Recommend a drill s...
Recommend a drill set for metal
7 Users
Pref not too expensive drill set (pref with individual replacements)that can deal with metal repeatedly, e.g. cleat removal (* first manky cleat took about 3 mins, second about 90 mins, hacksaw, punch, pliers, vice, a gawd awful mess)
Also do drill sharpeners actually work or any other tips for keeping drills working.
Ta
Posted : 30/08/2022 12:36 pm
The wee Makita pack from screwfix is descent enough for most purposes unless you think you'll need to make very big or very small holes
https://www.screwfix.com/p/makita-d-67527-straight-shank-hss-tin-metal-bit-set-19-pcs/265xp?_requestid=211201
I'd used the dewalt extreme bits previously but although they are great at starting a cut they are very prone to grabbing the work piece and snapping.
If you need to replace anything - you don't need to replace like for like. Buy a little five-pack of what every quality you like of the drill bit size you use most. I used the pack above as the suits-all-occasions set and buy 5 packs of double ended twist-drill bits for the sizes of hole I drill the most (3mm and 5mm)
Posted : 30/08/2022 12:50 pm
Makita.
Posted : 30/08/2022 1:00 pm
the word 'manky' might be a factor - grit is going to blunt drill bits. Other than that some oil on the drill bit / hole, keep the speed down and get a bit of weight behind it - the drill bit should be cutting not rubbing its way through the metal so you should be creating ribbons of metal as you drill, not fillings.
Posted : 30/08/2022 1:08 pm
Cobalt all day long, tough as f***.
Posted : 30/08/2022 2:08 pm
Cobalt steel.
Posted : 30/08/2022 2:09 pm
For mild steel, brass, alu, or any other soft metal, a set of HSS and a bit of knowledge on how to grind them will see you OK.
If youre drilling anything with a hex head ( socket head bolt,countersink bolts, cleat screws, etc, ) or similar tougher material, then its Cobalt HSS all day long, dont bother with HSS.
Posted : 30/08/2022 4:23 pm
Big thanks guys,
New cobalt drill, some chain lube, cheapie handheld drill at slowest speed, two cleats off in about 5 mins. Cheers. Oh yeah, it does create ribbons, nice one.
Posted : 06/09/2022 11:15 am
