Retirees to the for...
Retirees to the forum.
139 Users
46 Reactions
56 and touch and go whether i'll be able to afford to retire at 60. i have a couple of relatively small DB pensions and a SIPP. i also have a small S&S ISA with vanguard or fidelity, i forget which.
just had an email from HL stating....
You can set up a Direct Debit into your HL SIPP from as little as £25 a month. In this example, you pay in £20, and the government adds £5 in the form of basic rate tax relief (currently 20%).
i didnt know this (useless at understanding money). i opened the SIPP by transferring old, stagnant DC pensions from my engineering days and following good advice on here, invested in a spread of markets and just left it.
now knowing that the government would add 20% to anything i put in, im thinking of taking HL up on that and setting up a DD.
is my SIPP the best method of saving regularly into future investments? i assume if i was to save the same amount of money into my ISA then there'd be no top up from government, so is it a no brainer? or might it work out the same anyway when it comes to withdrawing as maybe the SIPP will be taxed then, and the ISA not?
and if i do decide to set up DD into my SIPP, whats the best way of doing this to minimise charges? chuck a monthly amount in which sits doing nothing, and then when its accumulated into a sizeable amount invest it into my spread, so i just pay one charge?
or invest the DD amount immediately each month and pay charges each month?
hope thats not too confusing and you understand what im asking 🙂
Posted : 12/04/2021 11:08 pm
Retire and maybe pick a some consulting work
How about not trying to turn every thread into a STW political sycophant rant.
Posted : 13/04/2021 10:51 am
ISA is tax free but you invest from your net income (after tax). There are no restrictions on what you do with it and when you take it and any gains are 100% tax free.
SIPP is a pension and you invest from your gross income (before tax), or from your net income (after tax) but you get your tax back (the extra 20% basic rate tax). However, pensions are subject to tax and you can't touch them till you're 55. At 55, you can take 25% tax free as a lump sum, the rest will be taxed eg at your marginal rate.
The 25% tax back on a SIPP is worth having as you'll likely pay less tax as a pensioner than as a saver as you'll earn less, so you wil get some benefit (unlikely the full 20% though).
Posted : 13/04/2021 11:00 am
so i think youre saying then that on paper theyll both give me the same in the end for the same input, you just pay tax at different times. but that the SIPP would probably end up being the better option to draw from if i dont touch anything until retired, yep?
and if so, then.....
thanks
Posted : 13/04/2021 2:23 pm
Not quite. You can "usually" invest your money within both "wrappers" in the same way for example you can buy a fund in your ISA and/or in your SIPP.
Without speaking for Footflaps but if you are earning now at the higher tax rate then pensions are attractive as you can put money in and claim 40% back. Yes when you retire and start to take your pension you will pay tax at your marginal rate but unless your pension is large then you are unlikely to pay tax at the 40% level and probably at the 20% level so you have made a saving.
ISA's are tax free withdrawing the money but you have paid tax on the way in.
So you just need to calculate what that mean for you.
Posted : 13/04/2021 2:35 pm
You can “usually” invest your money within both “wrappers” in the same way for example you can buy a fund in your ISA and/or in your SIPP.
yep, got that.
im 20%, so probably as i thought, pretty much the same in/out? but SIPP still slightly better for withdrawing once ive retired yep? i wouldnt touch it whilst working, firstly as i dont need it, and secondly that may then push me up to the 40% rate.
so for a 20% tax payer, i think im understanding that the SIPP will be better to draw from once retired and starting my earning from zero, is that right?
thanks
Posted : 13/04/2021 2:44 pm
Not really. If you withdraw from you SIPP it is part of your taxable income so if you say draw out £15k pa then you will pay tax on the bit between your tax free allowance (about £12k) and the £15k.
If you draw £15k out of your ISA then you will pay no tax on any of it.
SIPP is probably better if you are earning at the 40% threshold then in retirement paying tax on what you take at the 20% threshold.
As above I am no expert so happy to be challenged on any of this.
