Hi all,
Dad needs a new drill, not sure if one to cover all this exists, but moon on a stick requirements as follows;
-Will be used for drilling into wood, brick, stone, as well as screw-drivering
-Cordless
-Hammer setting
-Fairly lightweight
-At least 1/2inch chuck
-Reversible and adjustable speeds
-Decent battery tech (I'm assuming li-ion), with good power and run-time
Had a really quick look and something like this looks decent?
http://www.screwfix.com/p/makita-bhp453rftk-18v-3ah-li-ion-cordless-combi-drill-w-101pc-accessory-kit/20547#product_additional_details_container
As a side note, the drill will likely be kept in the garage which normally gets below 0*c in winter - will that affect (or help?) li-ions?
Cheers, Duane.
Thst drill looks ok for what you're asking for. Only issue is the single battery, wont be a problem for light mid diy use, but prolonged use if its his only drill, having to stop for an hour or so while the battery charges.
A liion charges in something like 20 mins, it gets to 80% charge really quickly and with liion batteries you can interrupt the charge. The makita charger gives you a light to signal 80% meaning you can give it quick partial charges and get plenty of work afterwards, so having one battery is fine for home use.
^^^^^^^^ this ^^^^^^
Makita 453 perfect. Lucky dad.
Or, lighter, £70 cheaper and 2 batteries (1.3Ah as opposed to 3Ah)
Just got a Bosch PRS 18 Li-ion with two batteries from B&Q for £99z doing me well so far...
This one...
I use that Makita and it's superb also use the impact driver which is awesome
[url= http://www.screwfix.com/p/dewalt-xr-dcd785c2sf-gb-18v-1-5ah-li-ion-cordless-combi-drill/22732 ]I got this...[/url]
and a shed load of top quality bits for it with teh £50 change has 2 batteries full charge in 30 mins.
Kitchen fitter killed one of them makitas when he was fitting my kitchen he reckoned the dewalt was slightly better.
Cheers all - any thoughts on this?
Hi
Makita for me , got mine from toolchestdirect a while ago , at the time they couldnt be beaten on price
