt_outandabout – that looks like a really good setup” - agreed
Where I am the ramblers do some good stuff (* and have kit, training, dayglo, “authority support and contacts” etc etc) but I suspect I’d have to be a member (which I don’t want to do), to go on their work parties.
Wildlife and Countryside Act 1981 section 13 1 a
Might apply if any plants in schedule 8 are destroyed.
It strikes me as pointlessly confrontational to go onto someone's land with machinery without their permission, particularly when you know it's not welcome.
Land owners that don't want to encourage more people to cycle and walk about on their land rely on a bit of overgrowth to limit it, do the minimum until the council forces them and so on, the last thing they want is someone taking control of it and encouraging more pesky mountain bikers.
I'd exercise diplomacy and speak to the council and see what can be done before doing something that could cause conflict.
If it's the Council's duty to clear vegetation growing on the ground on a PRoW, then the way forward for the OP, I suggest, is to offer his services to the Council on a voluntary basis. I would start by approaching a Councillor, not a Council Officer, as the best way to avoid being blocked by a jobsworth, as once that's happened there's no way back.
You can clear most stuff with a thickish whacking stick, forget the machinery and rules, just walk it regularly with an appropriate length of branch and fling it about. Nobody will stop you for that.
My lunchtime loop has a 400m section that's impassable in summer due to nettles. I used to get angry, now I wear winter gloves and long shirt and trousers. Every time I go through it, I snap the nettles and brambles that get in my way using my hands. Because I've snapped them near ground level, they can't come back quickly.
Over the last month spending 5 minutes a ride has made it passable to walkers. I previously spent a couple of hours with a weed whacker but this seems more effective and I don't feel guilty doing it in full view of the farmhouse at the end (the farm are pretty good, they cut it back every winter but it grows back during the summer).
I could clear it all in an afternoon with a lawnmower and hedge trimmer but that would take more than 5 minutes and would probably piss of the farm and the owners of the horses in the field next door.
Youve already broken the first rule of trail clearing.
If you clear the trail with a petrol-powered unit the landowner will likely hear you from a mile away. You’ll probably end up in some sort of altercation which could be far worse than a trespass charge.
Get something electric or manual if you’re going to do it!
My cheeky riding alias (if I ever need it) is Michael Souris (it's Latvian originally). My false address is a random number on the street where I lived as a kid, so the postcode would check out.
Mine is dannyh off singletrackworld
I'm curious..why the need for a false name and address??
Too much of a well-known arsehole, you'll get in trouble.
I’m curious..why the need for a false name and address??
I could tell you, but I'd have to kill you. Plus I like the faux jeopardy.
