Right, heres an IT ...
[Closed] Right, heres an IT question for you (moon on a stick content)
4 Users
Ok, you have a program that configured properly, can add data to a SQL database
What I want to do is take a backup of that database just before the program runs. I've had a dig about on the internet but finding it hard to explain what I want to do. Basically, you double click to run the program that inserts the data, this kicks a batch file into life to take the database backup and drop it somewhere (a folder)
I was thinking some sort of scheduled task that works on the event of running the program, the batch file runs a SQL statement to take the backup
Am I dreaming just too darn big?
Posted : 20/04/2013 2:49 pm
Windows? Yes, a simple batch file could do this.
Do you have a command line access to the backup program or do you not even have a backup program?
Posted : 20/04/2013 2:53 pm
You can run SQL Server backups from the command line, so assuming your program can call a batch file,, away you go.
Edit: oops, misread the OP, not necessarily a SQL Server db!
Posted : 20/04/2013 2:54 pm
groovy.......its a work thing and could be written into the program.
No backup program, just access to the server
Posted : 20/04/2013 2:55 pm
[url= http://stackoverflow.com/questions/880487/sql-server-command-line-backup-statement ]Linky[/url]
Posted : 20/04/2013 2:57 pm
What type of server is it? Oracle, SQL Server, ...
Not that it makes that much difference, it should be fairly easy regardless.
Posted : 20/04/2013 4:29 pm