Posted : 14/04/2021 11:27 am
yes, but the ISA will have been taxed already as i would have paid into it from net earnings, so is that not pretty much the same then? apologies for not really grasping this.
sadly i wont be troubling the taxman with my SIPP withdrawals. my SIPP is only worth around £100,000 at the mo with less than 4 years left to go before starting to 'draw down' at 60. so, going by the recommended figure for drawing down (4%?), then id only be taking around £4000 pa.
although saying that, my DB pension will kick in (12,000 pa hopefully) which means something will be taxed at 20% wont it.
this is confusing for me, told you i was rubbish at money 😀
basically, ive worked out that my £12,000 DB pension, plus 4% SIPP withdrawal will give us £16,000 pa. not quite enough to live on for us, so we were thinking about @ivorlott 's question previously where he asks about tapered withdrawals from a SIPP due to other pensions kicking in later (another £6000 pa DB pension at 65, state pension at 67, plus being an old codge and not needing so much the older we get)
so we'd considered his suggestion of say 7% first 5 years and then a lot less when second pension kicks in. minefield innit.
im jealous of some of those mahoosive pension pots ^^^ that you lot have acquired 🙂
so.......now that ive put a bit of context and a few figures behind my question, would you say theres most benefit in putting any further DD payments into a SIPP or my ISA?
thanks for sticking with me, id never have made a career as a financial adviser would i 😀
Posted : 14/04/2021 12:13 pm
Retired at 60 last year, and loving it. I've absolutely no idea how I arrived here living mortgage free in Brighton and having a rental in Bedfordshire.
I say no idea, as I've pretty well been a warehouseman all my life. So minimum wage all my life.
I can only think that starting full time work at fifteen helped, and no debt.....I wasn't ever earning enough to get credit.
Anyway so it's great. rebuild our new home here over 2020. Got back on my bike March 2021. Beck on the board and in the sea April 2021. Looking forward to dancing again and enjoying a social life here.
Posted : 14/04/2021 12:52 pm
Yes thats about the same I think. If you are not getting any other benefits from the SIPP such as the additional 20% tax allowance.
Yes the tax is on your overall income (same as when working) from whatever sources unless those sources are tax free such as an ISA.
Yes I am thinking the same way, im 56 and would like to stop at 60 although I may go a bit earlier. With tapering I can finance it for 10 years until my state pension makes a contribution.
possibly but you need to decide yourself I dont want to mislead I only have a basic understanding.
Posted : 14/04/2021 1:31 pm
You said you have a pension paying £12k a year, so anything you take from your SIPP will be taxed at 20%, which pretty much wipes out the 20% tax you get back when you pay into a SIPP. However, you can take 25% out as a tax free lump sum, so you can effectively get a 20% benefit on 1/4 of your pension (or 5% overall benefit).
So, a SIPP is marginally more tax efficient, but less flexible (have to wait till 55%, more paperwork to take 25% tax free etc).
Posted : 14/04/2021 5:19 pm
Retired at 60 last year, and loving it. I’ve absolutely no idea how I arrived here living mortgage free in Brighton and having a rental in Bedfordshire.
Timing
Posted : 14/04/2021 5:50 pm
Timing
Those graphs don't show affordability of the mortgage payments eg as a % of average wage, which would probably be a better indicator as interest rates have dropped a lot since the 80s.
Posted : 14/04/2021 5:56 pm
Sadx - you may be able to defer your db pension to boost retirement income. Some schemes allow it, some don't. I know someone who s deferred his db, he must be early 70s by now, must be pretty sure of his longevity as the pensions going to die with him. Actually he s pretty clued up so maybe it all transfers to his widow.
Those meaningful money podcasts are really good, I m ploughing through them now. Ta whoever tipped them on here.
Posted : 14/04/2021 5:58 pm
@surfer 's comments
thanks, appreciated.
understood, thanks. without going into too much detail (that i wouldnt understand anyway), i dont think id want to take out 25% straight away, id want to draw down (4-7% at a guess) and make it last. would i still get the same 25% tax free benefit by doing so?
i assume you mean 'age 55', im 56 now so no problem there 🙂 more paperwork? is it a right faff or still easy enough?
you may be able to defer your db pension to boost retirement income. Some schemes allow it, some don’t.
ah ok, not sure if mine does or doesnt. i think colleagues that have worked out whether its worth staying on or not (fire service) always come to the conclusion that its not and retire when they can. (and no, i joined too late for the decent fire pension unfortunately) 😀
gut feeling tho is as plenty have already said above, lifes too short, retire when you can and dont put it off.
thank you all very much.
