The strap on my 735xt is slowly dying but a straight Garmin own brand replacement feels a bit overpriced really at 23quid. Has anyone found anything cheaper that will do the job well? I don't need super cheap but 23 is a bit much really
Not sure if that model is quickfit compatible. Whilst I'm not usually a fan of Abiexpress etc, these came recommend by a friend and I ordered 3. They are 90% as good as Garmin genuine.
excllent thanks. I've seen the AnBest stuff come up before so good to have a recommendation. Prices seems a lot more sensible
I recently bought a 22mm strap for my Fenix 6 from zymall-2021 on ebay. It was £7.45 posted and as good as the std Garmin strap. Loads of colours.
Thanks
Loads on ebay.
Only issue I've had is the quick change metal ends must have been magnetized so screwed with the electronic compass, had to do a factory reset and took the quick change bits off. The watch pins then fit straight through the strap and no more issues.
