My window on the hatchback boot door is coming away. Dunno how long it's been like that but I noticed it today when I shut the boot and it rattled.
Easy fix? The car's 17 years old so not surprising really, but hopefully something as simple as squirting a load of glue/sealant/gripfill in the gap 🙂
What car ? Is it bonded in place or held in with rubbers ?
How much is your glass excess on insurance?
I had auto glass take out and rebond my windscreen (through insurance) and it only cost £25.
No idea tbh. Insurance never occurred to me. Will have a look.
Could be rust seperating the bonding agent from the body work. That's what it was on my old transporter.
Solution was to remove the glass, sort the rust and respray then refit the glass.
Computer says no. As the glass isn't actually damaged. So I can either get it repaired myself, or wait for it to fall out and then ring the insurance again.
Just take it up to your local windscreen replacement centre to ask them for a quote. As above, probably only £50 max i'd have thought.
Shame. Some companies are just stupid 🙄
When I rang mine they said "sure, we would rather do it now as it's cheaper than a full replacement down the line when it breaks"
Legal&General was mine.
The insurance generally only covers "windscreens"
I know someone who locked their keys in the car, who broke a side window to gain access. To find out it wasn't covered, if they'd broken the windscreen it would have been!
Best way is to find a small local windscreen repair guy and ask him to take it out and reseal it.
I do suspect that there will be rust causing it though!
Similar happened to the windscreen on my cavalier back in the day. Used to get a blast of cold air and engine noise when I went over a bump and the glass lifted!
It was rust causing it
At least on a tailgate you can just replace the whole tailgate with a scrap one. Might be worth having a deposit on a replacement at least before removing the glass just in case you find you need it
Or squirt a load of silicone in and hope for the best!!
That is what I did.
After cleaning it all up with isopropyl. Seems solid enough, I don't think it would actually fall out without warning as it's held in place at least by the wiper mechanism and the little cables for the heated window. Probably wouldn't have done it if the whole window was loose.