Posted : 14/04/2021 6:35 pm
Sadx- not so much staying on working, your job is physical so probably not suitable to work more years. What I meant is deferring the start of your pension, some schemes allow it.
My db schemes start at 62, I will get a quote for their deferral to start at 63, obviously I would have lost a years payment but it depends on the uplift in payment.
Biggest indicator for me in above is any known family illnesses, longevity of parents, widows benefits.
Posted : 15/04/2021 6:53 am
ahhh i get you. not sure that i could retire and NOT take my pension tho, unless you have a sneaky method of existing for a year or two on no wedge? 🙂
i guess youre probably alluding to living on wifes wage for a while, but in my case that wouldnt be feasible, she earns next to nowt really.
(EDIT: or theres always the possibility of a part-time job, B&Q, van driver type job etc i spose, but is that retiring?)
thanks. its all interesting information, lots to consider, i appreciate it.
Posted : 15/04/2021 7:33 am
 5lab
@sadexpunk you don't have to drawdown your sipp pot evenly - so out of your £100k - you take £25k tax free at the 60 (and then effectively split it over the next 7 years), then you could take ~£11k a year till your state pension (and delayed define benefit pension) kicks in at 67 (might be wrong about the age). This would give you a total of £16k/year, all completely tax free as you're not meeting the £12.5k threshold in any year. At the end of the stint you've nothing left in your SIPP pot, but you have a bigger db pension (potentially).
with this method its also worth pumping more into the SIPP pot as you are £1.5k below the minimum tax threshold each year
one other thing to note - if you can contribute through your employer as salary sacrifice you will also get your contributions pre-employee NICS - this is ~5% at your salary range (I think) so gives a benefit over getting the income then putting it into a SIPP (you get the 20% tax either way, but can't claim back the 5% NICS)
sorry to add more confusion
Posted : 15/04/2021 7:52 am
oh FFS! 😂
Posted : 15/04/2021 8:00 am
i assume you mean ‘age 55’, im 56 now so no problem there 🙂 more paperwork? is it a right faff or still easy enough?
yep, age 55.
No idea about the paperwork, but I have read that quite often when people try and take the 25% tax free it ends up getting taxed and you have to fill in various forms etc to get the tax back. I'm only 50, so will find out exactly in 5 years....
Posted : 15/04/2021 9:16 am
 DrJ
A basic and probably naive question, but if you stop working before the state pension age, do you have to declare yourself "retired" to anyone, like HMRC or whatever, or are you just "voluntarily unemployed"?
Posted : 15/04/2021 9:23 am
Sorry for NRTS but has anyone mentioned to sadex that the 55 age limit is probably moving?
Sadex, are you less than 49 years old currently?
If so, the age at which you can start getting your pension will probably move just before you get there...
Posted : 15/04/2021 9:31 am
but if you stop working before the state pension age, do you have to declare yourself “retired” to anyone, like HMRC or whatever, or are you just “voluntarily unemployed”?
When I retire the very last thing I'm going to do is tell anyone, least of all my employer. I want to see how long it takes them to work it out that I've gone (a few salary payments I'm guessing).
Posted : 15/04/2021 9:35 am
Nope.
I suspect HMRC will figure it out after a year of no PAYE...
Posted : 15/04/2021 9:42 am
no, im 56 so should be fine.
you don’t have to drawdown your sipp pot evenly – so out of your £100k – you take £25k tax free at the 60 (and then effectively split it over the next 7 years),
so take out 25% tax free and invest it in an ISA say and draw down from that you mean?
