but all i could find was this
[img]
[/img]
so I thought this
[img]
[/img]
found this and something to cut it with
[img]
[/img]
Unfortunately the drill bit broke so I couldn't finish the base mounts for the uprights
[img]
[/img]
so I cleaned up the old shocks and sprayed them with undercoat ready for a top coat tomorrow
[img]
[/img]
Hopefully an update tomorrow when I get a drill bit, some top coat for the shocks and a scaffold plank or similar for the seat.
Dude...fuxupwitchoo...?
Brilliant!
You should probably install the seat in your car 😉
I wonder what A&E will be dealing with later today? Looking forward to pics of the finished item, or the inevitable gore fest prior to a ride in the ambulance.
A bit of progress but spotted a design flaw in the last shot
Compressing the springs to refit after painting the shocks and floor rests
[img]
[/img]
One half assembled and mounted to the bench top / scaffold plank
[img]
[/img]
Other side on and notice there is an issue with the suspension camber
[img]
[/img]
Concrete blocks solve that but then MrsWCA points out the obvious...
[img]
[/img]
...swap the legs around and use the wheel mounting bracket, currently on the outer edge of the shocks, to hold a support bar between the legs so they are vertical.
Sitting on it is comfortable enough but not much in the way of bouce. I guess I weigh less than the front of a BMW. Maybe a couple of people would make a difference.
We will see what it is like with the legs swapped and an anti sway bar across the middle
or, maybe you could launch yourself off - ooh, I dunno, maybe a ladder - and see if that improves the compressionSitting on it is comfortable enough but not much in the way of bouce. I guess I weigh less than the front of a BMW. Maybe a couple of people would make a difference
Hi, Molgrips! Come in, have a seat!
Er no thanks, I'll stand. Hope you don't mind.
Do you live in a windmill, own a flying car, and have a bird called Truly Scrumptious?
Looks, er.. heavy.
DezB - I will use alloy for the cross strut and remove the four concrete blocks to lighten it.
Chitty Chitty bang bang? No, not yet but there are plans...
See the front of the pick up? With a bit of angle grinder and vision, perhaps, just perhaps...
I have faith in you
Anti-sway bar needs to go diagonally from each side and attach to the seat centre, rather than side to side
Balance a spare engine on your lap and it'll be just fine..
[i]Anti-sway bar needs to go diagonally from each side and attach to the seat centre, rather than side to side[/i]
Exactly the same conclusion I came to on the drive up to work this morning - you are a genius
Assuming the shocks are not completely goosed, the nitrogen charge should be enough to hold most non-clydesdale types - take the springs back off and have a try!
All completed and painted now
Now on ebay with a cheeky buy it now price. If anyone on here wants either just email me an offer
http://www.ebay.co.uk/itm/111702896106?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
http://www.ebay.co.uk/itm/111702900303?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
