Recommend a Wood Sh...
[Closed] Recommend a Wood Shed
4 Users
I'm looking at buying a wooden shed (10 x 6) - can anyone recommend a good make?
Also is paying extra for 20mm cladding worth it over the normal 12mm ish cladding?
How easy is it to erect yourself?
Thanks
Posted : 14/02/2015 12:31 pm
You'll pay a fortune for a woodshed, even buying new tantalised timber and making it yourself will be cheaper, but even that's a bit overkill tbh. I have built a few now, started of buying timber but have since built some from an old fence I took down, as the posts were rotten. Only cost me the price of the screws and a bit of roofing felt.
Posted : 14/02/2015 12:35 pm
I've always just made the of old pallets - helps the air flow to keep on drying the wood out. A pallet base to keep off the floor and keep logs dry. Add a sloping top using sawn timber and some corrugated sheeting - about an inch drop a foot. The top sheeting is the most expensive bit followed by getting a bunch of big screws and some timber from the store. Pallets about a quid a piece!
Posted : 14/02/2015 1:50 pm
Thanks, should have said a wooden shed (not a wood/log storage shed) I was after.
Posted : 14/02/2015 2:16 pm
I was going to say the same as pippin but now I know you're after a garden shed the only advice I can give is don't do what I did and varnish it yourself instead of getting it factory dipped - saved myself about £10 for a days painting gutted
Very easy to assemble helps if you've got some to help hold the panels
Posted : 14/02/2015 3:49 pm
