Recovering a delete...
[Closed] Recovering a deleted partition or contents from a FAT32 disk
7 Users
So, like all people 'nevitably do, I messed up in a way I should have know better 🙂
While rebuilding my PC I was distracted at the crucial moment.
I used GPARTED to nuke the previous Windows install partition on my primary disk. I installed an SSD and I didn't want the machine to try to boot from the old Windows install, but I did want the rest of the partitions.
I deleted the wrong partition!
ZOMG I'VE LOST ALL OF BABYLON 5 [and a set of coursework backups], and Red Dwarf too, I think. You appreciate the gravity of the situation.
This actually happened a few months ago. Since wiping that, and also the correct partition, I have not reinstated either of them. There is a 300GB partition still active on the disk which has been used, but not had it's parameters modified.
Now, assuming it's just the index/partition table that is modified by this action - how do I recover the affected files from the deleted Data partition? The files should be there still, I hope.
The drive is a 1TB WD Caviar Black. It is NOT the boot drive.
I have Win7 and Ubuntu/Mint at my disposal.
Any help appreciated, ta.
Posted : 18/09/2014 9:13 am
You may be able to get the data off it using something like Helix (free download) or the forensic tools on Kali (free download), but I have never tried to recover a partition using either of those.
I have a strong feeling that, if the disk has been used since you made the boo-boo, data might have leaked over Babylon 5, so you may be out of luck. Try anyway though and see what happens.
Posted : 18/09/2014 9:16 am
I've had success with Easeus Partition Recovery, but on a disc with flaky boot sectors/partition table, not a nuked one. I'd clone the drive first though, and work on the copy.
Posted : 18/09/2014 10:22 am
Cloning the drive is a good idea..... except I'll need another disc, which I probably don't have. I'll see what I can find first, then make a decision about what to recover it to .
I downloaded the Helix 3 .iso - which tool would i want to use - they seem geared towards someone who already knows what they're doing with the software.
Can you point me to one that will scan for partitions, willard?
Thanks guys.
Posted : 18/09/2014 10:50 am
you could try isobuster. its not free but i used it to recover stuff from a cdrom that was no longer readable normally. you shouldn't have overwritten anything providing you haven't created a new partition in the free space that was created when you deleted the old one
Posted : 18/09/2014 10:58 am
I've used Recuva in the past. Worked well. I think they do a free trial
Posted : 18/09/2014 11:40 am
Crell - Recuva didn't work, got confused by the partitions.
keefmac - I'll save paid software for last ditch 😉
Cheers anyway.
Posted : 18/09/2014 11:49 am
TestDisk might be worth a try.
http://www.cgsecurity.org/wiki/TestDisk
Posted : 18/09/2014 11:58 am
TestDisk'll do it. However it's a powerful tool and can also cause mass destruction (particularly relevant since you mentioned getting confused by the partitions...)
If you want to give it a try; I'm happy to advise on how to do it. Or I can give you a hand if you are anywhere near Leeds.
Steve
Posted : 18/09/2014 12:29 pm
MiniTool Partition Magic/Wizard is handy too
Posted : 18/09/2014 12:52 pm
Hi steve - as at happens I am in Bradford. I could travel to Leeds, but it's a fairly giant machine with a very large CPU cooler and I don't like to lug it around much.
I launched testdisk, and I'm now doing a scan, but it's throwing errors about cylinder/head and sector mismatches. I guess I can't recover the data safely without knowing more about what's I'm doing.
How's about I provide beers and you come to mine? No great hurry - whenever's convenient.
Posted : 18/09/2014 1:23 pm
Where 'bouts in Bradford are you ? I'm actually in Tong; so it sounds doable 🙂
Posted : 18/09/2014 2:32 pm
BD1 - Canal Road
sam{d0t}firth{?t}gmail{d0t}com
Not tonight or tomorrow - but after that...
Cheers!
Posted : 18/09/2014 2:43 pm
No worries; will drop you an e-mail to arrange from here.
Cheers,
Steve
Posted : 18/09/2014 3:23 pm