This would give you a total of £16k/year, all completely tax free as you’re not meeting the £12.5k threshold in any year.
sorry, dont understand that. how can 16k all be tax free as its actually over the 12.5k threshold?
sorry, still dont understand how im under a threshold.
with regards to pumping into my SIPP, another consideration which may make more sense than all of this, is that my wife doesnt have a pension, so we'll be relying on mine.
we just started a SIPP for her which only has a few grand in it and we've not even considered it as its just not worth anything.
im now thinking it may make more sense to put regular payments into it (rather than my SIPP or anything else) as she'll be nowhere near her tax allowance. shes 10 years younger than me tho so wouldnt be touching it until im 65.
Posted : 15/04/2021 9:43 am
The change from 55 to 57 is currently in consultation, but is looking slightly complex.
There's some discussion on MSE here , but basically anyone 55 between the period when this applies needs to watch out, in particular in transferring pensions.
Posted : 15/04/2021 9:56 am
You take 25% of the pension tax free as a lump sum and stick it in a savings account (for example). Then each year, you take £4k as 'pension top up' and spend it. Thus you get an income of £12k pension + £4k top up from savings = £16k all tax free.
Posted : 15/04/2021 10:09 am
I've not had much of a coherent approach to pensions, preferring other means to an end, but on the basis that I am approaching 60, I thought I'd start pulling stuff together for a final push.
Ive got three pensions and had in the back of my mind that when I left my lowly role in the Raf Regt back in 1985, I was given a peice of paper saying I had qualified for a £500 pension at retirement age.
So I contacted Vets UK, who handle the Service Pensions and they said that from the age of 60 that £500 is now worth £1700 a year and a £5000 cash lump sum. Obviously, I'm not going to have a celebration party, but its better than a kick up the arse! 🙂
You don't actually have to take the 25% in one go.
You can have 25% of each drawdown payment as tax free (small % of overall 25% tax free amount) and leave the rest in the fund to grow. Your remaining percentage goes up with the fund.
Posted : 15/04/2021 10:13 am
You take 25% of the pension tax free as a lump sum and stick it in a savings account (for example). Then each year, you take £4k as ‘pension top up’ and spend it. Thus you get an income of £12k pension + £4k top up from savings = £16k all tax free.
ahhh that makes perfect sense, thanks. (and apologies to @5lab for not getting that myself).
You don’t actually have to take the 25% in one go.
got it, thanks.
Posted : 15/04/2021 10:16 am
This is the way that most people will probably handle things. Martin Lewis uses a good analogy based on a jam roll representing your pension pot. The jam is the tax free bit and the sponge taxable. When you cut a slice of the jam roll (thick or thin), you get 25% tax free and 75% at marginal tax rate. The remainder of the jam roll will grow or shrink based on your investment approach and then you take another slice at a later date etc, etc.
Posted : 15/04/2021 10:39 am
I suspect HMRC will figure it out after a year of no PAYE…
This appears to work. I retired at the end of October, got my final pay off in November. Yesterday I got an email from HMRC telling me to check my new tax code. They have figured out that my old DB pension is now my only source of income, and they will no longer take such a large proportion in tax.
Posted : 15/04/2021 11:35 am
Love these threads....sadx no what I mean with widows benefits is when you go to the fire station in the sky does the pension die with you, or say half to your wife.
I have met q a few ex police and fire types who are doing other jobs, you have good skills, so pension deferral if it pays and is possible could be an option.
The old rules for deferring the state pension were really generous, now it's not worth it.
Posted : 15/04/2021 12:15 pm
pretty sure its half to the spouse. which is why its always seemed tempting to go for the cash transfer on my old engineering DB pension and then stick it in a SIPP so its all available to her on my death. but, ive read it enough times on here to know that we should never get rid of our DB's 🙂
with regards to pumping into my SIPP, another consideration which may make more sense than all of this, is that my wife doesnt have a pension, so we’ll be relying on mine.
was just thinking about this, and on further thought, itd mean money that we could have put into my SIPP or an ISA to be available early doors when we may want it more, wouldnt be available until shes 55 (or 57 if the rules are likely to change ^^^). which means id be 65 (or 67) and other pensions would be kicking in there too.
if we want more earlier on, thats probably a bad idea even though the tax implications would be favourable.
