Recommend me a home...
[Closed] Recommend me a home 4g router.
4 Users
As title, I'm near breaking point with Openreach.
Need to figure out which network will work out best for the actual 4g part.
I'm guessing a home router will have a better range than the portable ones?
Ta in advance.
Posted : 27/07/2018 4:04 pm
4g? As in mobile? Or you just confusing that with WiFi?
Posted : 27/07/2018 4:25 pm
You can get dual mode routers that do normal broadband and allow you to plug in a 4G connection when needed, probably worth looking at one of those.
Posted : 27/07/2018 4:34 pm
4g as in mobile. But for home use. Vodafone do 100gb home 4g for £18.99.
I'm looking for a recommendation for a home 4g router.
Posted : 27/07/2018 4:35 pm
The HUAWEI LTE routers work well and give a very reliable connection - this one would do the trick:
https://www.amazon.co.uk/dp/B013P15G4K/ref=cm_sw_r_cp_api_l2ZwBbE571BF4
It may vary where you are but when openreach flaked out for a month and we had to use 4g for broadband Vodafone and O2 were both useless  - strong signal but abysmal speeds in the evening. EE and three both worked very well - they also both offer 4g home router products if you want to just keep it simple.
Posted : 27/07/2018 4:45 pm
I think I'll grab a Vodafone SIM and chuck it in my phone to check it out before committing then.
Posted : 27/07/2018 5:07 pm
breadcrumb
I’m looking for a recommendation for a home 4g router.
Ah right, cool, never knew such a thing existed!
Posted : 27/07/2018 5:12 pm
