Replacing a few bri...
[Closed] Replacing a few bricks - do it myself or hire a bricklayer?
14 Users
Is it worth it? Might get a few quotes but how much would you pay? Or Just DIY?
The bricks broke where the satellite idiot installer hammered off my aerial, so I’ll 1-2 replacing.
Tempting to do it myself but looking st costs if tools and storage.
Posted : 30/08/2018 12:36 pm
1 or 2 bricks? You will need a 2lb lump hammer a cold chisel or plugging chisel and a bolster to clean the mortar of the in situ bricks. It's a piece of piss.
Posted : 30/08/2018 12:52 pm
But look what happened last time Frankenstein created something himself.
Posted : 30/08/2018 1:19 pm
You might find it difficult to find a good bricklayer willing to do a job that small anyway
Posted : 30/08/2018 1:27 pm
Overkill, any random builder should be able to replace a couple of bricks and do a half decent job....
Posted : 30/08/2018 1:52 pm
Overkill, any random builder should be able to replace a couple of bricks and do a half decent job….
True.  You might also find it difficult to find a good random builder willing to do a job that small, though.  It's an easy job though, so even a hopeless random builder shouldn't be able to mess it up too badly.  I'd just take my time and do it myself.
Posted : 30/08/2018 1:57 pm
Easy peasy job. Tools will be a 7lb hammer a cold chisel and a trowel, plus some ready mixed mortar. All readily available fro B&Q (Other stores do exist). Will cost you a lot less than a brickie would - if you can find one to do that small a job.
Posted : 30/08/2018 1:58 pm
Thanks for the info!
Was quoted £35 for work incl bricks by an independent brickie.
Now off to buy the bricks and match the colour.
My old man wants to do the work for/with me now.
So what could go wrong with Frankenstein Senior with me?
Posted : 30/08/2018 2:10 pm
Same question.
I've got to move our kitchen extractor a smidgen as the previous owner swapped from a standard cooker to a range so its no longer central.
Outside its a big square Airbrick, inside I guess its just a big hole in the block.
The outside isn't somewhere noticeable so I'll just leave the Airbrick and stick a core drill through the wall next to it. But how to do the inside? Just fill with foam and tile over? The new hole will only be a foot away at most so I'm guessing two big 6" holes close together might not be optimal? Use the core drill to cut out a 'plug' when making the new hole and mortar that in the old hole?
Posted : 30/08/2018 2:27 pm
£0.75p per brick and ready mix for £10 if that helps anyone.
Posted : 30/08/2018 2:29 pm
Ready mix was £10.
Posted : 30/08/2018 2:39 pm
Looking at the wall and the satellite installation guy did a right stupid job on the wall.
Cracked 2 bricks, destroyed 2 and damaged the wall overall.  Wish I grinded the old bolts off myself.
Anyway up the spout here and drilling away Swiss cheese style.
I would hate to do this in winter as I’m wussy.
Spoony-just use filler if it’s going to by tiles over.  If it’s the same block then assess the condition of it and if knackered - replace.
Posted : 30/08/2018 5:13 pm
7lb hammer!!!! Good luck with that 🤪😂
Posted : 30/08/2018 5:24 pm
I'd have said the £35 was a cracking price if he is good, I'd pay money to see anyone holding a chisel and using a 7lb hammer must have some forearm
Posted : 30/08/2018 5:41 pm
 I’d pay money to see anyone holding a chisel and using a 7lb hammer must have some forearm
Teenage boys usually have at least one well developed forearm 😆😆
Posted : 30/08/2018 8:31 pm
£35 for a builder to do the job? Take his hand off and let him do it!
Not always as easy as it looks
Posted : 30/08/2018 9:08 pm
1: £35...unless you like to DIY everything, bite his arm off
2: Satellite installer should be footing the bill, even more so if its someone reputable such as Sky etc.
Posted : 30/08/2018 9:09 pm
For that I'd just get them to do it.  How much are you really saving yourself after you've bought the tools etc ?
Posted : 31/08/2018 1:26 pm
Probably not worth the hassle for the sake of £35 ("we didn't break anything, prove it"), but that was my first thought also.
You took plenty of photos, yes?
Posted : 31/08/2018 1:35 pm
For £35 I'd get it done and if it's a decent job you've got yourself a useful contact for anything else you might need in the future.
Posted : 31/08/2018 1:47 pm
Unfortunately my old man was adamant and had the tools.
Took an hour to drill Swiss cheese bricks and then an another hour to get the bricks and cement in.
I did warn him it’s quick drying 10 mins mix but it looks pretty good.
Personally I’d rather pay £35 as I was knackered from drilling and hammering.
Posted : 09/09/2018 8:03 am