Posted : 15/04/2021 1:50 pm
 Kip
I think I'm in the wrong forum. Checked my pension pots the other week and I'll still be working into my 70s at this rate, although house should be paid off, so who knows.
I try not to think about how much having a child and changing career more than once has stuffed my financial future.
Posted : 15/04/2021 8:07 pm
+1 although not changed careers, many job moves to places with no pension, or not joining a scheme as I thought I wouldn’t be there for long I’ve missed out on quite a few years of contributions or a few small pots 😕
Posted : 15/04/2021 10:05 pm
I'm paying additional pension to 50% of the maximum yearly amount. Am I nuts for looking at some of the Vanguard funds/retirement funds instead of paying even more into my workplace pension?
Posted : 15/04/2021 10:42 pm
The point was made way early on that many folk (like me) took career options that had a long term benefit at the cost of short(er) term gain - e.g. TJ and his NHS Pension.
Posted : 15/04/2021 10:45 pm
My first lad was born when I was 16, the second at 22 plus being a Granddad at 34 for I've had loads of financial outlay lol.
It was the rule change to allow transferring out of DB pensions that made the difference to me. Without that I'd have struggled to accumulate such a large DC pension.
Life costs loads of money.
What I would say though is not to lose out on life now to provide for a pension you might never see.
Save, yes, but I wouldn't sacrifice too much.
Posted : 16/04/2021 8:25 am
My friend died a few weeks ago after contracting Covid and an underlying condition that actually only began during lockdown and was not diagnosed correctly or treated. He was very healthy other than the last few months. We are heartbroken and he leaves 4 children (he was 54)
Another friend died (a couple of years ago now) a couple of weeks after we came back from a skiing trip. He had his own business which he had just sold (he worked 7 days a week for years) and was quite well off. He was 55 and his wife now lives in the fantastic house he built.
These things happen all the time of course but when you get to a certain age and people very close to you start disappearing then it focuses your mind. Nothing wrong with working late into life if you enjoy it but I have a 1 year old grandson (I am 56) so maybe another 2-3 years until retirement for me. So many seem to want to replicate their working salary. I think thats a fools game. I may be happy cutting down my hours but I am quite senior so that may be difficult. It may be better to make a clean break.
Anyway this was just a ramble so please ignore. This thread is really useful.
Posted : 16/04/2021 8:40 am
Agreed - my younger brother died at 36.
Posted : 16/04/2021 8:46 am
I’m paying additional pension to 50% of the maximum yearly amount. Am I nuts for looking at some of the Vanguard funds/retirement funds instead of paying even more into my workplace pension?
A workplace pension won't any better than Vanguard. I would expect Vanguard to have lower fees as they are uber competetive on that. As for how well they do over time, that's down to the choice of funds and you can't know in advance if one strategy will beat another etc.
So no, you're not nuts at all.
Posted : 16/04/2021 9:33 am
The corollary of that is don't have too much fun when you're young and then spend years in poverty...
Posted : 16/04/2021 9:34 am
Well I have to add to that , I know a few on state pension alone and they are comfortable.
Is there such a thing as too much fun ?
Posted : 16/04/2021 9:50 am
My advice would be to pay enough to gain the maximum contribution from them at least. Then you have to weigh up the pros and cons of investing the extra into a SIPP (with fees) and the option to invest it as you like. Also look at what investment options are available in you workplace fund. Many take the default but I have made my own choices and outperformed by a long way the default.
Posted : 16/04/2021 9:58 am
 ji
SO I just handed back the work laptops, Ipad, phone, pass, keys, credit card etc and am now either between jobs or retired 🙂
Not quite sure I can survive on the savings I have until I can actually touch my pension, so may have to leave you all and go back into the world of employment - not quite sure doing what though!
Posted : 16/04/2021 12:48 pm
intentional or unintentional?
Posted : 16/04/2021 1:07 pm
 ton
has anyone else pulled the plug since this thread started ? just curious that all.
my wife finished in november, and since then 6 of her work friends have taken retirement.
and i was at a rugby game yesterday, and 3 old playing mates have also called it day in their mid 50's.
wonder if the plague has made people think that working and earning dont mean all that in the grand scheme maybe.
