Removing Aqualisa g...
Removing Aqualisa gripper plate
5 Users
I need to replace a shower bar valve and the current one has the following gripper plate holding the pipes in place:
https://www.showerspares.com/search/gripper_ring_assembly_214022/?srsltid=AfmBOopdpN4bVq951pfHts-j6YFGT-t855q0kQLgeGTzCX8rOZgg5rvk
Before I start removing the shower valve, does anyone know how to remove this without damaging the pipes?
Posted : 27/09/2025 4:58 pm
Would it be possible to break off everything except the metal rings that do the gripping, then fit the new valve to cover the rings?
I imagine the gripper rings could be pushed further onto the pipes once the rest of the bracket is gone?
Failing that buy some either really good OR disposable side/flush cutters and ship the rings once they are exposed?
Posted : 28/09/2025 7:56 am
Can the teeth be levered out with a small screwdriver and bent far enough out that they won't dig into the pipe? If they spring back maybe cut a bit out of a juice can and slide it under the teeth to stop them digging in?
Could always just break the plastic and cut it from the outside edge in
Posted : 28/09/2025 10:15 am
I'll give those ideas a go. Have a few small screwdrivers and cutters.
Thanks.
Posted : 28/09/2025 5:55 pm
Dremmel (or similar)?
Posted : 28/09/2025 9:57 pm
Could you push/tap a  brass olive into the ends of the grippers so that they lift off the pipe? Might be able to just slide off that way.
Posted : 29/09/2025 5:42 am
