Red engine coolant,...
[Closed] Red engine coolant, Ford content.
7 Users
The coolant is looking a little low on my 07 Focus now this is the red stuff that they put in modern cars. Is it OK to top it up with water or do I need to buy some red stuff to top it up?
Thanks
Posted : 06/03/2012 9:42 am
I'd never top up with just water unless it was an emergency - you're just reducing the ability of the coolant to withstand frost and absorb heat.
Posted : 06/03/2012 9:45 am
It only needs a little bit probably less than 200ml. Will it really make much of an impact on the cooling ability?
Posted : 06/03/2012 10:01 am
No, just keep an eye on it. If you have to keep topping up then get some antifreeze
Posted : 06/03/2012 10:04 am
The red coolant is OAT - Organic Acid Technology coolant. I would top up with water is a small amount, but don't top up with non-OAT (i.e. blue) normal anti-freeze; they are not really compatible.
Also, if you are losing coolant, keep an eye out on the level and try to see where it is escaping. could be a nice, slow pressure leak from a borked header cap or it could be a holed radiator. Either way you might end up with HGF.
Posted : 06/03/2012 10:08 am
I don't think I'm loosing coolant. It has been in there for a good 4 years. I know I should probably change it but the engine stays at a constant temp when running so I'm waiting for the temp to creep up a bit before changing the whole lot.
Posted : 06/03/2012 10:35 am
changing the whole lot?
it sould just be a hose leak or a clip that has come loose no need to change the whole engine?
Posted : 06/03/2012 10:37 am
 hora
Personally I'd have just a coolant change carried out. Its not that much.
In addition- keep a daily eye on it (cold) and mark its level mentally.
I say this as mine started dropping- suddenly over two days it was an inch each day.
I caught the water pump before it let go completely.
Posted : 06/03/2012 10:46 am
You can get this ready mixed in small amounts for topping up.
Posted : 06/03/2012 10:54 am
Mine has been less than that in the past 2 years.
Posted : 06/03/2012 10:59 am
 hora
Mine was a small amount for ages then suddenly within 2days the marked-loss.
Your within the recommended range now for a coolant change.
Posted : 06/03/2012 11:04 am