Posted : 13/06/2021 6:45 am
Not quite @ton but it has been on my mind a lot and I cant unsee it....
I have also spoken to a couple of mates and they have brought the subject up so it does seem on quite a few peoples minds although I am in that age bracket (56)
Posted : 13/06/2021 7:02 am
56 this year - financially I am able to retire now, but there's still something stopping me. I had a spell of unemployment about 10 years ago and my mental health really suffered so I think I'm wary of retiring.
Posted : 13/06/2021 9:23 am
This so very much and i am glad we did 🙂
the purist - you don't have to retire completely. I you can retire it means you could do afford to do part time / minimum wage work and / or volunteering - or seasonal work.
I ended up steering a middle path being able to retire at 60 just but having spent much money on adventures over the last 40 years.
Posted : 13/06/2021 9:41 am
A couple of friends of mine are now in the same boat, both due to redundancies in their mid-50s. She was working for a big bank and was offered redundancy with paid-up pension - why not?
10 days until moving to our new home - can’t wait. Lots to do to get the house and garden sorted including 25m of dry stone walling! Will look for some part-time work but will probably wait until next year when (hopefully) normality prevails.
Posted : 13/06/2021 10:09 am
the purist – you don’t have to retire completely. I you can retire it means you could do afford to do part time / minimum wage work and / or volunteering – or seasonal work.
Very much this. Part time Job doing now isnt the greatest paying job but I have zero responsibility zero stress i get loads of flexibility in hrs and days I can work. It's more about still getting up and doing something rather than drifting from one meal to next or worse next beer to next beer. It also pays for bike bits and saves dipping into pot.
Posted : 13/06/2021 10:20 am
Has anyone retired 37? 😀
Posted : 13/06/2021 11:21 am
A few of us recently left our company when they offered a package for the old gits. I was planning to retire in another 2 years but the package was the equivalent of another years net salary so it was a no brainer to take the money and run.
Posted : 13/06/2021 12:54 pm
Friend of mine did - inherited the family farm, converted the old barns to residential, rented out the pastures to neighbours, took up sailing.....
Posted : 13/06/2021 2:19 pm
When people's head goes a bit wobbly after retiring I would suggest it's not the retiring that is the cause but rather resolving long term issues that have not been addressed. My Mrs has a fascinating, well-paid job and she's chucking it in this year. Age disgracefully.
Posted : 14/06/2021 8:54 am
I'm 52. Retiring from my day job. Marine/offshore/sub sea operations, had enough after over 30 years of it.
When I made the decision it felt like a load was lifted off my back.
Me and Mrs now have 2 small businesses on the Northuumberland coast. They don't even feel like work to me.
If I never set foot in an airport again I will be happy.
Posted : 14/06/2021 9:12 am
Hmmm. That first article seemed bollocks to me. The notion that I'll need 75% of my pre retirement income post retirenent....
Utter nonsense.
Posted : 14/06/2021 10:47 am
 5lab
Hmmm. That first article seemed bollocks to me. The notion that I’ll need 75% of my pre retirement income post retirenent….
Utter nonsense.
I suspect I'll be spending significantly more once retired than I do today (whilst working). house is already paid off and I'm kept busy by work. If I don't have my days filled with working I'll be travelling for months at a time, riding my bike more, going out for lunch, all of which cost a lot more money than sitting at a desk in my spare room.
I can also see that someone might be spending £15k/year commuting, and plan to have their house paid off the day the retire. There isn't a one-size-fits-all for this kind of thing.
Posted : 14/06/2021 11:06 am
Depends on the individual and the less you earned probably the higher percentage you'd need in retirement as you'll be closer to the breadline etc.
Most final salary schemes were based about 2/3 ish, with the employee accruing 1/60th of their final salary for each year worked.
Posted : 14/06/2021 11:15 am
We've had large numbers take VS this year, I'm just a bit too young (51) and probably wouldn't have been approved due to pension needing to be paid off (to costly).
