Screen on my laptop got cracked at the weekend so I'm going to have a crack at replacing it myself. Anyone done it, got any tips? Doesn't look like too difficult a job, but I've said that before and lived to regret it 😉
Not difficult, just fiddly, try not to break any cables and all should be fine.
Have done hundreds, used to fix the things, never managed to destroy one through hamfistedness which amazed me 😛
Should add that if you YouTube the make and model someone will have posted a tear down video
straightforward if a bit fiddly was my experience of it
Id varies in complexity but as VanMan says it's largely just a bit fiddly. See if you can get a service manual for it from the manufacturer's website.
Take your time, keep track of which screws go where, and be methodical.
That's where I tend to go wrong!
Have done a couple. Not difficult, you just need to concentrate. Far easier than a screen on an iPad!
For keeping track of screws, take lots of photos, or use a GoPro or similar if you have one!
Easy to do. Some more fiddly than others.
As others have said try youtube.
Watchmakers screwdrivers are your friends.
Check there isn't a screen protector on the new screen, don't do what I did and ask on here and the suppliers tech support, why there was some numbers visible on the screen all the time after the new screen was fitted. 😳
As above, a bit fiddly in places but take your time and you'll have no problems. I've replaced about 7 or 8 now for various people. Make sure you have some good watchmakers screwdrivers.
Replaced the back-light in my screen last year, easy enough to get the screen out, as above just keep track of the screws, some are not immediately visible but hidden under rubber pads, need to ping these off first to access the screws. Un-plug tho old one and plug in the new & re-assemble, about as difficult as fitting a new headset on your bike.
Looks like I've got a job over the xmas hols then. Quick scan of youtube reveals it's not quite as simple as I'd hoped, but still looks doable. I've got to take the screen out to find out exactly which one I need anyway.
changed a few as a last resort. Quite satisfying - in no order..
-Get some decentish 'jewellers' drivers. Many are rough, soft or just badly made.
-Get a pry tool for the pop latches. Mastercards might do.
-Try and confirm the replacement screen is OEM or better quality (hard I know). I had some dire ones, hard to send back after fitting.
-Get some card,matcbox/small containers. Number the card or container and keep the screws etc. together by section. Best of all roll out some plstacine/blutack and keep the screws etc. on it!
Beware hot melt glue-it needs more grunt than a pedal to break free! , and you might be grateful for some ds contact tape to hold any broken clips/panels together when you reassemble!
Good tips bonchance, thanks 🙂
good luck! if you can get the old one out first, you can find the OEM marked numbers - try and match these up with the ebay or whatever photo of replacement.
quite a few screens will be generics - and the same chromebook or whatever might have a few different versions or mnfrs.
Using Feedback selector (findit with Google) may help check it's kosher (Assuming you get rplcmnt from Ebay of course)
They're called "spudgers" for googling purposes if you want a proper one. But yeah, I generally use an old store points card or some such; basically a credit card without any embossing.
That's a very good point actually. The Lenovo service manuals list FRUs - spare part codes - and there's generally a a few different ones for any given model.
Replaced the one on my Sony a couple of months back, pretty straightforward. Have a look on Youtube for a how to demonstartion.
My top tip is to make sure it works before putting it all back togehter!
Try ifixit.com for a breakdown. If not Youtube. Get a big piece of paper to tape all the little screws etc. to in the order they came out in.
This, don't buy those stupid 'watch makers' little metal handle ones, you can't get any purchase on them. just buy small normal screwdrivers with decent size plastic/rubber grippy handles.
ifixit - yes
These may be of use:
http://www.maplin.co.uk/p/proskit-14-part-ratchet-precision-screwdriver-set-l95bq
Or any existing ones in good/sharp condition with genuine Cr-V blades.
I've done it a couple of times and it was fiddly but ok. The people who supplied the screen also included instructions but it's always good to also check YouTube to get a bit of confidence in what you are doing. I think the site was something like laptopsdirect.co.uk but I'm not at work so can't check - sorry