Posted : 14/06/2021 11:19 am
Not to be picky but that’s a change in career not retiring
Well done for doing it mind
Posted : 14/06/2021 11:21 am
Depends on the individual and the less you earned probably the higher percentage you’d need in retirement as you’ll be closer to the breadline etc
Yeah, agreed. I came to that same conclusion and that's why I didn't elaborate further. Probably shouldn't have posted even what I did.
Soz
Posted : 14/06/2021 11:25 am
If you aren't too worried about the money, what sort of job offers this ....
loads of flexibility in hrs and days I can work<
Posted : 14/06/2021 2:54 pm
If you aren’t too worried about the money, what sort of job offers this ….
(self appointed senior) maintenance technician at student halls 15 hrs a week, not bothered what days/hrs I work as long as the mandatory work gets done on time.
Posted : 14/06/2021 3:06 pm
Utter nonsense.
Most 'finance' articles are written a) by someone making a living from you buying their product and b) aimed at middle and upper class, financially flush and stable individuals who are target for point a).
Posted : 14/06/2021 3:12 pm
I m following the Pete Matthew finance podcasts, I know he s an ifa so not doing it for charity...but q interesting never the less.
One thing I notice is how money smart wealthy retirees are, when they really don't need to be. I suspect it's the challenge of saving money.
Posted : 14/06/2021 5:37 pm
One thing I notice is how money smart wealthy retirees are, when they really don’t need to be.
Maybe they're wealthy because they're money smart?
Posted : 14/06/2021 5:49 pm
I’m still working at 67, I’ve got several small workplace pensions and part of a private one I was advised to set up to pay off my mortgage, which was advice I regret following now, but I didn’t know better nearly thirty years ago. Thing is, now I no longer have my partner, I don’t have anything much to look forward to, but also I’m actually fairly well paid for the first time in my life, and my job now is very low stress and physically very easy to do, and I rather enjoy it, plus I work with some great people, so I might as well stick with it for the time being, otherwise I’ll just be sat at home most of the time.
Posted : 14/06/2021 11:57 pm
At my first job, after graduating, there was a retired chap who came back after his wife was killed in a car accident. He'd worked there all his life and been very senior but came back with a low stress, low responsibility job and sort of took it upon himself to look after all the graduates / sandwich students. He was 67 going on 17, had some amazing parties at his house. I think it genuinely saved his life, he'd had really bad depression after losing his wife but the job gave him a whole new second life.
Posted : 15/06/2021 9:07 am
Die rich.
Posted : 15/06/2021 9:59 am
Well I am unemployed now which means I am either between jobs or looking at retirement slightly earlier than I had planned. I wont go into what led up to this but I am not totally upset with the outcome after being unhappy with my employer for some time now.
I had planned to work for another 2-3 years and my investments are good but whether they are quite at the level to support my retirement now as oppose to another 2-3 years is a slight worry. One of the important opportunities I have lost is the ability to move monies into my SIPP at the higher tax rate which I had scheduled....
Posted : 12/08/2021 8:24 am
I have retired on about 30%
Posted : 12/08/2021 8:27 am
Ditto.
Of course, the affordability of this is down to what the pre-retirement income is. If you're on minimum wage it's unlikely to work out well.
Posted : 12/08/2021 8:32 am
@surfer- are you me? I could have written your first paragraph word for word…
Posted : 12/08/2021 8:41 am
Surprise surprise, investment companies want us all to put more of our hard earned with them. As has been said above, a broad brush approach really doesn't work. My pension is 50%, my actual take home is very close to 70% as I no longer pay a big chunk into said pension and I no longer pay NI. The devil is in the detail
Posted : 12/08/2021 8:48 am
I was 60 the other week,20 more shifts & I'm out of it.
I've not yet handed in my notice.It should be interesting when I do as I'm a supermarket trucker & there's a shortage of drivers at the momment.
Regarding what % of earnings people need to retire with,I'm looking at about 60% plus holidays.
I had the financial advisor from the bank visit me last week,she said I seem ready for retirement,I guess not everyone is.
My mates wife retired in May,she's 59 I ask her how she's finding retirement & she's now looking to get into a routine.She does'nt miss her job or the stress that came with it
Posted : 12/08/2021 9:01 am
Page 4 / 9
